Question about Canon PIXMA iP5000 InkJet Photo Printer
Paper wont feed in and get bunched up - Canon PIXMA iP5000 InkJet Photo Printer
  • Canon Master
  • 739 Answers
Hi Dianne
When paper bunches up it generally means there is an obstruction in the way - after the paper has gone into the rollers.
Sometimes it's as simple as a bit of debirs or even a pin off the pinboard has fallen in. However. a couple of instances have been that in the platen (the bit the paper passes over while the ink is being quirted) there is a strip of oddly cut sponge foam - and this foam as somehow come out of its seating and is getting in the way.
Open the printer as if you are going to replace the inks but take the whole print-head out. (take the inks out first then the print head) Then look at the metal plate and you'll see the foam. Is it dirty? is it wrinkled? is it sitting fluch with the surrounding surface?
Carefully remove it with tweezers (or rubber gloves) and give it a good wash in warm water until the water runs fairly clear.
With a damp piece of paper-towel, clean off the metal plate and the recess where the foam came from. When you are happy that it's clean squeeze the foam between some clean paper towel to remove as much water as possible and then carefully fit it back into the recess. - it's a bit fiddly but it will only go in one way round so you can't get it wrong.
Refit the print-head and the inks and see if matters have improved..
If they haven't then you will need to locate your nearest Canon centre.
Posted on May 25, 2011
2 Suggested Answers
gildonps
  • 28 Answers
SOURCE: Printer wont feed paper on one side
This may sound strange, but it works more often than not. Try unplugging it, turning it upside down and shaking it vigorously. Also, take some canned air and spray into where it feeds the paper. Just be careful not to spray into the ink-head.
Posted on Mar 06, 2008
Copier will not copy feed paper oeven try-justs makes agrinding noise
Dear
Pl. do test as per following.
1- empty paper tray.
2- pull the toner cart. and close the door.
3- power ON the printer. Listen the sound of initial motor run,
(If smooth not grinding noise, check the toner cart OPC drum for jam. If yes check the fusser drive gear and fusser gear and assembly)
If all are ok.
4- Check the paper pick up roller shaft, (sometimes it takes a bunch of paper and jammed if you forcible pull the bunch in reverse direction the shaft may gets bend cause the grinding noise during paper pickup. in that case you have to replace the paper pickup shaft.
Thanks.
Mar 10, 2015 | Samsung SCX 4521F All-In-One Laser Printer
My dell 2350 dn feeds to much paper causing jam
Step 1: Try fanning the paper at the feed edge before placing it in.
Step 2: Ensure that the paper is placed in with the edge curl up. When holding a bunch of paper between two fingers, the paper will naturally have a curl to it. It should be placed in "happy" (Edges up).
Step 3: Inside the printer's paper tray and where the feed mechanism is, locate the feed rollers and static feed pad. These will all be rubbery or "foam"-like. They should always be slightly tacky when rubbed against, however paper dust will eventually cause them to become slippery instead. Rubbing alcohol can be used to clean them with care and a Q-tip and recover the slightly rubbery, tacky feeling, thus resolving misfeeds.
Mar 28, 2014 | Generic Laser Compatible Dell 2330 2350...
Paper won't feed in Victor 1460-3. Calculator works fine otherwise.
There appears to be something in the way as the paper bunches up when I start to feed it through.
Is there some way of taking the back off this calculator?
Aug 17, 2011 | Victor 1460-3 Calculator
Paper not feeding correctly
try to clean the carriage and see if a Q-TIP will reach the feed rollers. They probably still have some ink still on them.
Jul 31, 2009 | Lexmark X5470 All-In-One InkJet Printer
IN MX-M350N SHOWS "REMOVE PAPER FROM TOP TRAY" AND DOESN'T PRINT
You probably have a paper jam in the auto feed unit. Open the auto feed and check for bunched up paper and if you don't find any open the side doors and check for paper jams there. Let me know what you find.
Feb 13, 2009 | Sharp AL 1631 Copier
Paper pulls to right and bunches up when loading
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Dec 31, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Mp600 pixma printer
I'm not sure if you've already checked this, but this was my issue. I, too, would try to print something and it would make a great deal of clunking noise but would then say that there was no paper and told me to load some. I went to the Canon site and before I actually went through the process of cleaning the print roller, I checked the feed switch button on the display panel. It's right below the ON/OFF button and, what do you know, it was set to feed from a paper cassette instead of the back loading tray. I pushed the button and it's now printing fine. I'm sure we must have accidentally hit the button when we were trying to turn the printer on or off quickly. Hope this does the trick! It's always nice when it's something easily fixed!
Aug 30, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper wont feed , keeps going in crooked
why do we the consumer have to submit the solution??? Where is Cannon after we purchased their product? This is total incompetency on their part!
May 01, 2008 | Office Equipment & Supplies
Mar 06, 2008 | HP PSC 1610 All-In-One InkJet Printer
Canon PIXMA iP5000 InkJet Photo Printer Logo
102 people viewed this question
old marine
old marine
