I do not have the original remote control. It is connected to cable but I am only getting a small percentage of the stations I should be getting. Even though it is not HD, there are a number of channels I should be getting.
  • 517 Answers
Good day!
If you don't have a original remote please use universal remote and go to the menu and find the auto scan and enter it to access all of the stations.
Thank you
Posted on May 25, 2011
My tv just went off all at once to nothing it just looks like snow on it thats it and we have it hooked up to cable and was viewing it at the time
snow is an indication of signal failure either from the station or an antenna connection problem
if it all channels then I would be looking at the cable connection at the cable box or outside antenna connections
Mar 03, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
How do I prevent my Samsung ln46C600F3FXZA from locking up?
It might be due to an older firmware version. Maybe contact Samsung and see if there is a new firmware upgrade. Many times these little updates make it all right again.
Jun 30, 2014 | Samsung Used Original LN46C600F3FXZA...
Hi, A friend gave me this particular tv, I had cable put in my room and i connected it to the unit I'm only getting 4 tv stations my problem is There is no remote Does this tv come with a remote so i...
You will find the name on the set is not the company who made the set---you need an original remote to change the set from the AIR band to the CABLE BAND and to then autoprogram the channels in the menu.
A universal is a WASTE of time and money as it will be minus many key features needed to operate the set.
GOOGLE the model number and search for "original remote"
DO NOT BUY A UNIVERSAL REMOTE.
Aug 13, 2011 | Curtis CMC13101 Combo
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
I have lost my remote
Original and replacement remotes: www.remotes.lt
Sep 07, 2009 | Televison & Video
Not receiving my local cable stations
You need to make sure the TV is set for "cable" tuning and not "standard" or "air." (If you are getting only local off-air channels and no cable stations at all, be sure you have a good cable and connection to the set. Normally, even if the TV is set for "air" you will get the low-number cable channels 2-13.) This is usually a selection through the TV's set-up menu. With a universal remote, it may be difficult or even impossible to get to all the menu entries. Most replacement remotes don't support all the original remote functions. Try with yours and good luck. Once you get the TV set to the proper tuning, you should have all your cable channels.
Jan 03, 2009 | Durabrand BH1304D 13" TV
Hotel TV remote
for phillips tvs that come out of a hotel try this code with RCA universal remote. the big remote not a small remote. 319753 followed immediately by the mute button. this will pull up the tv setup menu.
Jul 31, 2008 | Philips Magnavox REM-350 Remote Control
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
Television will not air all cable stations
If when you turn it on it starts to run through the stations let it go and finish.
Nov 18, 2007 | Sylvania 6719DF 19" TV/VCR/DVD
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
