Need to replace duracraft cz-600 double rocker switch. Where can i purchase one?
4 Suggested Answers
  • 17 Answers
SOURCE: Owner left a Duracraft air
Just plug it in. Water is not what is inside of unit, Oil is inside. Put the dial at the amount of heat that you are wanting to come out. Very simple poroduct to use. I have owned my unit for over 10 years now.
Posted on Dec 05, 2010
shastalaker7
  • 1515 Answers
SOURCE: duracraft cz600 double rocker off
Hi Mr. Coy, on a switch like this you might need to try a place like Granger's supply. You can look it up to see where the nearest one to you might be. You can also try any appliance parts house to. I don't know if Home Depot would carry this, you can check.Most Electrical supply houses are wholesale only, but I have walked in and when they ask who or what job it is for, just give them your name. They just want to put something down on your invoice, and tell them you will pay cash as you have in the past. This works. I hope this has been of help to you and you find one.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Dec 30, 2010
jcameo7270
  • 675 Answers
SOURCE: The electric cord on our
Look carefully at the plug's connectors to see if thewre is any scorching or otherwise burnt metal...electrical connectors tend to get hot due to the plug being loose(this causes more resistance and thus more heating). As a safe bet...the parts aren't expensive...I would replace both the power cord on the heater AND the outlet recepticle
Posted on Jan 17, 2011
The electric cord on our Duracraft heater model CZ-600 was very hot to the touch (closest to the plug) -- it burned so hot we could not touch it for more than a second. The heat was at maximum and we...
Jan 17, 2011 | Heating & Cooling
Duracraft cz600 double rocker off and on switch we are unable to locate one please advise where we can get one. Thank you Gilbert Coy
Sincerely,
Shastalaker7
Dec 30, 2010 | Heating & Cooling
Dual receptacles (hot all the time) next to dual rocker switches. One switch controls a light, the other a disposal. I've got three black and one white wire ( ground). The post set up on the rockers...
What are you doing? I can't figure it out.
I think you have a new double rocker switch and you are trying to replace a double toggle switch and you don't know which side to put your wires?
The screws are color coded. Look at the screw colors on old and new switches and follow same pattern.
If this is incorrect, answer back and I will help.
If you are adding another circuit.
That means running a new wire into the box to power another receptacle box, or to switch another light fixture.
If this is the case, the best place to connect any new circuit is the existing receptacle.
Connect new black wire to brass colored screw
Connect new white wire to silver colored screw.
Oct 25, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
Owner left a Duracraft air heater in home, model CZ 600. I am not familiar with it, and need instructions on how to use it. Does it require water, or can I just plug it in?
Sep 06, 2010 | Heating & Cooling
The rocker switch on the touchpad is not working and i can't seem to find how to set it.
The Rocker Switch is not active by default. You will first need to assign and action to it for it to function. To assign and action to the rocker switch do the following:
  • Go into the Control panel (Click Start -> Control Panel in Windows XP)
  • If you have not already then you will need to change your control panel view to "Classic View".
  • In the Control Panel list, double click on MOUSE.
  • While in the Mouse Properties click on the 'Advanced Features Tab"
  • Click on 'Settings"
  • To set the Rocker Switch click on the + by 'Button' and choose to action you would like to assign to the Rocker Switch.
  • Click OK
Dec 30, 2009 | Gateway 450ROG Notebook
I received a Duracraft model CZ-600 oil Heater. I don't know
I'm in the same boat..are we the only ones who have one?
Nov 22, 2009 | Duracraft DY-012 Tower Fan
Lutron Maestro dimmer rocker stopped working
Because the switches are relatively inexpensive, there aren't kits to repair them when they fail mechanically. Your best bet is to get an exact replacement from a Home Depot or such, turn off the breaker switch, and rewire it exactly as it was, using wire nuts and tape.
Oct 27, 2009 | Lutron Maestro 600-Watt Multi-location...
Both togggle switches are broken
Go to the hardware store and match them up, they have toggle switch. Get the heavy duty 20 amp switch.
Oct 03, 2009 | Heating & Cooling
Rocker switch for 600 watts broken----
First of all complaining to FixYa isn't going to accomplish anything. I doubt that the supplier of your device even knows about FixYa. Now on to your problem --- can you get me any numbers off the rocker switch? I'll do the research and get back to you. Use my original email address which can be found in my profile.
Dec 01, 2007 | Lakewood Oil-Filled Electric Radiator...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
