Question about Kodak ESP 5 Printer
My printer is printer mirror writing how can i get it to print correctly. I have tried resetting it and turning it off but no change. This is happening with all docs.
    Sergeant:
  • 167 Answers
Uninstall the printer driver all the printer software, then restart your computer then install the driver and software again. then try print test
Posted on May 25, 2011
Im having a problem with my canon mp 510 scanner, the problem is when i go to scan a piece of white paper with black writing on it, it reverses and shows me on the computer black paper with white writing...
this could be because.. in the printer preference / properties .. you have the option of Mirror printing../mirror image.. so, pls uncheck/disable that.
Also make sure that you are keeping the paper face down , correctly on the slot provided ..
Sep 07, 2010 | Office Equipment & Supplies
Printer prints mirror image only.
check the menu in the printing section. there should be a section that gives you mirror images, dark background white letters etc..
need more info on the model .
Aug 19, 2008 | Office Equipment & Supplies
I have a networked HP 3600n printer.\r\n when printing in grey scale it prints in reverse, so the black is the back ground and the writing is white. Can anyone please advise? The OS is XP and the server...
The "Mirror Image " printing option is enabled.
Click on START - Control Panel - Printers and Faxes. You will find list of Printers Installed
select the HP 3600n Printer icon and right click on it. Select Printing Preferences. Under Advanced Features you will find "Mirror Image" - Choose OFF and Click ok and Save the settings and try printing.
Jun 17, 2010 | HP LaserJet 3600n Printer
When I attempt to print from any software ie Word, Adobe, etc, the printed page comes out in reverse. When I hold the printed page up to the light and turn it over, I can see, through the paper, the...
Some printers have a function to print in reverse for special purposes (glue-on prints, iron-over-a-white-t-shirt-and-get-it-decorated, and so on).
Apparently this function got switched on in your printer's Properties page, so you'll have to turn it off from there. It is usually called "Mirror" and is either on the Advanced Function tab or the Print Layout tab. I don't have an Officejet handy now, but on my Ricoh I have "Mirror Output" in Properties -> Advanced. Postscript printers have it under Advanced PS.
Oct 22, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
How do I stop printin in mirror image? I already
go to the printer from the control panel on your pc and verify the defaults are set correctly. if you are changing it in word for example it may only do it for the one time you are trying to print. usually if you right click the printer and go to properties, you'll see the settings there.
Jul 12, 2009 | HP PSC 1610 All-In-One InkJet Printer
Changing a Printing Shortcut turns mirror setting ON and OFF.
The paper was tightened(delayed). I have not switched off the printer and with effort have extended a paper. Despite of it on the screen it is constantly offered to clear the printer
Jul 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing Backwards
You must have the Mirror image option turned on.
Open a document and select File>Print.
When the Print window opens, select the "Preferences" or "Properties". button.
Click on the Advanced tab. Look for the Mirror Image option. If it says "On", click on it and you will get a drop down menu to change it to "Off".
(BTW, the Mirror Image is used for printing iron-on transfers.)
Jan 09, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
HP L7590
I hit print on the pdf file, went to properties and THAT was still set to mirror, so I changed it and everything was o.k.
Sep 25, 2008 | HP Officejet Pro L7590 All-in-One InkJet...
Background Color
1) In the Applications Menu on your copy screen there should be a option to turn on or off a background color fill. Turn it off and try. If it still comes out try hitting panel reset. If this doesnt work. 2) You have a bad Image Unit. Change the yellow image unit. 3) You may also have a bad write unit. Pull out the four write units and check the yellow write unit. It may have gone bad in which case it needs to be replaced.
Jun 12, 2007 | Minolta CF1501 Copier
Kodak ESP 5 Printer Logo
42 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
