Question about Philips Cell Phones
We have purchased a phillips perfect sound 2000 CD275 When we try to set the date and time it will not accept the new numbers. Following the instructions we get to where it is flashing on the date but it will not accept the new numbers.
Hiya, we've just had the same problem here. I think I may have figured it out so thought I'd put it on here in case anyone else came in search of answers!
I think the date is in US format and not UK format, so it is MM/DD/YY instead of DD/MM/YY. So you can only put up to 12 in the first section and as I was trying to put 31st August in so it didn't like it very much! So you have to put 08/31/11 instead of 31/08/11
I hope this makes sense and is of help!
Posted on Aug 31, 2011
HOW TO SET TIME AND DATE ON LG FLIP PHONE 441g
Check your manual for guidance. How can anyone help without the model number? Duh!
Sep 19, 2017 | LG Cell Phones
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Imei 35454001633758 i need security code
Jun 28, 2011 | Nokia 1110i Cellular Phone
How do I change the date on a Sharp EL-1801V calculator?
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Apr 10, 2010 | Sharp EL-2630P Calculator
Forgot service password for HP Surestore Tape Autoloader 1/9 DLT 1 Tape Drive
This legacy devices service password can be reseated by following this steps:
The following is required before resetting the password:
  1. Access to the front panel of the HP Surestore DLT library.
  2. From the Home screen, press Main.
  3. From Main, press Information.
  4. From Information, press More.
  5. From this menu, press Date and Time.
  6. Write down the date (including year) and time.
The display shows a valid date and time
Do the following:
  1. Press the left-most button (button 1). This button is not labeled. A warning message to call service will appear.
  2. Press OK.
  3. The Call Center must then calculate a special password based on the date and time, using the following formula:
    1. (Hours * 1001) + (Days * 101) + Month + Year (all 4 digits) = subtotal
    2. Multiply the subtotal by 123. If this multiplication results in a number greater than 99,999,999 (this should never happen), use the special password of 44122333.
    3. Since the only valid choices are 1-4 for each digit, follow these rules:
      • If the digit=0 (zero), make the digit=1
      • If the digit=9, then make digit=1
      • If the digit>4, subtract 4 from the digit
      • If the digit does not meet any of the above, leave the digit unchanged. If the result is less than 8 digits, add leading 1s to make it eight digits in length.
        NOTE: As an example, 2000 02/07 2:30 is displayed (February 7, 2000 at 2:30). Plugging in the numbers: (2 * 1001) + (7 * 101) + 2 + 2000 = 4711
        4711 * 123 = 59453
        Convert all digits to be between 1 and 4 = 131413
        Add the leading 1s to make it eight digits long - 11131413
  4. Enter this special code to the front panel.
  5. Press OK. The screen will confirm that the password has been reset.
  6. Set a new password.
Mar 08, 2010 | HP Surestore Tape Autoloader 1/9 (C7147A)...
Plz tell me security code my phone nokia 6235
*#06# - Check the IMEI (International Mobile Equipment Identity)
*#7780# - Restore Factory Settings (Memory, language, counters not included)
*#3110# - Check the phone's software (SW) - called firmware revision information.
*#746025625# - To check if the Sim-Clock can be Stopped
(Sim-clock-stop is a kind of standby mode which will save battery time)
*#92702689# - Phone asks 'warranty code:'
Press for the following warranty code:
7832 (OK) : Displays the date where the phone was purchased
37832 (OK) : Set the Purchasing Date MMYY (Warning: You can only do this once - So be careful ...)
defalt security code is 12345
or go to any mobile shop for unlocking normal charge rs 50/-
Feb 01, 2010 | Nokia 6300 Cellular Phone
HOW TO SET A CLOCK AND CALENDAR ON SHARP EL-1750P CALCULATOR
GT •RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR:
“GT”: Grand Total
“•”: Neutral
“RATE SET”: To set the date, time, and tax rate, set this switch at the “RATE SET” position.
Date:
• Enter in the order of month, day and year, then press to complete the entry.
• Use to separate month, day, and year.
• When is pressed, the number entered is evaluated and displayed as “date” if the
value is within the following range; “Error” is displayed otherwise, and the previously set
date is restored.
Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits)
Time:
• Enter in the order of hour, minutes, then press to complete the entry.
(There is no entry available for the seconds value. The clock starts at zero second.)
• If the hour/minute digit is less than 10, it is not necessary to enter the first digit “0”.
• Use to separate hour and minute values.
• When is pressed, the number entered is evaluated and displayed as “time” if the
time is restored.
Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Aug 22, 2008 | Sharp EL-1750PIII Calculator
Master code for all nokia 3110
Nokia Unlock Codes, Nokia Phone 3110 Secret Codes, Cell Phone Codes
Nokia 3110 Secrets
*#7780# Restores Factory Settings (Memory, language, counters are not included).
Press the following warranty code :
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it. The cell phone will however accept another SIM card from the same operator. All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for up to 4 different providers. But most phones with restriction only have one lock activated. (Lock 1) The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove SIM card restriction (SP-lock).
Use the * key to get the p, + and w chars.
#pw+1234567890+4# for SimCard-Lock status # = DOUBLE-CROSS
Y = NUMBER 1 TO 4 [Master Code] is a 10 digit code, based on the phones IMEI number.
#pw+1234567890+1#
NOTE : These codes could be used with care. A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIM locked to one provider you can bypass the SP lock like this:
3: Press the "C" key.
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed
Jun 10, 2008 | Nokia 3110 Cellular Phone
How to set time and date
Function 7 then 1 push set 4 times diplay says ID push clear a few times(depends on how long number is)to remove then input new number and push set,then stop to get out of that.(This also where you set time date and company name) THIS IS FOR ALL PANASONIC FAX MACHINES.
Jul 24, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Cell Phones Logo
103 people viewed this question
Top Philips Cell Phones Experts
Vladimir Frolov
Tom Chichester
tosin_christ
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
