I have to remove a section of retangular metal ductwork from my HVAC system in order to install a sister beam to support a broken beam. Are special tools needed? Can I just peel back the metal band that seems to be connecting the sections?
    Genius:
  • 1,033 Answers
Hello, you can peel back the drive cleats but just be carefull not to bend too much or it will be hard to reinstall. A pair of sheet metal seamers or linesman piers and a flat screwdriver is all you really need to remove the drive cleats.
Posted on May 25, 2011
How to remove dash panel to replace climate control panel
  1. Remove the instrument panel accessory trim plate around the control panel by prying gently and then pulling it straight out.
  2. Remove the control panel mounting screws.
  3. Pull the control panel straight out from the instrument panel.
  4. Disconnect the electrical connectors.
  5. Installation is the reverse order of removal.
  6. After installation, the actuators must be calibrated. For additional information, refer to the following section, -Actuator Calibration.-
  8. Fig. Remove the screw and pull the control panel straight out of the instrument panel.
To calibrate the system:
  1. Place the ignition switch to the OFF position.
  2. Install the HVAC control module.
  3. Connect all previously disconnected components.
  4. Start the vehicle.
  5. Wait 40 seconds for the HVAC control module to self-calibrate.
  6. Verify that no DTCs have set as current DTCs.
  7. Place the ignition switch to the OFF position.
  8. With the Mode knob in the PANEL position, press and hold the AC button for 5 seconds.
  9. Rotate the Mode knob fully counterclockwise.
  10. Rotate the Mode knob fully clockwise.
  11. Rotate the Mode knob fully counterclockwise.
  12. Release the AC button.
  13. Wait 40 seconds for the HVAC control module to self-calibrate.
  14. Start the vehicle.
Sep 14, 2011 | 2001 Oldsmobile Silhouette
Cold air from ceiling vents when furnace kicks on. Can blower fan setting be retarded to avoid this cold air? There also seems to be a cold air downdraft from the cold air return in the ceiling. Is...
1. You can't change the blower timing at the beginning of the cycle (important to keep the heat exchanger temperature correct).
2. The issue isn't that cold air is going through the furnace itself, it's cold air in the ductwork.
3. It's likely that the cold air you feel from the return and the cold air in the ductwork are related in this way: many duct systems are imperfectly sealed and not that well insulated.
A home energy contractor (weatherization or energy auditor) might be your best resource to seal the ductwork and add insulation.
If this is the problem, then the good news is, your comfort issue can be solved and it will also save you lots of fuel, paying for the work to seal and insulate in very short order!
Dec 16, 2010 | Goodman Heating & Cooling
With my 91 buick park avenue,in order to have heat,i need to plug in the blower motor/fan,when i do this,i feel some heat but it doesn't blow out alot like it should. Could this be the blower motor or...
The vacuum motor may be bad:
Vacuum Actuators Fig. 1: Vacuum actuators and related parts 84306017.gif
REMOVAL & INSTALLATION
  1. Refer to the Air Bag section at the beginning of this Section, and disarm the Air Bag system. Disconnect the negative battery cable.
  2. Remove the glove box assembly.
  3. Remove the right and left side sound insulators.
  4. Remove the heater ductwork.
  5. Disconnect the hose harness from the actuator.
  6. Disconnect the actuator rod or lever.
  7. Remove the mode, recirc, or A/C-defrost actuator. To install:
  8. Install the actuator.
  9. Connect the actuator rod or lever.
  10. Connect the hose harness to the actuator and fully seat.
  11. Install the heater ductwork.
  12. Install the right and left side sound insulators.
  13. Install the glove box assembly.
  14. Refer to the Air Bag section at the beginning of this Section, and arm the Air Bag system.
Oct 28, 2010 | 1991 Buick Park Avenue
Broken heater coil
If you mean the heater core is leaking. Here is how to change it:
To Remove:
  1. Remove the HVAC assembly.
  2. Remove the heater core cover screws.
  3. Remove the heater core cover from the HVAC assembly.
  4. Remove the heater core gasket from the core.
  5. Remove the heater core from the HVAC module assembly.
To Install:
  1. Install the heater core to the HVAC module assembly.
  2. Install the heater core cowl gasket to the HVAC module assembly.
  3. Install the heater core cover and screws to the HVAC module assembly.
  4. Install the HVAC module assembly to the vehicle.
Oct 18, 2010 | 2000 Chevrolet Silverado 1500
How to change heater core on 2005 dodge stratus?
  1. Disconnect the negative battery cable.
  2. Remove the radio/HVAC control module bezel. CAUTION
    The vehicles covered by this manual are equipped with a Supplemental Restraint System (SRS), which uses air bags. Whenever working near any of the SRS components, such as the impact sensors, air bag modules, steering column and instrument panel, disable the SRS, as described earlier in this section.
  3. Remove the right instrument panel side trim.
  4. Remove the two retaining screws at the lower right side support beam.
  5. Remove the instrument panel support bolt at the A-pillar.
  6. Remove the left instrument panel side trim and upper instrument panel bezel.
  7. Remove the lower knee bolster and console screws at the instrument panel.
  8. Remove the gearshift knob and shifter bezel.
  9. Remove the mounting screws at the front and rear of the floor console. Remove the front and rear console halves.
  10. Remove the right side instrument panel support strut.
  11. Drain the cooling system into a suitable container, then disconnect the heater hoses at the cowl panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal.
  12. Remove the mounting screws and heater core cover.
  13. Remove the heater core from the vehicle. To install:
  14. Carefully position the heater core unit into the heater housing.
  15. Install the heater core cover onto the heater housing and tighten the mounting screws.
  16. Install the right side instrument panel support strut.
  17. Install the front and rear console halves.
  18. Install the shifter bezel and gearshift knob.
  19. Install the lower knee bolster and console screws at the instrument panel.
  20. Install the upper instrument panel bezel and left instrument panel side trim.
  21. Install the instrument panel support bolt at the A-pillar.
  22. Install the two retaining screws at the lower right side support beam.
  23. Install the right instrument panel side trim.
  24. Install the radio/HVAC control module bezel.
  25. Fill the cooling system to the proper level.
  26. Connect the negative battery cable.
Aug 13, 2010 | 2005 Dodge Stratus
How do you remove the hvac control from the dash of a 1996 astro van? looks like the front of the dash has to be removed first ,but I can't see any way to remove it.
A/C-Heater Control Unit Removal & Installation To Remove:
  1. Remove the IP cluster trim plate.
  2. Remove the retaining screw from the left side of the HVAC control assembly.
  3. Pivot the HVAC control assembly.
  4. Remove the HVAC control assembly from the dash in order to access the vacuum and the electrical connectors.
  5. Disconnect the electrical and vacuum connectors from the HVAC control assembly.
To Install:
  1. Installation is the reverse of removal.
Jul 09, 2010 | 1997 Chevrolet Astro
How do I remove heater core on 1997 dodge stratus
prev.gif next.gif Heater Core REMOVAL & INSTALLATION Cirrus, Stratus, Sebring Convertible and Breeze
  11. Drain the cooling system into a suitable container, then disconnect the heater hoses at the cowl panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal. Fig. 1: Remove the heater core cover 90906g01.gif
    Fig. 2: Remove the heater core 90906g02.gif
Sebring Coupe and Avenger
  1. Disconnect the negative battery cable. CAUTION
  2. Remove the instrument panel from the vehicle, as outlined in Section 10 of this manual.
  3. Drain the cooling system into a suitable container, then disconnect the heater hoses from the dashboard panel. Plug the heater core outlets to prevent coolant from spilling during unit housing removal.
  4. Remove the center stay.
  5. Remove the lap cooler duct mounting screw. Remove the center duct.
  6. Remove the left and right rear heater ducts.
  7. Remove the foot distribution duct.
  8. If equipped with A/C, remove the cooling unit mounting nut and bolt.
  9. Remove the retainer clip, then the heater unit.
  10. Remove the heater core. Fig. 3: Exploded view of heater unit and core assembly 90906g03.gif
    To install:
  11. Install the heater core into the heater housing.
  12. Install the heater housing and retainer clip into the vehicle.
  13. If equipped with A/C, install the cooling unit mounting bolt and nut.
  14. Install the foot distribution duct. Install the left and right rear heater ducts.
  15. Install the center duct, then install the lap cooler duct mounting screw.
  16. Install the center stay and connect the heater hoses to the heater core at the dashboard panel.
  17. Install the instrument panel.
  18. Fill the cooling system to the proper level.
  19. Connect the negative battery cable.
Jul 08, 2010 | 1997 Dodge Stratus
I have the large goodman HVAC standalone unit. Why isn't the metal box which connects the unit to the home ductwork insulated since it is outside?
It should be insulated. It may be insulated inside with duct liner. If not you can do this yourself. With insulation or foam duct board.
Nov 25, 2009 | Refrigerators
REPLACING HEATER CORE
HEATER CORE REPLACEMENT REMOVAL PROCEDURE 1. Remove the fuel injector sight shield. 2. Drain the cooling system. Refer to Draining and Filling Cooling System in Cooling System. 3. Use J 38185 in order to position aside the heater hose inlet and outlet clamps at the heater core. 4. Disconnect the inlet and outlet heater hose from the heater core. 5. Remove the RH Instrument Panel Closeout/Insulator panel. 6. Remove the LH Instrument Panel Closeout/Insulator panel 7. Remove the floor carpet. 8. Remove the rear floor air outlet duct from the holes in the floor reinforcement. 9. Disconnect the rear floor air outlet duct from the heater air outlet cover. 10. Remove the rear floor air outlet duct. 11. Remove the heater air outlet cover screws . 12. Remove the heater air outlet cover heat stakes with a small chisel. 13. Remove the heater air outlet cover from the HVAC module assembly. 14. Remove the heater core cover screws . 15. Remove the heater core cover heat stakes with a small chisel. 16. Remove the heater core cover from the HVAC module assembly. 17. Remove the heater core from the HVAC module assembly. 18. Remove the heater core foam seal (1) from the HVAC module assembly.
INSTALLATION PROCEDURE 1. Install a new heater core foam seal to the HVAC module assembly. 2. Install the heater core to the HVAC module assembly. 3. From the inside of the heater core cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 4. Install the heater core cover to the HVAC module assembly. NOTE: Refer to Fastener Notice in Service Precautions. 5. Install the heater core cover screws . Tighten Tighten all screws to 1.5 N.m (13 lb in) . 6. From the inside of the heater air outlet cover, drill the dimples adjacent to the heat stakes using a 5.5 mm (7/32 in) drill bit. 7. Install the heater air outlet cover. 8. Install the heater air outlet cover screws (2). Tighten Tighten the screws to 1.5 N.m (13 lb in) . 9. Connect the rear floor air outlet duct to the heater air outlet cover. 10. Install the rear floor air outlet duct to the holes in the floor reinforcement. 11. Install the floor carpet. 12. Install the RH Instrument Panel Closeout/Insulator panel. 13. Install the LH Instrument Panel Closeout/Insulator panel. 14. Connect the inlet and outlet heater hose to the heater core. 15. Use J 38185 in order to reposition the heater hose inlet and outlet clamps to the heater core. 16. Install the fuel injector sight shield. 17. Fill the cooling system.
Nov 13, 2009 | 2003 Chevrolet Monte Carlo
How to change front headlamp bulb? Low beam
  1. Open the hood.
  2. Remove Grille.
  3. Remove the 2 retainers on back of headlamp assembly and remove the headlamp from the sheet metal panel.
  4. Remove the access cover from the rear of the headlamp.
  5. Disconnect the electrical connector from the socket.
  6. Rotate the bulb and socket counter clockwise in order to remove the bulb and socket from the housing.
  7. Disconnect the electrical connector from the socket.
  8. Remove the bulb and socket from the headlamp.
Installation Procedure Important: • Replace a high beam bulb with another high beam bulb. The high beam bulb has a black socket. • Replace a low beam bulb with another low beam bulb. The low beam bulb has a gray tip and a grey socket.
Oct 14, 2009 | 2002 Chevrolet TrailBlazer
Heating & Cooling Logo
108 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
