Question about HP Designjet 5500 (42 in.) InkJet Printer
I have a DesignJet 5500. Just this morning, I noticed the color is not being "sprayed" down evenly. Each color "oscillates" across the entire sheet leaving a smooth gradient of bands of normal & light coverage about every .5". The "pattern" occurs at the same intervals & position with each color/printhead so I believe it has to be an issue with the way the ink is flowing to the printheads. Any assistance and/or information you can provide would be appreciated.
  • 5 Answers
SOURCE: Printer assistance
please change of it's printer driver software
and i think printer going ok
Posted on Feb 14, 2008
SOURCE: Kodak 5500-printhead problems
I was having problems in trying to remove a faulty printhead. It all started with asking Kodak for instructions for removing it,. The technician wasn't able to remove it. After they sent 2 printhead replacements in less then a year, they included a website which I was to go on to solve the problem. 2 hours later I found a website where someone(thank you whoever you are) suggested that you put your thumb in the middle of the top part of the printhead(after tthe ionk cartridges are removed) push toward the back gently & lift it out with your other hand, It came out quite easily. Why couldn't Kodak print insructions as such & better yet why couldn't they have a photo taken with a digital camera & sent it with their replacement parts or by e-mail. I realy feel Kodak & all other companies should be taken to task on this, They rely too much on websites to cover their inefficiences.
Posted on Oct 11, 2008
  • 203 Answers
SOURCE: change printhead in 5500
To change the printer head on the Kodak 5500 AIO printer, you will need to do the following:
To remove the old printer head,
  1. Power on the printer.
  2. Lift up the lid to expose the printer head.
  3. Once the printer head moves to the middle, where you can get at it, then unplug the power cord to the printer.
  4. Remove the ink cartridges.
  5. With the printer head now empty, run your finder along the underside of the top of the printer head, all the way to the left side of the printer head.
  6. Push up with your finger where there is some give, and the shroud that holds the printer head will release the head.
To install the new head,
  1. Simply put it in place, and push forward with your finger on the sticker that shows a finger pushing on a sticker, and you will hear and feel it click into place.
  2. Reload your ink cartridges, close the lid, plug the printer back in and you're done.
Posted on Jan 07, 2009
efs_perpends
  • 1996 Answers
SOURCE: how do you resolve a hp designjet 1050C printhead path (1) - turn power off and check issue
Please read through some of the information provided in this link and this link from the HP support forums.
Also see this basic troubleshooting guide here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 20, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 5500 error code 0b0006
Hello. This error code indicates that the 5VDC and ground are shorted together by the trailing cable. Replace the trailing cable.
May 21, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 5500 Main board faults
if you want component level repairing...
just send mail to me which for matter board repair you want???
Apr 14, 2014 | HP Designjet 5500 (42 in.) InkJet Printer
Hp designjet 5500 error codes
Error code 0C0040 is caused by the drop detector not detecting drops from at least 2 print heads in the same area. Run print head recovery on all the print heads and see if that clears up the problem. If not, then clean or replace the drop detector. Drop detector can be ordered from: http://www.lpscomputer.com/p-2512-c6072-60179-designjet-5000-5500-drop-detector.aspx
Sep 30, 2013 | HP Designjet 5500 (42 in.) InkJet Printer
How to find ip address in hp 5500
To locate the IP address with the HP Designjet 5500, follow these steps below:
Press the Down Arrow keys on the front panel until the Setup Menu is displayed. Press ENTER. Go to the Utilities menu and select Test Prints.Press ENTER. For the HP Designjet 5000 series, select Service Config. Press ENTER. For the HP Designjet 5500 series, select Network-card Config. Press ENTER
Feb 12, 2011 | HP Color LaserJet 5500 Printer
I have problem with my 5500 hp: check printhead path 2
The most common cause of the Check Print Head Path Error 2 is a worn out carriage belt. Open the top cover and locate the carriage belt. It is the long thin belt that extends the full length of the plotter. Use a light and look under the belt for debris that looks like pencil erasure crumbs. If the crumbs are there, the belt is disintegrating and needs to be replaced. See: http://www.lpscomputer.com/c-732-designjet-5000-5500-belt.aspx
Dec 01, 2010 | HP Designjet 5500 (42 in.) InkJet Printer
After print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Oct 13, 2009 | HP DesignJet 5500PS InkJet Printer
Change host name on HP designjet 5500
Go to the printer server and open up the printer properties in the control panel then in the shared tab, locate the name and change it.
May 21, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
HP Designjet 5500 (42 in.) InkJet Printer Logo
139 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
