Question about Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply
Nothing happens when ON button is pressed, only green light on power supply is on. The fan is not running either. Preceeding this event, computer will run only whe I kept ON button for several seconds.
  • Gateway Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem hope this helps
Posted on May 25, 2011
Intel D946GZIS machine will not start after being reassembled. The green light on the Motherboard is on but after hitting the power button nothing happens
It is more than likely the power supply that is faulty. Newer PSU's have a 5volt supply missing, this means that some older boards will not run with the new PSU's. Try and find an exact match for your older supply but with a better power rating, if that is what is required.
Jun 24, 2012 | Intel D946GZIS Motherboard
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
IBM server x3400 not starting
This is a Planner issue (Mother Board) . Open side cover and investigate capacitor status . Probably some capacitors are bulged . Check it and replace if necessary .
Good Luck
May 16, 2012 | IBM x3400 Server
No power to my desktop computer HP A1330N and no green light in the back of the power supply
You replaced power supply and your made sure you plugged everything back into the motherboard snuggly and in it's proper place? If so it might be your motherboard is bad.
Make sure you have the new power supply turned on. Sometimes there's a O/I switch on the back of the power supply. Flip it and try to boot and see what happens. You might have another bad power supply.
If so your motherboard might be burning them out.
Try removing the power cord for 30 seconds and press and hold the power button. After 30 seconds put the power cord back in and press the power button to see what happens.
Do your fans work when you press the power button? Do you hear any fans running?
Mar 23, 2012 | Computers & Internet
Power supply unit starts (fan running) but computer does not....
Try swapping out the ram 1 at a time, making sure there is one memory piece there while testing. If no! check hard drive for activity.
Mar 14, 2012 | HP Pavilion a1102n PC Desktop
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
No boot, New PS, Green light on MB lights, No Fans running
Bottom line: Either your power supply or (hopefully not) the mother board has gone bad.
Replace power supply (remove old one), take to local independent computer shop, ask them for new unit. Should be around $50.00. - no more. After reinstall, if still no fans, boot, etc. Replace motherboard or buy a new machine. MB's installed probably will run you around $250.00-ish.
Good luck.
gurutim
Mar 21, 2009 | E-Machines eMachines Desktop PC
HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Dec 12, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
My computer won't start! It was shut down by the start menu and when I went back to it about an hour later, I push the button in to power the computer on and nothing is happening. Yes, it is plugged in...
Unplug it and hold the power button in for up to 60 seconds to discharge.
Is there an I/O button in the back of the computer? Make sure it is set to I.
Apr 10, 2008 | Computers & Internet
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Gateway Bestec ATX-300-12EB3 305w Power Supply (ATX30012EB3) Power Supply Logo
159 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
