Question about Price Pfister Home
Dripping shower facuet - Price Pfister Home
    Brigadier General:
  • 3,301 Answers
Replace the diverter valve washer and seat
Posted on May 25, 2011
I have a moen caldwell 82495brb facuet shower. I am trying to install and all is fine except when i turn the hot water back on, i can't turn the facuet off. Am i doing anything wrong on the install...
Does it turn off when you push on it, put pressure on it. Make sure the handle is not interfering with the escutcheon. Does the handle keep turning all the way around? You may have not installed the stop or posi-temp gear.
Apr 21, 2011 | Moen Home
How do u take the knobb off on a moen 2353 chateau facuet
Check for a removable center cap to access the screw or look under the handle for allen wrench screws.
Mar 17, 2011 | Moen & One Handle Tub & Shower Faucet
The pipe that has shower head does not fit tightly into the facuet; I am installing a new facut with a hand shower and a shower head system
Try screwing it in opposite of normal threading. Left to tight not right to tight. Usually with anything liquid especially water connections threading is opposite.
Mar 05, 2011 | Franklin Decor Bathware Shower Rod
We are installing a new moew tub facuet and shower and need to know where it says to use copper pipe if this is required because our pipes are cpvc thank you ruth
To the best of my knowledge it doesn't matter what type of pipe you use. Just make sure you install valve in the right position. Thanks
Nov 02, 2010 | Moen & Replacement Cartridge
Price Pfister tub/shower facuet needs much force turn on and off
put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Jul 04, 2010 | Price Pfister 07-81PC Savannah 2 Handle...
Hi my delta single hanlde tub/shower facuet is leaking hot water bad
If its a ceramic cartridge type then replacing cartridge is called for, HOWEVER sometimes cheaper to replace complete tap.
If not ceramic then turn mains off and replace the washer inside.
Jan 08, 2010 | Delta Classic, Single Clear Knob Handle...
A single handle delta shower control lets water drip through shower head when shut off......how do I fix it ?
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Sep 25, 2009 | Delta & Single Handle Shower Faucet
Bath tub water doesn't stay hot
it is because the tub has a temp control valve in it so if you were to put more cold with the hot it will last longer but still won't be all the way hot,, now a days people are suing the manifacture because they are getting burned form the hot water so they put these saftey temp controls in place of the old style 2 or 3 handle faucets,, there fo no more real hot water nothing you can do outside of change to the othere type of faucet 2 or 3 handle tub shower diverter,, that why the water is hot in the sink but not the tub.....
Jun 23, 2009 | Water Heaters
Single handle facuet for shower/tub leaks hot water
change the cartridge it is bad,it has rubber gaskets on the outside of the cartridge it is worn,just replace it and it should work,it may also be trash in the way.take out and shake,if this does not work replace with new cartridge.
Jun 07, 2009 | Moen & One Handle Tub & Shower Faucet
Home Logo
143 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
