I recently bought a new 23" LED TV after a few days the remote control doesn't seem to work all of the sudden, i already replaced with a new AAA battery but still no luck.. what could be causing these problem?
    Sergeant:
  • 167 Answers
The first problem that comes to my mind is, the remote was accidentally poured with water or coffee and the result is shorted parts inside. solution: place the remote at the back of your refrigerator or in a warm place for a couple of days then try to use it again
Posted on May 25, 2011
Atlas ocap
use the camera digital or cell cam and with the remote control viewn see if the LED are ON. see the photo attached.
If do not do it. Open the remote control clean the keypads from corrosion, and resolder any colder joint . clean the contacts batteries and try again.
May 30, 2013 | Televison & Video
Tip
Hitachi 22HXJ06U stanby LED flashing red and blue.
Recently first thing in the morning I've found my tv power on / standby LED is flashing red and blue. The tv does not seem to respond to the remote...but after pressing remote on key the tv will eventually come on about 3 to 5 minutes afterwards. It would seem that the tv does an auto update during the early hours and then on next switch on it completes the update...during which time it seems that it has not turned on. To prevent this annoying behaviour you can disable the automatic software updates in the settings menu... see pdf user manual at https//estadoc.hitachi.eu/servlet/FileViewer?DocumentName=22%20IB.pdf see page 23 about software upgrade. In the settings options you can disable the auto upgrade. Occasoinally I expect it would be advisable to either enable the auto update for a day or two or do manual update.
on May 02, 2015 | Televison & Video
Remote control slow to respond to Bush tv (LT42M1CFA)
Even though your TV s remote control emits infrared light, it might have not sufficiant frequency as it supposed to be. The fault with its resonator crystal inside the circuit board need replacement. It will look like this. Replace it with exact frequency marked on it.8_16_2012_4_53_50_pm.jpg
Aug 15, 2012 | Big Button TV Universal Remote
Logik remote control won't work
It sound that your remote control need serivce. In most cases, claning it will rectfy the problem. You can get more details about how to reapair,test or clean the remote control by entering this site "Electro-help". Search for it in Google.
May 02, 2012 | Televison & Video
The remote control sensor on the TV has stopped working
If new batteries did not fix the problem, then it means the problem is either from the remote or the TV.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Regards.
Jan 09, 2012 | Televison & Video
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
My sony wega tv remote is not working
nice tv.. w/o a remote control seems bothersome huh.. heres my tips *try to buy new batteries *check the battery terminal if still intact *last resort is to replace the infra red L.E.D. of your remote control
Feb 11, 2011 | Sony WEGA KLV-23M1 23 in. HD-Ready LCD...
Brand new 55" Samsung LED
Well, you may have problem inside the TV, to find out for sure is to use this remote with SAMSUNG TV in the store where you bought it from, if it works, then I would demand them to give you a new TV since it may be a LEMON set which I would not want to own if it breaks down already, if the remote does not work in the store then ask the store to give you a new one.
Please leave rating if it helps.
Jan 20, 2011 | Samsung TV Remote Control
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
