Question about Acard Technology (ARS-2030LD) DVD±RW Burner
I am trying to simply copy a dvd but constantly get' target drive not ready' I have copied dvds in the past, not ure what I am doing wrong. I can even find the dvd in the HDD but dont know how to copy it!!!! As you can see I am a novice!!
  • Acard Techno... Master
  • 27,725 Answers
Make sure that the dvd rw is getting enough power test all leads that are attached to the dvd rw including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options update driver roll back driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs Click Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on May 25, 2011
Copying dvd to hard drive so i can copy i have a family dvd that i would like to copy how do i do it
It really depends on the DVD content. Commercial DVDs are copy-protected, and unless you have specialized (and usually *******) software, you copy attempts will not work. Home-recorded DVDs can be copied, but again, content is key. You can do something as simply as copy the files to the hard drive and re-burn them to the new DVD, but that will produce a DVD that will work in a PC but might not work in a DVD player is there is video content to be watched. You can copy the disc as a single-file ISO, which provides an exact copy of the disc. To do that you'll need a program that can make and burn ISO files. There are a number a free ones available out there, just be careful what you go for as some are known to be accompanied by adware.
Jan 31, 2016 | Lenovo Essential G500 Laptop Computer -...
I have dvd rw discs can i use them to copy ?
Yes, but you need to format the DVD R/W then you can copy and then paste to the DVD R/W disc.
Oct 13, 2010 | Sony Optiarc AD-7240S 24x DVDRW DL SATA...
How do i transfer dvds from my laptop to my seagate external drive
Highlite copy and paste.
Right click on the file, then select copy,
Go to the folder on your external drive,
Left click, then select paste.
That`s it.
Dec 19, 2009 | Seagate Computers & Internet
Cannot copy dvds or cds with my duplicator
Hey! Usually, DVDs have some protections which prevent DVD users copying DVDs freely. Theser protections include CSS protection, region code protection etc. Therefore, you need to remove DVD protections first if you want to copy DVDs. There are some DVD Copy software which can do this. I have a good luck with this DVD Copy which works fine. You can have a try if you like.
Hope that helps.
Nov 07, 2009 | Plextor Dupsonic 52X 1 to 9 CD Duplicator...
Acard 1 to 3 duplicator can't seemto get past the traget disc not ready
of course theres a problem but what are you doing with the thing? are you formaating the disk first to render the dvds in the target drives? are you using the right DVD like DVD+ DVD+- or Blueray? need more information to help you. and it the DVD you are copying has been redered on another machine it won't copy it anyway. You have to use the same machine to copy it as thats how they protect copy rights now days.
May 29, 2009 | Computers & Internet
TEAC DVD Duplicator copies CD but not DVDs
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
Feb 19, 2009 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Teac 1x1 dvd duplicator dvw-d11
This seems to be a memory/cache problem - increase (double) your cache size .....
Mar 19, 2008 | Computers & Internet
Coping dvds ,cds
If you are copying a DVD to another blank DVD, just put the original DVD inside > open Nero > click Copy disk > then the copy dialog box window will appear. > Just select your favourite speed ( [8x] medium speed recommended) and click Burn. If you are copying a DVD to your hard disk, just put your DVD on the drive, Open My computer > right click DVD drive icon and click open > Then select the appropriate file or folder to copy > right click it select copy > close the window. Now open My computer > open disk drive [may be D: or E:and so on... ] > right click and select paste. Now the file will be copied to your disk.
Sep 29, 2007 | Ahead Software Nero 6.0 (60045) for PC
Acard Technology (ARS-2030LD) DVD±RW Burner Logo
Top Acard Technology Computers & Internet Experts
Martin Murray
Alun Cox
DROPNDEAL
DROPNDEAL
Are you an Acard Technology Computer and Internet Expert? Answer questions, earn points and help others
