Question about Air Tools & Compressors
RAnd 4000 compressor Model RA5e6va The small wheel thats spins to build up the pressure broke.. One big wheel and one small wheel w/ a fan belt. THe small wheel broke, where can i get a replacment wheel?
4 Suggested Answers
dgjtex
  • 405 Answers
SOURCE: Ingesoll Rand 4000
http://air.ingersollrand.com/manuals/Default.aspx
Go here, If this helps you please vote me fixya..
thanks
Posted on Jan 31, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
  • 480 Answers
SOURCE: Ingersoll rand 4000 5.0 hp
ya it can be take the cover off the switch and look for a small screw if you turn in or out you should build more pressure.
Posted on Oct 12, 2010
Where can i get an owners manual ingersoll-rand compressor model RA5E6VA?
Try Googling (Ingersoll-Rand)(RA5E6VA)(manual) without parens.
Feb 20, 2018 | Air Tools & Compressors
Motor turns and pump pully does not. burning up belt.
Air Compressor Trouble-Shooting, Problems, The Causes ...
www.portlandcompressor.com/compressor/trouble-shooting.aspx
Provided below is a general list of common air compressor problems, and a few quick ... Loose pulley, flywheel, belt, belt guard, cooler, clamps or accessories. ... Piston rings installed up-side down. ... Receiver does not hold pressure when compressor is unloaded. ... Turn on power, check fuse, breaker, or motor overload.
Reasons Why an Air Compressor Will Not Build Pressure
fix-my-compressor.com/compressor-will-not-build-pressure/
An air compressor that will not build pressure runs on long past the point where it normally ... air compressor with at least one piston that moves up and down or side to side to pump air - cycles, .... I have an Ingersoll rand 7100 compressor 2stage 175 psi 120 gal tank ... The motor is a 2.5hp 3450 rpms with a 4 inch pulley.
Supercharge your Air Compressor for 20 bucks or less - Sawmill ...
www.sawmillcreek.org > ... > General Woodworking and Power Tools
Mar 16, 2006 - 15 posts - ‎8 authors
I have a 27 gallon belt driven Sanborn (Coleman) compressor and I have been ... I'mnot suggesting they won't compress air or give good service. .... Most any small oil-less compressor will serve a nailor, pump up the snow tires ... A two stagecompressor pumps 20 to 30% more CFM per motor HP thanks to ...
Jan 05, 2016 | Ingersoll Air Tools & Compressors
Air disc grinder will stop run after wheel grind touch the surface metal
You don't have enough air pressure. Let the compressor build up more air pressure, and check to see if you have an inline pressure regulator (like you might have for a paint shop). If you can, bypass the pressure regulator to use full compressor pressure.
Feb 03, 2014 | Ingersoll Rand - Rand 308 Heavy Duty Air...
Won't build top pressure an shut off
It sounds like your pressure switch is not set correctly. It is possible it is set too high for the compressor you have.
Sep 23, 2017 | Ingersoll Rand Ingersoll-Rand 80 gal. Air...
I have ingrosoll rand t30 model 2340 motor is working very hard to spin the compressor sound of compressor is different to , rubber burning smell is also there , but belt is in good shape it is not loose.
May have a bearing going bad. Remove the v-belt and turn the motor by hand. Does it turn hard or produce an unusual noise. If so you have a bad motor bearing. If not turn the pump by hand. If it turns hard or produces an unusual noise you have a bad bearing in the pump. Also move the pump fly wheel up and down , left and right. If you can move it the front bearing is bad.
Sep 20, 2010 | Ingersoll Rand - Rand Type - 30...
I have an Ingersoll Rand compressor (RA5E6VA) 5 HP 60 gal vertical tank (only found 3 HP listing below, but it says 5 HP on it) There is a plastic tube between where the pump attaches to the tank (air in)...
that is just a compression fitting. Sometimes just replacing the tubing is enough to get a bit on it. If not you should be able to get another fitting from an indstrial supplier.
Mar 06, 2010 | Ingersoll Rand Single Stage Cast Iron 3 Hp...
I have a ingersoll rand air compressor rand 4000 60 gl vertical 230v model #ra5e6va serial #dc90177-0025 i am wanting to know what cylinder head torqe is for the compressor.the head gasket leaks oil and...
Oct 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Ingesoll Rand 4000
thanks
Jan 30, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
185 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
