Question about Vtech 5.8GHz Cordless Phone with Digital Answering System
Does these phones have a call waiting function? I loss the manual. Please advise if there is and how to access it.
I have a poulan PP3516AVX/PP4218AVX and the starter pull cord does not retract when pulled to start. I opened the face plate and manually rewound the cord hearing the "CHING" of the spring coil...
You need to remove the screw to get to the spring which may have broken, the screw in the centre is a torx 20, you can purchase these from any good hardware or tool centre.
Aug 19, 2011 | Poulan Garden
My new Ricoh C820DN printer gives me a "waiting
please DO NOT use PCL printer drivers. USE RPSC or PS (post script) drivers and everything will be OK
pifonski
Feb 24, 2011 | Ricoh Aficio SP C820DN Laser Printer
How to activate call waiting on samsung corby...
1)Go to menu from the touch pad [the icon in right corner] 2)Settings->Application settings->Calls->Voice Call->Call waiting 3)then activate it
Dec 13, 2010 | Cell Phones
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
LG KG800 memory
Hi there, try takiing your mobile phone to the shop were you got it from or phone the place and tell them what your problem is, they should be able to help, i'm sorry i coulden't, hope this helps, good luck ! :)
Apr 23, 2010 | LG KG800 Cellular Phone
T7316E Voicemail issue
Reset the voicemail password.
Do so by first presing
Function 985 (to view the mailbox number the phone is using)
Function 983
Log: 1020000 (or 120000, 10020000 1st is for 2 digit extensions 2nd is for 4 digit extensions)
Left Button (MBOX)
Right Button (CHG)
Enter Extension
Left Button (RESET)
This should reset the passwod to 0000, the steps maybe a little bit off depending on the software version installed on the phone system, but something like that will fix the problem.
Jul 04, 2008 | NorStar T7316E Corded Phone
Owners manual innovage 1507102
touch the FLASH (-) button once to switch and again to switch back
Dec 01, 2007 | Lands Phones
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
51 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
