Question about Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer
Xerox 5225 bypass tray with envelopes will not pull from this tray. When printing envelopes pulls from tray 4. On status all trays read ready except tray 5, status is blank
5 Suggested Answers
  • 208 Answers
SOURCE: Unable to print envelopes on Xerox WorkCentre Pro 123
Some thoughts.
Envelopes won't print from bypass tray. Cause:
Extended tray is not set up properly for envelopes. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Enter tools "Login" 1,1,1,1,1 Touch buttons with the following names in that order: System Settings System Settings Common Settings Other Settings Scroll down to "Extended Tray" Next to "Extended Tray" it may say "Inverter" if it does go to change settings then change it to "Offset Stacking" Close out tools.
Posted on Nov 30, 2007
Rubec
  • 42 Answers
SOURCE: Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
Posted on May 11, 2008
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
  • 2072 Answers
SOURCE: I can't seem to print envelopes on the xerox workcentre 7345. I fed the envelope into the bypass tray, configured the settings on the workcentre as well as the word doc, but it gives me an error 012-2
There is a lengthy set up process to that. I would recommend going ot Xerox.com, then at the home page, click on Support and drivers. When you get to that page, type in 7345, then click on the support home page, once there type in envelopes and the step by step instructions are there.
You are correct, setting up envelope printing on that machine can cause you to beat your head against a wall. The machine settings and the driver settings MUST be set exact. And it may take 3 or 4 tries, even for a service rep to get it all correct. Trust me on that LOL.
But once set up, it does a nice job. It is just very picky. Personally, I think it is way over designed just to print an envelope.
Posted on May 20, 2009
After replacing fuser upper roller machine shows error code 010-327.after resetting 3 to 4 times then the machine comes in ready
That error signifies that the fuser is not heating up, it could be the lamp or the thermistor, check your connections and lamp continuity.
Jan 19, 2016 | Xerox Workcentre 5225 / Copier, With...
How do I get the pritner to pull paper from open tray if there is an envelope or special paper being used?
You need to set the correct paper in the bypass tray settings on the machine. Once that is input you will have to tell the printer that you would like to print on envelopes through the bypass tray. This is done through the printer preferences. Hope this helps!
Oct 07, 2014 | Kyocera Mita FS-4100DN Mono Laser Printer
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
How to replace toner cartidge of the Xerox Copier 5225 machine?
The toner cartridge is located in the upper centre of the front of the copier. Open the front door, slide out the cartridge until you see the top handle, whilst pulling out hold the top handle to avoid the cartridge tilting and leaking any excess toner inside the machine.
Before inserting your new cartridge, gently shake it from side to side to ensure even distribution of the toner. Slide the new cartridge in until you here a click, then close the front door. Your copier may go into a calibration routine for a minute or so if the developer has been starved of toner. If it hasn't, it will be ready to copy straight away.
For a quick user guide on the copier go to http://download.support.xerox.com/pub/docs/WC5225_WC5230/userdocs/any-os/en/EN_Online5230_5225_5222_QUG.pdf
Hope this helps.
Jan 21, 2011 | Xerox Workcentre 5225 / Copier, With...
How does one print envelopes on the xerox pro 232?
descicon.gif function showThisURL(){ $('.urldisplay').show(); } function hideThisURL(){ $('.urldisplay').hide(); } email-icon.gif print-icon.gif btn_remove_x.gif Return to Search Results Solutions for : How To Print on Envelopes in the Bypass Tray or Optional Envelope Tray Solution : Print on Envelopes in the Bypass Tray or Optional Envelope Tray This solution assumes that Number 10 envelopes are being used and printed on using Microsoft Word 2003 or 2007. Steps may vary if other applications are used.
NOTE: If necessary, make sure the envelopes are loaded correctly in the Bypass or Optional Envelope Tray. See the Related Items below for additional information.
From the computer using Word 2003:
  1. Open the application, and then select [Print] from the File menu. The Print window will be displayed.
  2. Select the required printer, and then click on [Close].
  3. Select [Envelopes and Labels] from the Tools menu. The Envelopes and Labels window will be displayed.
    NOTE: For Office 2003, click on [Tools], then [Letters and Mailings], and then select [Envelopes and Labels].
  4. Click on the [Envelope] tab.
  5. Enter the address and other information in the fields provided, and then click on [Options].
  6. Select [Size 10 (4 X 9.5)] from the Envelope size pull-down menu.
  7. Click on the [Printing Options] tab.
  8. Click on the second icon from the right under the For Feed Method section.
  9. Click on [Face-up].
  10. Select [Default Tray (automatically select)] from the Feed from pull-down menu.
    NOTE: If the Envelope Tray is being used, select [Tray 2].
  11. Click [OK].
  12. Click on [Print] to begin printing.
From the computer using Word 2007:
  3. Click on [Mailings] tab.
  4. Click on the [Envelopes] icon.
  5. Click on the [Envelopes] tab.
  6. Enter the address in the Delivery Address field.
  7. If necessary, enter the return address in the Return Address field.
  8. Click on the [Options] button.
  9. Click the [Envelope Options] tab.
  10. Select [Size 10] from the Envelope Size pull-down menu.
  11. Click the [Printing Options] tab.
  12. Click on the fifth icon from the left from the Feed Method section.
  13. Click on the [Face Up] radio button.
  14. Select [Bypass (Tray 5)] from the Feed From pull-down menu.
  15. Click [OK] twice.
Nov 23, 2010 | Xerox Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
How do i print envelopes on a Lanier LP331cn laser color printer?
You should see a bypass tray near the main paper tray. On laniers it is recommended you use the bypass tray for envelopes.
when you send a print job make sure to select the bypass paper tray option
Oct 08, 2009 | Xerox WorkCentre PRO 128 Copier
Some thoughts.
Nov 22, 2007 | Xerox WorkCentre Pro 123 All-In-One Laser...
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
Xerox Workcentre 5225 / Copier, With 100-sheet Bypass Tray, 2 X 500-sheet Paper Tray, 2 X 500 Tray... Printer Logo
180 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
