Question about Cell Phones
I forget my lock code factory settings ,nokia6210 navigator-serial 352914022489468 ,please
    Problem Solver:
  • 12 Answers
If you forget the security code means, you can get the master reset code,
Visit this site http://www.onlinegsmunlock.com/nokia-dct-master-code-service/rs7wp10/
It has the best services for the master reset codes and unlocking codes for mobile phones.........
Posted on May 25, 2011
How to reset clock on 6520 mpbile
Follow the instructions on the screen to set up your phone and prepare it for use.
  1. Find "Reset all" Press the Navigation key. Select Settings. Select Security. ...
  2. Restore factory default settings. Key in the phone lock code (default is 1234) and press the Navigation key. Press the Navigation key to confirm.
Doro 6520 - Restore factory default settings - Device Guides
https://userguide.vodafone.co.nz/doro/6520...os/basic.../restore-factory-default-settings/.
or go to this link might help.
How to reset clock on 6520 mobile Google Search
Oct 28, 2017 | Computers & Internet
How to reset samsung s w299
1 Find "Reset settings"
  • Press the Navigation key to access the main menu.
  • Scroll to Settings and press the Navigation key.
  • Scroll to Reset settings and press the Navigation key.
2 info.png Restore the factory default settings
  • Tick the required settings by pressing the Navigation key.
  • When the box next to a menu item is ticked (V), the setting will be reset.
  • Press Reset.
  • Press the Navigation key to confirm.
  • Key in the phone lock code and press the Navigation key.
  • If it is the first time you use the phone lock code:
  • Key in the phone lock code again and press the Navigation key.
  • The selected settings are reset.
3 Exit
  • Press Disconnect to return to stand-by mode.
Jun 25, 2011 | Cell Phones
Reset or change door panel code for lincoln navigator 2005. i forget my password code to open the doors.
You cannot change the factory code and you will need it to set a personal code. To find the factory code you will need to open the fuse cover on the passenger side of the vehicle under the instrument panel. Above and to the left you should see a module that has a label/sticker on it with bold numbers (5 of them). Below is a picture of an exemple of the location of the module and how the label looks you may need a flash light. It is down there believe me. Once you have found the code, tried it and am sure you have the right code you can set a personal code, one that you can remember easily. to do this enter the 5 digit factory code. Then within 5 seconds press the 1/2 button. Now enter the new code you want to put in. Once the new code is put in the locks will cycle confirming to you that the new code is put in there. This does not replace the factory code and both codes will work. If you ever want to erace the personal code, press in the factory code and within 5 seconds press and release the 1/2 button within 5 seconds and the personal code will then be removed. I hope this helps you and good luck.
May 28, 2011 | 2005 Lincoln Navigator
Samsung c3050 phone white screen
Different Samsung phones has different methods to reset to factory default settings, today I will give you the tricks about how to reset Samsung C3050. If there is something wrong with your Samsung C3050 and make your handset slowly, the best method is to reset it.<
p>
While restore your device to factory default settings will delete all the data you saved before, and then your cellphone will be quicker than before. So you should transfer the useful information to the memory card or computer, then when you finish resetting Samsung C3050, you can transfer them back. So back up first.
-Press the Navigation key to access the main menu.
-Scroll to Settings and press the Navigation key.
-Scroll to Reset settings and press the Navigation key.
-The first time you use the phone lock code, key in a code of your own choice.
-Tick the required settings by pressing the Navigation key.
-When the box next to a menu item is ticked (V), the setting will be reset.
-Press Reset.
-Press the Navigation key to confirm.
-Key in the phone lock code and press the Navigation key.
Note: if it is the first time you use the phone lock code, key in the phone lock code again and press the Navigation key.
-The selected settings are reset.
-Press Disconnect to return to stand-by mode.
Please take note: if reset is not the best solution, I would strongly suggest to contact your manufacturer.
May 13, 2011 | Cell Phones
Nokia6210 navigator battery gets warm
Good day sir/maam, your battery is bad, replace it. If still gets hot, you may need to bring your phone for service. the charging circuit maybe faulty.
Oct 08, 2009 | Nokia 6210 Navigator Cell Phone
Factory setttings has to restore but forgot securiy code
Do you have your " lock code ". Then enter it instead of the security code. Its default is in the manual.
Sep 04, 2009 | Cell Phones
Forget my security code please help me
hi
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Feb 25, 2009 | Nokia 1100
Forget my personal lock code
#pw+106914725471323+1#
#pw+138514753677122+2#
#pw+497597111527102+3#
#pw+798100614623017+4#
#pw+283595606167200+5#
#pw+057393070555703+6#
#pw+195924610341532+7#
Nov 16, 2008 | Nokia 6610
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
