Question about Samsung Convoy Cell Phone
Samsung Convey front display backlight stays on all the time
Samsung LED backlighting turns off
The only cure for this is to get it repaired and stop smacking on it before you do some real damage.
Jan 24, 2013 | Samsung NP300E4C-A02US Laptop
The screen goes blank when you want to make a call and sometimes it hangs
Check out this link below to download a PDF manual for your phone. Just copy and paste into your browser.
http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/SGH-D880-_E
From page 35 in your manual:
Light settings → Backlight time
Select the length of time the backlight or display stays on when the phone is not used.
From page 5 in your manual:
To access Menu mode, press <Menu> in Idle mode.
# Settings
3 Light settings
If all fails you can call Samsung at 1-800-726-7864.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung D880 Cellular Phone
Motorola Razr V3a Backlight Stays On
From the manual, p. 31:
"BACKLIGHT
Set the amount of time that the display and
keypad backlights stay on, or turn off backlights
to extend battery life.
Find it: (on menu) > Settings > Initial Setup > Backlight"
Jun 22, 2009 | Motorola Mobility RAZR V3
Front key pad stays lit all the time on my wifes envy2 runs battery down
Go to your display setting. Then go to backlight, then click keypad. And then you can choose how long you want it to stay lit up. Hope I helped
May 23, 2009 | LG enV VX9900 Cellular Phone
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
Dark display
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 11, 2009 | Computers & Internet
Tocco backlight not staying on.
Menu > settings > display and light settings > light settings > backlight time > dim> change time till dim upto 3 mins. back >on >change time light stays on .
Jan 18, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
The wired keyboard backlight turnes off too quickly
You would need to go into the Setting Menu and find the Backlight or Power setting to lengthen the display and keypad backlight times. Just know that your battery life will decrease the higher the settings especially since it is a VGA screen.
Dec 18, 2008 | HTC Touch Pro Smartphone
Samsung u340's front screen is very dark
Probably need your brightness turned up. Go to menu, then settings, then display settings, then backlight, then brightness.
Apr 11, 2008 | Samsung SCH-u340 Cellular Phone
Samsung Mb A412
i am after an unlock code for Samsung SGH-A707
Nov 13, 2007 | Samsung Cell Phones
Samsung Convoy Cell Phone Logo
357 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
