Question about JVC Audio Players & Recorders
I have an old JVC Shelf top shelf top stereo system (model # MXD661T) that just recently stopped playing CD's. It has a 3 disc changer. When I put a disc it, the system tries to read it and then just opens the CD door as if no CD where in the player. Could it need to be cleaned??
    Top Expert:
  • JVC Master
  • 75,311 Answers
Hello
There are two possibilies for this faut. The first one is related with its Laser Pickup Unit, and the second one is related to its loading mechanism. If loading mechanism did not load disc properly to to the holding disc drive motor, disc wont play, and will be ejected as it enters into the system. i don't know, how old your system is, and how much it used so far. Anyway try first by inserting a head cleaning disc into the tray and play it for two of more time. if this does not help you try replacing the loading belt. You have to open your system to do this work. Loading belt can be located at the loading mechanism, fastened with its loading gear and loading motor. If this also does not help you, there is no other way than replacing the laser Picup Unit with same type and number. To repalce either belt or laser pickup unit, you have to open and disassemble the mechanism itsef to do the work. If you are not aware in electronics, and not so experienced in doing this type of work, get help from an other who knows these well. Most of the [90%] of components used in this section are made of high density plastic, and can be damged easly. If any wheel in loading gerar mechanis has broken teeth with it, also will poise this probelm. So it also should be checked.
Anyway you have to open and disassemble the mechanism as a whole. OK
Posted on May 25, 2011
My JVC stereo doesn't play cd's anymore, still runs audio for tv, and radio. What is best, low price stereo option i can hook speakers up to and play cd's again?
The CD player might just need it's lens cleaning. Best way to do this is taking the top off and cleaning the lens with either Servisol Video 40 or CD lens cleaning fluid.
Mar 03, 2013 | JVC MXKB30 300W 3-Disc CD Shelf System...
Jvc stereo model mx-kc4 cd tray won't open make loud noise
sounds like theres something keeping it jammed in might be one of those pull hard and hope jobs :) good luck
Mar 24, 2012 | JVC MXKC4 360-Watt Compact Component Audio...
The stereo works fine but i cannot eject the cd's
I just had the same problem with the same model. Disc five was saying no disc and would not play any other discs. I opened the radio and found the the CD tray was missing a piece for disc five. You have to put the disc tray back into the holder to fix it. Make sure it locks in place and you should be able to get the rest to work.
Feb 11, 2010 | JVC HX-D77 Shelf System
I have a memorex stereo, turntable, 3 cd changer etc. The standby light comes on but no sound, it is only 2 yrs old..
Sometimes you have to unplug it for about 30 seconds, then when you plug it in press the power on button. If there is still no sound, check the speaker connections on the back they sometimes come loose.
Oct 17, 2009 | Electro Brand Nostalgic Stereo CD Music...
RCA RP-9515 stereo, CD player won't play
RD probably stands for "Reading Disc" and ND probably stands for "No Disc". If the CD player doesn't recognize any discs, then either the laser is dead or the motor has died. MOst likely you will have to replace the unit.
Mar 22, 2009 | RCA 100-Watt Stereo System With 5-CD...
How can I get the cd changer to stop changing non stop?
Something is out of timing. When powered up, the unit trys to get to a known state and will continue until it reaches that state. If the timing of the gears has been changed, this may not occur.
I'll try to see if I can create a set of instructions to re-time this.
Dan
Mar 11, 2009 | Sony MHC-GX450 CD Shelf System
Fisher 143a CD Changer
HI...
You wont be able to play any new format CDs on an old Fisher or any other older make . It 's the internal decoder logic that's needed. And older players dont have it.
As far as top-loaders..Do a websearch . I dont know of any.
Jan 27, 2009 | Jwin JK-777 Nostalgic Stereo System with...
Hooking up surround sound
to get the digital you have to have the digital optical line or the coax rca jack digital audio connection from device to stereo reciever to get the dolby digital surround sound to work , otherwise you can only get a virtual surround sound from the reciever( no dolby digital )
Jan 04, 2009 | Sharp CDBA3100 Remanufactured Mini-System...
How to unlock protected mode on a jvc 5 disc cd changer?
cheack the speaker wireing.if thats not the pro i sugg the repair shop your unit could have over heated.
Jan 06, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
133 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
