Question about Matsonic MS-8188E Motherboard
I do not have clue how to connect it to the power supply. please show me a photo and description of all the connections
    Genius:
  • 1,127 Answers
Hi
click hear to find the manual to matsonic.
Posted on May 25, 2011
Wiring new A/C
ok let me think a little about this, the reason the control box has wires to connect to the thermostat is because some how the power has to run through the thermostat so it can be controlled by it. as you know the thermostat is nothing more than a switch that gets activated by temperature. now lets figure this out. you say the box has only 3 wires, but in your description you mentioned 4. how many is in total?
Dec 24, 2014 | Dometic Heating & Cooling
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
Lorex mc6996 4 wires connect to what? red, white, yellow, bare copper wires
Call Lorex
1-888-425-6739
Otherwise it appears this is 24V DC camera that requires DC transformer.
Photos of the product show plug-in connections.
That seems inconsistent with description, implying that incorrect model number was given, or this is a used product that was taken apart?
Add a comment.
Attach a photo.
Apr 19, 2013 | Hardware & Accessories
Where is the fusible link for the cooling fan on a 93 Mercury Topaz?
I can supply only general information. There are actually three fusible links: a 20GA DK BLU (YEL wire), a 20GA BLU (RED/LT GRN wire), and a 14GA DK GRN (YEL wire). All three wires connect to the constant control relay module which has a RED output wire connected to the powertrain control module (PCM), a BLK/LT GRN wire connected to ground, two DK BLU wires connected to the electric cooling fan, a TAN/ORG wire connected to the PCM, a LT GRN/PPL wire connected to the fan, and a LT BLU wire connected to the PCM. Sorry for the roundabout description but it's all the information I have
Oct 07, 2012 | Mercury Topaz Cars & Trucks
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Jul 20, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Scanjet 4300C
Hope this helps, but there's no specific model number, but here's a description:
Round barrel connecter with a positive center. Voltage regulator, power supply, powersupply, inverter, adaptor, adapter, transformer INPUT: AC 100V and OUTPUT: +12VDC/1.25A (12 Volt 1250mA)
And, a photo:
Aug 25, 2009 | Office Equipment & Supplies
ASUS P5S8000-VM/S no bios screen no beeps
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Jul 21, 2009 | ASUS P5S800-VM Motherboard
Acer Aspire powers on and off
The power supply is suspect here but go to setup or Control Panel to disable any power saving settings. Just change the setting to "Never turn off". I don't have your operating system to be specific but you can find the settings if you just explore.   If the signs point to the power supply you can try connecting another power supply if you have one available or check the Power On/Power OK pins at the connector if you have a meter. There are also power supply checkers you can buy but power supplies are not much more so just take the power supply out and any local service department where power supplies are sold will check your old one before selling you a new one. Let me know if you get any more clues to go on or need help as to where to check with a meter. Steve Medley
Dec 14, 2008 | Computers & Internet
Elio doesnt connect
i have similar problem, i think i know why mine doesn't work. My son connected the usb port to power supply, since then the elio manager does not recognise that the player is connected.... something must have blown in the usb circuitry
Jan 29, 2007 | Tatung Elio Photo JukeBox MP3 Player
Matsonic MS-8188E Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Alan Hohenbrink
Alan Hohenbrink
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
