Question about Baumatic Washing Machines
Is it easy to replace the door seal on a Baumatic BWD12?
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Baumatic BWD12
Yes you can do it yourself using the manual which can be found at the link below...
http://www.laundrymanuals.com/manuals/mfg/hotpoint/bwm12_bwd12.html
You will need to register for free to download it.
If you couldnt do it for some reason just let me know and i will guide you..
Happy fixing!
Posted on Oct 19, 2007
I can not work out how to remove the glass for cleaning from the baumatic pom9651ss oven. The instructions make no sense to me!!
Hi, to remove the glass there is a plastic sealing section at the top of the oven door with 4 slots in, use a coin placed horizontally into a slot and turn clockwise until you feel the seal disengage then repeat on the next 3, then you will be able to remove the plastic sealing section and access the door glass that can simply slide out one at a time.
Oct 14, 2015 | Baumatic Ovens
Bwd12
Best way is to measure it by measuring tape.
Jun 15, 2014 | Baumatic BTWM4 Front Load Washer
How to relpace door glass on beautmic oven, model 610SS
Ok open the oven dor at a 45 degree angle , there is a plastic sealing section at the top of the door witch has 4 small slots in it . place a coin into each of the slots , turning clockwise to unlock the sealing section from the door . lift the sealing section from the door and the glass is now free to be removed . . . . Hope this helped you . . ..
Jun 28, 2012 | Baumatic Ovens
My Baumatic bdw9 dishwasher's door is leaking from the bottom, I dont know if it is over filling or the door seals have gone, any help would be appreciated
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Dec 26, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Baumatic megawdss leaks in front when wash cycle starts. How do I fix this?
The front door seal is bad,check to see if there is anything jammed up inside that seal,money,ex,ex,lint
May 07, 2009 | Baumatic MEGAWDSS Front Load Washer /...
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Freezer not cooling
ZoeM, I am thinking freeze up from humid conditions, too much 'window shopping' or bad door gasket (is that the seal of which you speak?). If the unit is only 9 months old...it has a full warranty. Don't do anything to it beyond what is described here.
Defrost the unit completely. If you can get warm air to the coils, do so. If not, leave it off and open for 2 days to completely defrost.
To check most door gaskets: first, make sure the gasket and its mating surface are both clean and visually undamaged. Next, test by simply closing the door on a piece of paper...use a strip about 2-3 inches wide and long enough to go inside the unit that you can slide across the gasket/frame surface. Close the door with the strip near any suspect areas. You should not be able to pull the strip out easily. Replace any damaged gaskets.
Dec 03, 2007 | Baumatic Upright Freezer BV12A
Baumatic BWD12
Happy fixing!
Oct 19, 2007 | Baumatic BTWM4 Front Load Washer
Washing Machines Logo
Top Baumatic Washing Machines Experts
Einar Axel...
Einar Axel...
Level 1 Expert
noel
noel
Are you a Baumatic Washing Machine Expert? Answer questions, earn points and help others
