Question about Blakeslee F-30-CA Stand Mixer
Im looking for a dough hook for a blakeslee f-30 at a reasonable price. will hooks from other brands fit?
bigg t
  • 640 Answers
SOURCE: Blakeslee CC-30 Planetary Mixer & dough hook not mixing correctly
it sounds like you may have a sheared key on one of the shafts.with no product in the mixer will it run in any other speeds?when mixing pizza dough you should only use 1st gear.if it does run in other speeds you have a sheared key or broken shaft,if it doesnt run in any speeds drop the planetary and check the key on that shaft.
Posted on Jan 05, 2008
SOURCE: viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Posted on Mar 09, 2008
SOURCE: dough hook
if you r using it for dough use the roller and scraper it works much better. But if u want to use the dough hook the holes in the middle is where the knob and stick in the arm go into to hold the hook inplace and it also goes in the hole on the side near the scraper hope this helps
Posted on Apr 17, 2009
  • 145 Answers
SOURCE: KitchenAid 600, Stand Mixer -
If the beater is grinding when it meets resistance, it generally indicates that an internal gear has broken or been stripped.
With the Professional 600 stand mixer, up to 14 cups of white flour or only 8 cups of any flour are recommended at one time. Speed 2 is the only speed that should be used for bread dough and it should never be kneaded for longer than 7 minutes. Failure to do any of these things make cause problems for the mixer motor.
If you are interested in self-repair, I recommend mendingshed.com. They have internal parts available to order and also have a .pdf file for the Kitchenaid Mixer Service Manual.
If you are interested in a repair facility, please visit the following link:
http://caservice.kitchenaid.com/
This is a listing of certified repair locations.
Also, if the mixer is less than a year old, Kitchenaid may replace it under their 1 Year Manufacturer's Warranty. I would recommend calling their customer service. Their toll-free telephone number is:
1.800.541.6390
Posted on Jul 16, 2009
Cuisinexpert
  • 61 Answers
SOURCE: Model 62300 - are flat bears or dough hooks available?
You probably can--but you might have to contact the manufacturer. Most retail stores will not sell parts like this (and if they do, it's probably a store that will be something like a kitchen specialty store--aka, a little more pricey), so the best way to go is to contact them directly so that they can get it for you (and, a lot of times, they can get it for you at a cheaper price, or, if you're under warranty, and the beaters/dough hooks have broken, sometimes for FREE!!).
Their contact number should be either stamped somewhere on the mixer (usually on the bottom--might be stamped directly into the plastic, so make sure you have it in really good light when trying to read) or in the product manual (usually near the back of the book). If you still can't find it, you can usually just do a quick internet search (just typing in the manufacturer name--in this case, "Hamilton Beach"--and then "support" into Google usually helps).
Good luck! :)
Posted on Aug 22, 2009
Beater is stuck
I had this happen on my Kitchen Aid mixer. There is probably a build up of dough/cake mix etc inside the hole where the beater fits into. Fill a mixing bowl or a jug deep enough to fit over beater with very hot or boiling water. Immerse the stuck beater in the water up to where it connects in to the mixer and hold for about minute. Once the hot water has melted the build up you should be able to remove the beater. Hopefully this may work on your brand of mixer.
Apr 14, 2014 | Blakeslee DD-60 Stand Mixer
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
I have a blakeslee cc15 i need a hook .is there any part for this mixer
Hi and welcome to fixYa, I am Kelly
This is the US support site for Blakeslee.
http://www.hfse.com/GetYourPart.html
Call 800-458-5593 or Fax 800-800-4981
They also have a Canadian site.
The link below has a live chat feature where you can ask if they carry parts for the CC15 model:
http://www.hfse.com
Hopefully this will get you a source for your hook.
Thanks for choosing FixYa,
Kelly
Feb 23, 2011 | Blakeslee F-20-CA Stand Mixer
Will hobart 20qt hook fix on a blakeslee 20 qt mixer.
as long as the shafts are the same o.d.and the bayonet pin are the same diminsions you should be ok
Dec 09, 2009 | Blakeslee F-30-CA Stand Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Is there a dipstick for the oil?
Google northernparts.com they can help you out.
Jul 29, 2008 | Blakeslee F-20-CA Stand Mixer
Dough hook
May 30, 2008 | Magic Mill DLX 2000 Stand Mixer
Jan 05, 2008 | Food Mixers
Blakeslee F-30-CA Stand Mixer Logo
55 people viewed this question
Top Blakeslee Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Blakeslee Food Mixer Expert? Answer questions, earn points and help others
