Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
I have 230V AC units and a 110V Condensate pumps can I hook up a power feed from anything inside or around the unit? A 110V wall socket mains feed is not close by.
    Sergeant:
    Champion:
  • 229 Answers
Just return the condesation pump and get a 208/230 V one. Thats the only 100% correct way to do that. I know people in the field who have tapped off one leg of 230 v and run neutral to the casing and the unit will work but it isnt recommended. Your not supposed to run a current carrying conductor to the casing but its up to you. If this helps please rate me and do a testimonial.
Posted on May 25, 2011
    Guru:
  • 683 Answers
If your 220 volt circuit has a netural in it, YES, you can. They do make 220volt ac condensate pumps. Hope this helps.
  • Walter Kunesky
    Walter Kunesky May 25, 2011
    In the recommendation that I said was because If there is a netural in your circuit then yes again you could have doed it. The reason that I didnt say, netural to ground is because this is not safe. I did not say netural to casing anywhere is my solution because this is not code and also because if you have a short in the pump and someone is tounching any metal in the system weather it be inside or outside they will feel the voltage and possibaly hurt them. I dont need a testimonal because I have 30 years in the field of doing this. Hope this helps.
Can 110 volt motor work with intermatic t104r
YES ,BUT YOU MUST LOOK AT THE MOTOR ON THE TIMER , IF IT IS A WG1570 IT WILL WORK ON 110V IF IT IS A WG1573 YOU WILL NEED TO FEED THE TIMER 230V AND IT WILL SWITCH YOUR 110 VOLT MOTOR. WARNING ONLY USE ONE LINE IS YOU HOOK UP 2 YOU WILL BE RUNNING YOUR 110 MOTOR ON 230, JUST NOT FOR LONG. CUZ YOU WILL SMOKE IT !.. THERE IS NO WAY TO USE THE WG1573TIMER MOTOR ON 110V NOT GOING TO WORK !
Jun 02, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
MMP2 seems to have no voltage selector. Manual states power as 230, 240, 110v. I am reluctant to plug my US 110v unit into UK 230v mains. Would appreciate any info?
Check the manual..It's on the Roland site
In that unit , it's most likely an auto-switching power supply ie; universal 105 - 230 volts AC 50-60 hz
Aug 07, 2010 | Roland MMP-2 2-Channel Amplifier
Have a Plantronics Cordless phone with the supplied Power Charger (input 110v, output DC9v.500mA.)using in UK with 230v/110v step down transformer, works perfectly. Then, like an idiot decided to use a...
You may have FAILED to check that the polarity matched. Some have the pinpositive, the other the sleeve.
It is UNLIKELY that muchwas damaged beyond the power regulator in the base unit. Should be relatively inexpensive repair.
Dec 26, 2009 | Hitachi 12v 3/8" Driver Drill Kit with...
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
When the ac unit is on the water comes in the house
The condensate drain line is clogged, causing the condensation water to overflow. You can use a shop vac to clear the line. attatch it to the outlet side of the line. also clean out the condensate drain pan located at the bottom of the indoor coil.
Sep 25, 2009 | Amana MH09A3PA235 Comfort Zone Room Air...
A\\VOL Model ALTD1902M - Where to Find Power Cable?
POWER: AC 100V-240V at 50/60 Hertz means that your unit has a switching power supply built in which will operate on ANY AC (alternating current) voltage from 100V up to 240V, on either 50 or 60 hertz frequency.
(110V @ 60 Hertz is an USA wall outlet power standard, whereas 220V @ 50 Hertz is the European wall outlet power standard)
So, you can actually use it with just about any line voltage from a standard home wall power outlet, you just need the correct power cable that fits into your unit on one side and into the wall socket on the other.
The 60W power rating is just telling you how much power the unit consumes for operation which means that if you hook it to a 110V power line (USA), it will draw a current of approximately 0,54 amperes (60 watts divided by 110 volts equals to 0,54545 amperes) and if you hook it to a 230V power line (Europe), it will draw a current of approximately 0,26 amperes (60 watts divided by 230 volts equals to 0,26086 amperes).
The switching power supply in the unit has an internal fuse which is rated somewhat above the 0,54 amperes, could be a 0,63 amperes, but most probably it is rated at about 1 ampere or more.
If the specs you listed are correct, you only need to worry about the correct power cable that will fit into your wall socket on one side and into the combo unit on the other.
Hopefully, if the unit is in good health, you haven't wasted your money after all.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Televison & Video
Maytag Dishwasher MDBH965AW will not power.
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replace
If the junction box checks out ok, the wall outlet socket is live, replace the main control or timer module.
Jun 19, 2009 | Maytag 24 in. MDBH965AW Built-in...
Sub woofer
It is possible, but very rare that I have seen this, the unit's AC plug is not making good contact in to the wall socket. The extension cord's AC plug may be making better contact to the wall socket, and the socket on the extension cord is making better contact to the unit's AC plug. It could be something this simple.
In my mind however, I sort of think that there is a very intermittent fault, and it does not show up too easily. Sometimes moving a device can disturb it in such a way that its fault may not show up (fault gets to be masked). The fault may come back to haunt you. Time will tell which scenario is the right one.
Jerry G.
Jul 07, 2008 | Panasonic SC-PT1050 System
18v. charger (dewalt)
I did a little hunting and it seems you really want to use your 110v charger on a 230v supply.....
So you could use a transformer (LINK)
or you could get a local power supply pack.
Read the label on back of power pack that attach's to wall socket and charger base, see what input it can handle, some gear can handle like 110v-230v, others cant ie will read 120v
Any adaptor that puts out the same output as the original would work ie 18v DC 2.5 amps is your specs i beleive so use a transformer or another suitable adaptor
Please check my quoted specs are the same as listed on power pack of your charge ie I am assuming you are using your 110v A.C. to 18v 2.5amp D.C power pack
Jan 30, 2008 | Dewalt 7.2-18.0 Volt One Hour Charger
Change 120v chager to run on 240v
all you needs is a step tranformer from 110v to 220v ac
Nov 13, 2007 | Dewalt 7.2-18.0 Volt One Hour Charger
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
292 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
