Question about Electric Eyeware Fender Cd-60ce Black Acoustic-electric Guitar W/case
How to place/replace the battery of the built-in tuner?
How do I use the built-in tuner (Alvarez System 500) on my Alvarez guitar? I put a new battery in, but nothing happens.
is the battery in correctly? All Volumes up? If yes to both of those and you still get nothing, Then the tuner is not wired into the pick-up or is defective
Jul 07, 2015 | Alvarez Music
Ibanez Srt preamp issue
try opening it up and pinching the two prongs around the patch cord to tighten it up. My bass was cutting out for a while and giving out no sound till i did that
Jul 27, 2013 | Music
How do I change the battery?
Most there is a little release right by the tuner EQ that allows the tuner with battery box to tip out to replace.
Sep 05, 2011 | CF Martin 000X1AE Java Mahogany Acoustic...
Hi, i have a acoustic guitar but i do not know how to tune it with the Matrix Chromatic Tuner SR-1050
That tuner has a built in microphone to listen for your guitars sound. Turn it on and set is close to your guitar as you tune it.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
No signal, or in and out ,not battery or preamp
This appears to have a built in tuner. When you press the tuner button, that kills all output. Make sure the tuner is OFF to get output.
Feb 26, 2011 | Applause AE148RRB Super Shallow Deluxe...
I have a takemine 523 12 string. recently, the preamp starting flashing arrows up and down, the tuner is inop and can't get sound through the amp. Any suggestions?
I have this same problem. I press the button to turn the tuner on and nothing happens except the arrows on screen flash alternately. There's also no sound from the output
Feb 17, 2011 | Takamine EG523SC12 Cutaway 12-String...
I bought my Taylor acoustic/electric brand new. It sounds great, but when i plug it into my amp no sound comes out. I replaced the battery, but it still failed to work. When i plug it in to the amp and...
IF YOUR GUITAR has a built in tuner, make sure the tuner is off as it disables output while tuning... The other thing is to check if you have a volume control on the guitar that might be set too low.. Make sure if you are using 1/4 inch plug guitar cable that it is NOT a TRS balanced cable, as that will turn off the power in the guitar.
Dec 27, 2010 | Taylor Guitars 816ce Acoustic Electric...
Electric Eyeware Fender Cd-60ce Black Acoustic-electric Guitar W/case Logo
1,011 people viewed this question
Top Electric Eyeware Music Experts
Vito Vacirca Jr.
Are you an Electric Eyeware Music Expert? Answer questions, earn points and help others
