Question about Roketa 50cc Gas Moped Scooter
2009 Roketa 50 Gas Moped will not turn over
I have a 2009 Roketa Moped that suddenly won't start. It wasn't turning over completely, and acts like the battery is dead. I tried to jump start it, but now it doesn't turn over at all now. If it won't take a jump start, will a battery charger make a difference? I'm trying to determine whether or not it's a problem with the alternator, the battery, or something else?@
    Top Expert:
  • Roketa Master
  • 43,050 Answers
Hi, Msmcenaney before testing any electrical component in the Starting Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Scooter Troubleshooting Scooter won start All about Scooters Fix Chinese 49cc Scooter that won start
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
http://www.roketapartsdept.com/
Roketa MC 08 50 User Manual
Posted on Oct 18, 2017
SOURCE: My bike won't turn over?
You either blew some fuses and or sometimes if you jump a cycle battery with a auto or truck you put to much amperage into the cycle system and it burns things up. Have a good look at the whole wiring harness.Gook luck. donnyb60
Posted on Mar 22, 2009
canbruce75
  • 1776 Answers
SOURCE: alternator will intermittently not charge battery
The first thing to check is that the belt is not slipping and that the belt tensioner is working properly. The next thing that I would consider is a short in the alternator output wiring. My nephew had a similar intermittent charging problem and one of the wires was shorting out in the plug at the alternator. I was able to isolate the problem by checking alternator output while moving around the wiring (gently). While doing this, the output would drop, and I was able to narrow down which wire was causing the problem. It was shorting out in the plug. I resoldered the wire into the plug and that solved the problem. Not saying that this is the case in your situation, but the symptoms are similar. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 30, 2009
  • 534 Answers
SOURCE: car wont start, acts like
Check the battery +12v power connection to the starter is in good order,
Check the ground connection between the battery negative and the engine/starter motor is robust and intact.
If no problem with above, replace the starter motor.
Posted on Oct 10, 2009
Adrian762
  • 425 Answers
SOURCE: ZR7-S wont start, battery is dead, i tried to jump
Start by getting your self a manual, plenty for sale if you google for it and if you like to search hard you should find a freebie.
Now your problem. Start with the fuses, make sure they are all OK, move to the kill switch and make sure it is functioning. Your jump start may not have had enough juice to get it going. Get your self a new battery, nice clean terminals, clean and reset plugs, then start again. You will find it a breeze once you get the manual and wont know how you ever lived without it. :D Good luck,
Posted on Feb 05, 2010
airjer995
  • 5332 Answers
SOURCE: 2001 PT Cruiser turn
Whats the battery voltage when you turn the key on or try to crank it? Have you checked to make sure the terminals are clean?
An almost dead battery will still read 12 volts until there is a load on it. Then you will see the voltage drop to almost nothing. Checking the battery voltage with the key on or with the headlights on will give you a better picture of the health of the battery. Since it starts and runs with a jump I would say a new batter is in your future.
Posted on Oct 14, 2010
The six pin plug from the bike shows all pins shorted to ground. This on the headlights. I have a 2008 Roketa 250. Also I cannot switch from lo to hi.
Hi, David for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Roketa, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda CN250 Owner Manual
http://store.oohla.com/storefiles/terminatorscooter//download/accessory/2658/sms.pdf
MC54
ROKETA atv exercise fitness dune buggies scooter gokart dirtbike moped...
Roketa Scooters
Apr 18, 2017 | Roketa 150cc cheap Scooters
150cc stator
Chinese Junk I am sorry to say. All made as cheaply as possible.
ROKETA MC-19 STATOR
www.roketapartsdept.com/products/ROKETA_MC_19_STATOR-16828-579.html
  1. Cached
Part# MC-19-150-06-01-09. Roketa MC-19-150 Replacement part. May Fit Other Makes and Models.
MC-19 ENGINE PARTS: Roketa Parts Department
www.roketapartsdept.com/catalog/MC_19_ENGINE_PARTS-579-1.html
  1. Cached
ROKETA MC-19 BREATHER HOSE CONNECT. Product ID ... ROKETA MC-19 ENGINE OUTPUT SHAFT. Product ID ... ROKETA MC-19 STATOR. Product ID ...
Roketa 150: Parts & Accessories ' eBay
www.ebay.com/bhp/roketa-150
  1. Cached
  2. Similar
Find great deals on eBay for Roketa 150 in Scooter Parts. ... MAGNETO STATOR 8 COIL POLE GY6 125cc 150cc SCOOTER ATV GO KART ROKETA TAOTAO ...
Roketa Scooter Parts - All Street Brands - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa
  1. Cached
Roketa MC-16T-150 Scooter Parts. Roketa MC-17-50 (Sicily 50) Scooter Parts. Roketa MC-17-150 (Sicily 150) Scooter Parts. Roketa MC-19-150 Scooter Parts.
Roketa MC-07-150 (Bahama 150) Scooter Parts - Monster Scooter Parts
www.monsterscooterparts.com/scooterparts/street-brands/roketa/roketamc07150
  1. Cached
Items 1 - 6 of 6 - 8 Coil Magneto Stator with 3+2 Wiring Connector for 125cc GY6 152QMI & 150cc GY6 ... 19 99. G07-1459. Medium Weatherproof Cover for Roketa Scooters ... Quality replacement parts for the Roketa MC-07-150 scooter.
Roketa Scooter Parts - Chinese Parts
www.motopartsmax.com > Roketa Parts
  1. Cached
  2. Similar
Roketa Scooter Parts By Type ... Air Filters & Intake (19) · Intake Pipes & Water Pipes · Air Filters · more · Cables (16) ... Roketa MC-19-150. Parts List · MC-20-150. Missing: stators
And TAO TAO
tao tao powermax Google Search
Dec 29, 2016 | Motorcycles
Wiring diagrams MC-02-50b(MAUI-50ST)
http://www.chinesescooterreference.com/manuals_charts.htm
Jul 19, 2014 | Roketa 50cc Gas Moped Scooter
Rewiring a 50cc roketa scooter
lights and relay wire
Jun 27, 2013 | Motorcycles
I have a 2009 derbi senda 50 cc and my indicator stays on solid ( not flashing ) why?
Hi, Bendapshaw you may need a new flasher/canceler sorry you can't find the first and best tool you ever bought for your Derbi despair, not for a mere $0 you can download another one. For more information about your issue and free valuable downloads that you will need please visit the websites below. Good luck and have a nice day.
Idicators won blink on my Moped
Derbi GP1 50 cc Workshop Manual
https://www.oemmotorparts.com/oem2.asp?M=derbi
http://www.derbi.com/fr/images/stories/modelos/37/manual.pdf
Derbi Senda XTreme 50 2008
Nov 03, 2012 | 2009 Derbi Senda Xtreme 50 SM
Roketa scooter won't start
Hi, Ammoncrosset and the usual suspects are:
1. Fuel tank empty.
2. The fuel tank has old dead gas.
3. Fuel tank bottom contaminated with ethanol sludge, dirt, water, rust, etc.
4. Fuel supply valve/petcock turned off.
5. Fouled spark plugs.
6. Engine flooded as a result of overuse of the enrichner.
7. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
8. Fuel valve/petcock or filter clogged.
9. Fuel line to carburetor or throttle body pinched, kinked or blocked.
10. Carburetor float stuck.
11. Fuel injectors clogged.
12. A severely discharged or damaged battery, you need 12.5 volts or better and be able to pass a load test if necessary.
13. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
14. Loose or corroded wire connection at the coil or plug between ignition sensor and ECM module.
15. Spark plug cables in bad condition and shorting check for spark leakage in the dark, cable connections loose, or connected to the wrong cylinders.
16. Ignition timing incorrect due to a faulty ignition coil, ignition module or MAP, CMP, CKP, O2, TPS, ETP, IAC sensors.
17. Faulty neutral, clutch lever, or kickstand safety switch.
18. Faulty fuel pump or fuse or relay.
19. A stuck bent or burnt valve.
20. Tilt sensor needs a reset.
21. Security system not disarming alarm needs a reset.
22. Check for engine trouble codes.
cranks but wont start
http://www.roketapartsdept.com/catalog/Scooter_Parts-52-1.html
Mar 19, 2017 | Roketa 50cc Gas Moped Scooter
I have a 50 cc tao tao moped that's when I started
Make sure the cable is hooked up on the carb slide inside the carb.
Oct 10, 2017 | 2004 Factory bike Chrono SM 250
TV wont turn on????
Some models may have a small little hole in the back to reset the TV if not I believe it may burn out on you.
Have it chec by your localTV repair man
Jun 29, 2010 | Philips 50PL9126D/37B 50" DLP TV
Rakatak md150t-6 moped was running
I was riding my 150 moped and when I turn the corner it cut off. When I tried to start it back up it wouldn't start. It crank but didn't turn over...
Aug 22, 2009 | 2000 Bajaj Chetak 150
Roketa 50cc Gas Moped Scooter Logo
80 people viewed this question
Top Roketa Computers & Internet Experts
David Payne
David Payne
Are you a Roketa Computer and Internet Expert? Answer questions, earn points and help others
