Question about LG Dehumidifiers
Unit will do a small of amount of dehumidifing however the unit gets very hot on top and blows very hot air out of rear. Could this be a lack of freon or whatever is used and comprssor getting hot??? THANKS Skip
  • LG Master
  • 43,501 Answers
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
My dehumidifer runs but no water is being pulled out
Might be a dirty coil and condenser.
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. If it actually still runs, I would suggest you take off covers and give the coils a good thorough cleaning. Otherwise the units are not designed to be serviceable aka - "disposable small appliance". if you do dispose of it take it to a qualified recycle organization for Freon products. Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
WHIRLPOOL DEHUMIDIFIER Parts Model ad75ust0 Sears PartsDirect
Apr 18, 2013 | Whirlpool 75-Pint Dehumidifier
Tip
Dehumidifier is Freezing up and not working
If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degrees and you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
Many dehumidifiers will shut off when the coil starts to freeze to let them thaw, then they will restart when the coil is warm enough again. This can take an hour or so. Some will not shut down the compressor and when the dehumidifier coil starts to freeze it reduces the air flow and only compounds the problem.
Check the air flow over the coil. If the coil becomes dirty or the fan motor stops or even slows down a bit, you will get freezing. The dehumidifier is very dependent upon the proper amount of air going over the coil to keep the coil warm enough to not freeze. Any restriction will cause problems.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in the refrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
Some things that you can do to help out a dehumidifier that is freezing up are:
Raise the temperature of the room and provide a bit of heat for the room as the dehumidifier is actually a very small A/C unit.
Raise the dehumidifier up off of the floor… the air is usually warmer when you go higher up in the room, hot air rises.
Clean the coils off so that the air can flow through them easier and keep them warmer.
Make sure that the fan motor bearings are oiled and that the fan is running freely. Even a tiny bit of resistance will slow the fan enough to make a difference.
By checking all these things out and making some small changes you maybe able to make your dehumidifier work much more effectively.
http://www.fixya.com/support/r3877515-dehumidifier_problems_dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
http://www.fixya.com/support/r4688381-dehumidifier_problem_shows_bucket_full
on Apr 30, 2010 | Dehumidifiers
The dehumidifier is getting cold condensation on the top outside of the unit and no water in the bucket. Model BGD-510A. I cleaned the filter and the coils and still have this problem.
Kathryn, if you are operating it in a basement application, the problem is that air temperature at floor level, is colder than at shoulder level. Dehumidifiers struggle to work at temperatures between 40 & 65 degrees F (Unless they are Low Temp model designed for basement applications). And will ice up at times. Raising the unit up off the floor onto a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
If it's not a basement application, try lowering the humidity extraction level to 35%. In you have an analog unit, turn the control knob to Maximum.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Dehumidifiers
Can't get our dehumidifer to run. It show all the numbers but doesn't want to run to plull humidity out of the air.Can't find my manual book so we know what to have numbers at. Can you send me...
Bonnie, there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications . Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
Hope this helped you tho troubleshoot and solve the problem. Please let me know. Thanks.
Jul 09, 2011 | Haier HD308 Dehumidifier
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
Goldstar Dehumidiflier coil freezes
Hi, If you are having problems with your dehumidifier freezing up them here are a few things that you can check and also a few things that may help you.
First check the ambient temperature of the room at the level of the dehumidifier. If it is below 65 degreesand you do not have a special low temperature dehumidifier then you are asking for trouble. Most units are only designed to work in temperature 65 or higher and will freeze if they are working at lower temperatures. Some even will not work well below 68 degrees F.
The final and worst thing that can happen is for your dehumidification unit is to develop a slight leak in therefrigeration system. This will cause the coils to run even colder then they would normally and this will create the same problems. If everything else check out then you may have to have the refrigeration system checked by a professional. The problem with this is that many of these units only cost a few hundred dollars and a service call can soon add up to more then the unit is worth.
By checking all these things out and making some small changes you maybe able to make yourdehumidifier work much more effectively.
Aug 11, 2010 | Goldstar DH504EL Dehumidifier
Dehumidifer stopped collecting moisture, blows air w/ empty tank
Possible cause it's out of gas.
you might have to get a refridgeration mechanic to regas it, or/and fix any gas leaks
Apr 02, 2009 | Maytag M3DH30B2A Dehumidifier
Danby Dehumidifier Model # DDR557HE Serial # 0107030704369 --Does not collect water and cxontinues to frost up
Take care
Mar 23, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Unit runs but no water in storage tank
Make sure conditions are not too cold or too dry already.
Is the compressor running?
Set the unit to the continuous run setting or the dryest setting
compressor should start.
If compressor runs but the evaporator doesn't get cold the freon has
leaked out.
If compressor doesn't run no matter what you do the board may be bad.
Also the fan must blow air.
Sep 30, 2008 | LG DH30 GoldStar Dehumidifier
Humidifier is very hot
doubt if there is a fault. if something gets cold ie freezing section then something else gets hot
Mar 18, 2007 | Fedders RDG40 Dehumidifier
Dehumidifiers Logo
124 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
