Question about Sony PlayStation Portable (PSP) Console
Need help on my psp
I'm trying to download some things from my computer onto my psp but it is not reading the usb do you know what could be wrong?
  • graceparks Aug 21, 2008
    i did that im still having trouble downloading the music to my psp
Yep.
connect your USB (psp to pc)
hold left on your psp go into settings. tap up.
click USB connection.
DONE!
Posted on Aug 18, 2008
How to download a games to a psp version 6.10
How to Download Games onto PSP- Step 1-
Your regular PSP games will come on disc, or UMD as they are known. When you download games onto PSP however, you are going to be putting them straight onto a memory stick/card. (Some people call them memory sticks, and some people say memory cards, but they are in fact the same thing.) The standard PSP memory card of 32mb is just not going to be big enough to download games onto, PSP owners should generally get the largest one they can afford. These days you can find fairly affordable 2 or 4 gig models on Ebay and Amazon quite easily. Once you have your new memory card, you will need to format it before use. This is basically like wiping the slate clean before use, so be sure to do it.
How to Download Games onto PSP-Step 2-
You will need to locate somewhere to download the games from. There are hundreds of places online that will allow you to download games onto PSP, but unfortunately they are not all reliable-if you go to the wrong places you will encounter many problems and can even find your computer riddled with spyware after. Not good! Be sure to choose a reputable site to download PSP games from-the most reliable ones are the ones that charge a small fee upfront and then give you access to unlimited downloads.
How to Download Games onto PSP-Step-3-
Once you begin downloading to your computer, be sure to only download files that end in "PSP" or have "PSP" in the title, as they are the only files compatible. You will occasionally find that the untrustworthy sites out there will try and give all kinds of files as downloads, so be sure to double check everything before you download it. When downloading the games I save them to a little folder on my desktop called "PSP Downloads, as it's simply the easiest place!
How to Download Games onto PSP-Step 4-
Now that you have a selection of games downloaded, you will need to transfer them from your PC onto the memory card of your PSP. This is pretty simple, all you will need is an ordinary USB cable to connect the two, and the PC should then identify the PSP as some form of removable drive, like a flashdrive or removable HD. All you need to do from here is to open up the PSP using the PC and drag and drop the required files onto the PSP memory stick, much as you would with any other removable drive. When you are doing this, be sure to send the files into folders called PSP, and then GAME on your memory card. If they don't exist you will need to create them, and I would recommend using all caps.
How to Download Games onto PSP-Step 6-
Once the transfer is finished you should be able to play the games on the PSP by simply opening up the GAME menu and selecting the games from the stick. Any errors or error messages are likely to be due to incompatible firmware-this is especially true if downloading homebrew games. You may find it necessary to downgrade your PSP in order to play these homebrew games.
Hopefully this guide has helped you see that it's not that tough at all to download games onto PSP once you get the hang of it, the real trick is finding a reliable download source!
I would suggest downloading PSP games using torrents. Just go to www.thepiratebay.org and search for PSP games. You'll need to have mutorrent or some other torrent software on your computer to download the torrents with. Follow the instructions once you have the downloaded game via a torrent and you'll be good to go. Good luck.
Mar 13, 2011 | Sony PlayStation Portable Slim Black...
How yo download psp games
First, you have to find the game you want, and download it to your computer.
  1. 1 Once the PSP games are downloaded, connect the PSP to your computer by using the USB cable that comes with the PSP console. Change your PSP console into PSP mode by pressing the "Home" button. Next scroll left to the "Setting" column and scroll down until "USB Connection". Press "X" button to enter PSP into USB mode.
  2. 2 To download the PSP games into your console, the games must be copied and downloaded onto the correct folder in order for the games to work. And the correct path is PSP > GAME in order for the any PSP games to work correctly. If the "PSP" and "GAME" folder does not exist on your PSP memory stick, you need to manually create the folder with folder name in ALL CAPS.
  3. 3 Once you have finished downloading or transferring the games onto the PSP memory stick, you can disconnect your PSP from the computer. From the PSP console main menu, scroll over to the "GAME" column on your Sony PSP and continue to scroll down on the memory stick. Press "X" and a list of game files will be displayed. Scroll downward and you will be able to see the games you have just installed.
  4. 4 Press "X" again to confirm your selection and play the PSP games. I had tried to practice the steps above many times in my PSP and it worked all the time. Hopefully it will also work for your console too.
Hopefully, this works for you!
Feb 08, 2011 | Sony PlayStation Portable (PSP) Console
How can we download psp games now
these are the steps you will use to download a game on your psp.
step 1
step 2
step 3
step 4
step 5
Please rate my solution.
Thanks
Jun 26, 2010 | Sony PlayStation Portable (PSP) Console
How do u download psp games
to learn how to download psp games, follows the steps below and you won't have any problems:
  1. Download desired game from an Internet game site onto your computer.
  2. Connect the PSP to the computer using the USB cable. The memory stick needs to be in the console at the time of connection.
  3. Copy the downloaded game files into the PSP game path on the removable drive. This puts the downloaded game onto the PSP memory stick.
  4. Disconnect the PSP from the computer once the game has been fully transferred.
  5. Look in the PSP main menu from the game folder. Scroll to "Game" and select the memory stick option. Press the "X" button to display the list of available games.
  6. Select the downloaded game and begin playing.
I hope this would be of help to you.
Take care.
Jun 07, 2010 | Sony PlayStation Portable (PSP) Console
How do I download music onto my Psp 300?
Please try the following:
  1. Step 1 First, add connect your PSP with your computer using your USB, but you have to go to "settings" and click on "USB connection"
  2. Step 2 When your PSP is connected to your computer, a hard drive will appear [for example: hard drive (F:)]. That hard drive is for your PSP
  3. Step 3 Click on that hard drive and make a folder called "music"
  4. Step 4 Finally, open your folder full of musics and drag musics you like in the the "music" folder
  5. Step 5 Finally, when you disconnect your PSP with your computer, go to "Music" on your PSP and listen to your favorite songs!
Hope it helped.
Nov 22, 2009 | Sony PSP-3000 Black Console
Downloading
Do you have a usb cable to connect the psp to the computer? If you son't the it's useless trying. And if you do, when you connect it to your computer it should appear as a removable disk. Just double click and put the music in the music folder and the videos in the video folder.
Hope this helps.
May 08, 2009 | Sony PSP (Piano Black)
Sony psp
On your computer go to the start menu look at the top and it should say documents, pictures ,music, and my computer click my computer whatever drive your psp is on click it on the right side of your mouse and click explore double click folder that has psp and there are the folders that you download things onto.
Apr 03, 2009 | Sony PSP (Piano Black)
PSP USB connection- screen reads please wait
there might be somthing wrong with the hard drive or with the usb
Mar 31, 2009 | Sony PlayStation Portable (PSP) Console
Internet videos
I don't think you can directly play movies from your web browser. Maybe if you have the latest firmware it will work.( i think the latest is around 3.80) If you want to add movies from the internet and SAVE them onto your PSP, then follow these steps:
1. Download Firefox if you don't have it
2. Goto the page with the movie you want
3. Goto File in the top left corner
4. Select Save Page as
5. Save it anywhere you want
6. Connect your PSP to your USB, and enter USB mode with it
7. Read the following/download the converter
http://www.pspconverter.com/how-to-convert-video-files-to-psp-video-mp4-with-psp-video-converter.html
For flash/java games, read the following:
http://www.wikihow.com/Put-Flash-Games-on-Your-PSP
May 29, 2008 | Sony PlayStation Portable (PSP) Console
Downloading music from computer
easy. plug in the USB cable into your PSP and the other (big) end into your computer. on the PSP home menu, go all the way to the right and select USB mode. YOU NEED A MEMORY CARD INSERTED. click open and explore files if somthing pops up on your computer. if not, go to my computer, then memory stick K (or what ever letter your compute shows). then if its not already there, make a new folder and call it MUSIC
then drag and drop / copy and paste your songs into that folder.
Nov 18, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
Jonathon summesfield
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
