Question about Bush 5693D 24" TV
When I switch the TV on I just get a message 'No Signal' ,this also happens when I try to play a DVD. The TV is on and I just get a blue blank screen. The other TVs in the house that are all connect to the same aerial and signal booster are working OK.
You might be on the wrong "channel" on your TV. On the remote for your TV, there should be a set of buttons for if you want the remote to control the TV, or DVD player, or Aux 1 or 2. You want to click the TV button and try changing the TV's "channel". Your cable/DVD player are on different "channels" of the TV. Try scrolling up and down through the "channels" of your TV.
Posted on May 25, 2011
I have a PHILLIPS DV3 47 inch smart TV. But I cannot hook up to my dvd recorder
The blue/red/green aren't a component signal which is why they don't match and are causing the no signal message. The dvd recorder is most likely only giving out RGB which you need to plug into those RCA sockets or SCART/Peritel connector if you have that.
Sep 30, 2014 | Televison & Video
Have 32 inch rca, says no signal, blue screen, plays dvds great has good picture, how do i get tv picture on?
IF plays DVD's via the audio and video jacks on the set there is a option here--bypass the issue with a box (cable or sat or any kind that will pass the signal via the same connections you use for a DVD.
The blue screen suggests you have or may have a bad tuner in the set--cannot beat it get around it.
Jun 11, 2012 | Televison & Video
The disc is stuck in the player and the tv screen says it cannot get a signal.
Barbara, your dvd player needs to be either on channel 3 or 4. If you have a local channel 3 or 4 switch it to the one that is not local. Or it could be a video 1,2 or 3. Just keep using the remote in that format and you will find the signal.
Nov 21, 2011 | Cyberhome CH-DVD 300 DVD Player
Get message This disk can not be played. Please check the tv system from bdp1500 blue ray player. Disk plays well on another dvd player. What's wrong
Happening to me as well.. I have burned dvd-r that I made myself.. and it will not play.. I have all kinds of different dvd-r's and none of them worked.. ran the latest firmware.. nothing!
May 20, 2010 | Samsung BD-P1500 Blu-Ray Player
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Jul 13, 2009 | Yamaha RX-V861 Receiver
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
Sony KP-41T15 Color problem
Does this happen when you play a dvd? if so your RED, GRENN, and BLUE lenses in the tv may be out of alingment. First try pulling the power on the tv (make sure the tv is turned off first) wait about 2 min. then plug it back in. If this stil continues, then what i said earlier may be the case and sorry to say unless you have a warranty you will be better off to buy a new tv. Now days it costs more to repair a tv than to buy a new one. And it could very well be the receiver
Oct 25, 2007 | Sony KP-41T65 41" Rear Projection...
Bush 5693D 24" TV Logo
232 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
