Question about Seagate ST3500312CS 500 GB SATA II Hard Drive
Hi i have a seagate hdd from a sky+ hd box 500gb and when i plug it into my pc it will freeze when i get to the black screen where you have the option to go into the bios but it does reconise the hdd the serial number is st3500312cs
  • John Waters
    John Waters May 25, 2011
    What type of motherboard do you have, i would start by check your bios settings to see if its configured for auto , sata, ata ect. since of course your seagat is a Satat II hard drive i would make sure your HD settings in the Bios are either set at auto or to Sata.
  • 77 Answers
SOURCE: Serial number missing
The volume serial number is automatically generated when you format the drive. By using the Seagate utility to zero fill the drive, you have made it blank and destroyed all data, including the partition table and filesystem. Re-partition and re-format the drive.
Posted on Jan 19, 2008
SOURCE: Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Posted on Oct 06, 2008
Vladimir Z
  • 86 Answers
SOURCE: Seagate Freeagent 500gb Ext. HD not working.
it´s my first time on this topic, but I´d recommend reinstalling it´s drivers, it sounds like it´s stuck there. Or just to be sure it is working ok, the both connections, esata and usb. If any of them work it´s ok. If not, come back, we´ll figure something out for you.
Posted on Oct 19, 2009
  • 10406 Answers
SOURCE: st3160827as seagate hdd is
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Posted on Nov 04, 2010
  • 10406 Answers
SOURCE: my seagate external hdd 500gb
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Posted on Nov 07, 2010
I need the driver for a seagate 500gb st5005423fa
Shouldn't be a problem. With the drive installed in your laptop, insert your windows disc and it will do it for you or if USB, plug it all in and get to Control Panel. Select Administrative tools. Choose Computer management and then under Storage choose Disc Management. There will be your drive. You must initialize it first then format it.
Hope that helps.
Nov 17, 2013 | HEWLETT-PACKARD HP 8740P I7820QM 4GB 320GB...
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
My HDD Seagate Momentus 5400.6 500GB is not recognized by win7. I have connected it like a ex USD HDD, but there is no USB devices in Device manager. The hdd is clicking -1sec click, 0,5sec off. Thanks,...
Hi, it might be a file system error.
You could try removing the hdd from the usb enclosure and connect it directly to your pc via SATA.
(power off both of them before doing so)
If it really is the file system then scan disk should repair it automatically when turning on the pc.
Then if the pc recognizes it you can put it back in the usb enclosure.
Jun 30, 2011 | Seagate Momentus 5400.6 500GB Hard Disk...
My Seagate 500GB not detected in Windows 7. Fine in Windows XP
hi there,
how old is your hdd? it could be that your hdd did not come with support for windows 7. if that is the case, you will need to log onto the seagate website and download the latest software/driver for your hdd. hope this helps :)
Jan 18, 2011 | Seagate Computers & Internet
I have Seagate HD 500GB (Internal) and my PC configuration is Intel i3 Processor with 2GB RAM, 1GB Nvidia Graphic Card and 250GB HD(Internal) in which OS is loaded. I'm facing a problems as...
Your problem is very clear... The HDD has got bad sectors in it and that is the cause for the Sneak sneak sound...
This causes your HDD to not get detected under bios in most of the situation and this is the root cause for all the problems stated above...
Here is the solution:
It is not possible to do any kind of service from your end...
It has to be sent to a seagate service center to get serviced...
Mostly they will never service the HDD, they will replace it with a new one...
All the seagate HDD comes with 5 years warranty...
you can opt for replacement...
search in google for an authorised service center located in your locality...
Dec 18, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Suddenly stopped working
i think your hdd is dead,Because your hdd light not even turn's on....
Apr 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagat 500GB Portable GO external HDD not recognised on PC
first of all you should try it on deferent pc , if its ok then that leads us to insufficient power provided through usb ports , try using back usb ports not the ON-front, and if the problem still try using dual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.html and if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changed if you cant find a similar one you may buy a new empty cage
Mar 05, 2010 | Computers & Internet
Oct 19, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 750GB usb HDD asks to format,when opening by double click
The disk is either damaged or the USB interface is damaged.
1) You could try opening the external case and connect the disk to your computer directly (Using IDE/S-ATA cables)
2) Format the HD and use data recovery software/service.
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
No detection
unhook ext drive from laptop...turn off hd...then reconnect to laptop..then turn hd back on..see if you can see it then.
check your computers warranty here 4 FREE
Mar 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate ST3500312CS 500 GB SATA II Hard Drive Logo
70 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
