Question about Samsung HCM4216W 42" Rear Projection Television
Have samsung hcm4216 w/ model code hcm4216wx/xaa that has convergence problemn would like to know correct current complete convergence board part and where i could purchase( I need to simply be able to replace entire component no soldering etc.
  • Samsung Master
  • 3,459 Answers
Try Partsstore.com for a whole board...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
have samsung hcm4216 w/ model - 7859b01.jpg
SOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that nehave samsung hcm4216 w/ model - 578ba6c.jpgid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 02, 2011
I use Ubuntu 10.04 and I want to install my printer Samsung SCX-4623F. What do I have to do? Thank You. Eros.
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
Dec 25, 2010 | Samsung SCX4623F Laser All-in-One Printer
Samsung hcn4226wx/xaa red color out of focus
Ok first of all, the convergence board you are looking for is no longer available from Samsung, probably because of the large failure these boards are having. The only thing to do though would be to replace the convergence amp IC's on the convergence amp board. this will involve locating the convergence amp board, going to http://www.samsungparts.com, entering your model number, without the /xaa prefix. Locating the list of parts for this TV set, and getting the right convergence amp IC's for this TV set. The numbers for the convergence amps are STK-392-040. You will also need to get the service manual for this TV set to perform touchup convergence, as well as to realighn the magic focus into the memory of this TV set. If you have the ability to solder and unsolder, you should have no problem replacing thes convergence amp IC's. But i will have to say this, about 45% of these TV sets do still have a problem after the convergence IC's are replaced. this is usually due to the burnt ground return resustors on the convergence board, so be perpared to know how to read a scematic diagram in the service manual and to trouble shoot the board. There is no simple repair to this problem I'm afraid, with this Samsung TV set. But , if at any time, you feel lost in the repair of this set, do not continue, and call out a pro to assist you in the repair of this TV set. Good Luck with the repair of this TV set.
Jun 26, 2007 | Samsung HCN4226W 42" Rear Projection...
Another Question Please.
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
I have a Samsung HDTV. Model Code HLR4667WAX/XAA,
IT'S YOUR DMD MODULE IT'S PART OF LIGHT ENGINE IN THIS PATICULAR MODEL WHEN THAT GOES BAD YOU HAVE TO REPLACE WHOLE LIGHT ENGINE CONTACT DISCOUNT MERCHANT OR RIVER VALLEY ELECTRONICS THEY HAVE THEN FOR PRETTY CHEAP.
Jun 24, 2009 | Samsung Televison & Video
I was just given a samsung hcp4752wx/xaa. The
OK, Its always best to replace the lens assembly if its not preforming well. never dump the fluid. just replace the lens. As for the double images and the misalignment of the blue convergence line, this is caused by a faulty convergence chip that is located on the convergence board. you will need to replace this board in order to restore proper convergence performance.
May 16, 2009 | Samsung Televison & Video
Samsung model#PCN5425RX/XAA, picture looks like a 3d movie without the glasses. I can replace the board myself but want to make sure I order the right one. The board I think I need is part#...
Save yourself some money. The typical parts are the convergence ICs. Replacing the ICs will retain the particular adjustment values for your set and avoid a complete convergence adjustment. Look for the large black ICs on the board. They should be STKxxx. Try resoldering the pins first. If that fails to resolve the problem, replace the ICs being sure to use plenty of heatsink compound between the ICs and the heatsink.
Keep us posted.
Dan
May 12, 2008 | Televison & Video
Samsung HCN4226W blue color outlines
Samsung parts for convergance problem
http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
This convergence board works with the following Samsung television models: HCM4215W, HCN529WX, HCN559WX/XAA, PCN5425R, HCN4226WX, HCN529WX/XA
Mar 10, 2008 | Samsung HCN4226W 42" Rear Projection...
Samsung hcm4216 rear projection
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Aug 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
69 people viewed this question
Jerry Greenberg
Jerry Greenberg
