Question about Maytag Washing Machines
My Maytag front load washer is leaking. It is 3 years old. I have had one headache after another with the unit from Day 1. But today, I have a new problem: It is leaking from inside the front of the unit; water runs down the inside of the unit and out the bottom onto my floor. I have taken the bottom panel off to inspect the source of the leak and discovered that water is running down the left side of the rubber door seal from outside the tub. I filled a glass of water and slowly poured it down the area where the soap dispenser drawer was (removed it for test) and observed water coming from an area between the soap dispenser drawer/tube and the opening in the seal that supplies water to the tub. I have read other posts on this site that discuss other models and how the dispenser drawer should be cleaned; it is clean. It still leaks. Is there a gasket or valve inside that particular area? I would think it would be just a straight unobstructed line that allows for flow of water/detergent direclty into the tub. But then again, I am not an expert. Any ideas as to what the problem could be and how I can fix it?
  • ryanpetry May 25, 2011
    Model is MFW9600SQ1 if that helps.
5 Suggested Answers
SOURCE: GE Front Load Washer
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
  • 112 Answers
SOURCE: Tricity Bendix AW1400W front load. Water leaks
Ether the washer is over filling or has warn out the seals. If it has been abused (overloaded) it needs serious work. other wise the sensor may be stuck. Try 1/2 cup of vinegar with a load and see if that cleans the sensor travel area past the drum but inside the tub. This is a common problem for an old machine. Best leak is on the door and you may be able to tighten the screws but be careful it could mis aligne it so tighten a small amount and test by closeing the door. Do this at least twice before turning the screws hard.
Posted on Aug 17, 2009
  • 552 Answers
SOURCE: When my washing machine is
There is an article of clothing stuck inside the dispenser housing. Remove the top and the housing to get to the hose and clean it out. Very common issue, I know this unit very well.
Posted on Apr 22, 2011
  • 43901 Answers
SOURCE: Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Posted on Sep 22, 2012
Maytag washer leaking from bottom
This is a fix for the Maytag MAH2400AWW, the machine kept displaying SUDS, the machine is 2-3 years old and it started doing this 4-5 months ago. I cleaned out the washer, and used HE detergent, ran it empty, to try to flush it out, used approved cleaners and ran it throught the cycle, still no good. I finally took out out a maintenance contract with BSF, the service guy came out today pulled the pump off and showed me inside it was missing half of the blades off the impeller. I remembered a year ago a coin had wedged in the pump which I took out and put back, not realising it had taken some teeth off the pump. Therefore the pump was not able to pump out the sudsy water very well which was staying inside the drum causing the suds light to come on, they installed a new pump for me, which was covered in the contract for free. Now it's working like new again.
Mar 06, 2012 | Maytag MAH2400A Front Load Washer
My Maytag MAV6000 washer leaks intermittently. In the past 3 weeks it has been used many times but has leaked 3 times. I removed the front panel to look at the pump and hoses and put the washer through a...
Realistically, a 10-year old Maytag is nearing the end of its usual life. The pump may be leaking at random times during a wash cycle. If you put 50% of the cost of a new one into repairs, it is time to thing seriously about replacement of the machine.
Apr 26, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer top loading leaks water seems to be coming from the tub itself 7 years old thank you mija
does unit leak constant or only when spinning ther are 2 screws done low on front panel fill unit with water and watch center shaft there is a seal below basket
inside washer changing seal is a little difficult have also had this style of washer leak when starting spin cycle if water has not drained out fast enough
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram
this page has a break down of normal maytag top load machine part at center is called boot and seal have also had thi type unit leak where bolts go through tub
good luck ron
Dec 12, 2009 | Cameras
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
MLE2000 front load washer
Hi..I had the same problem yesterday...the maching would start when I pushed the button and then stop..I had to push the button again to get it going..My stacked set is around 8 years old.
Here's what we did..moved the washer away from the water source and unscrewed the water intake lines..there is a little screen there...took the screen out of both hot and cold lines..one screen has some debris in it..the other was almost completely blocked..we are on a well and sometimes dirt..etc..gets in the lines..
Today no problems doing the laundry..its working like new..
Oct 26, 2008 | Maytag MLE2000 Front Load Stacked Washer /...
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
The grinding (bearing) noise on "spin", now leaking rusty water under machine... 3 1/2 years old "Legacy" ??? NOT !
maytag has rear rollers and front drum glides when goes out sound like sand paper scratching, also inspect belt idler same noise
Aug 14, 2008 | Maytag Legacy Series Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
