> Get your IMEI code by typing *#06#.
> Go to http://nfader.su/
> Enter your IMEI number and calculate the Master Security Code of your cell phone.
> Use that Master Security Code instead of your Security Code.
If you are an experienced user you can also use the following method to retrieve it.
http://www.youtube.com/watch?v=Oe79ml0Dr4w
If you dont change your security code is 12345 by default
SOURCE: unlock code for nokia 6070
3666341642 that is your code typwe in 1st *#7780# than put that code
SOURCE: Forgot Security Code of Nokia 6030 HELP NEEDED
These Nokia Unlock Codes are Generated For Nokia 6030 with IMEI: 353938013704220 (DCT 4) Locked to Provider Bharti Cellular Telecom Airtel in India and will only work with this phone!
#pw+199254713704764+1#
#pw+709210520774721+2#
#pw+922392540025507+3#
#pw+083253702164061+4#
#pw+324566447257373+5#
#pw+788290400654304+6#
#pw+302846623000752+7#
How to Enter your Unlock Codes
Recommended CODE :#pw+302846623000752 +7#
IF UNLOCK SUCCEEDS YOU SHOULD SEE RESTRICTION REMOVED ON SCREEN, YOUR PHONE IS NOW UNLOCKED!
POSSIBLE ERROR MESSAGES:
Repeat above instructions, but with the numbers from code 1 (#pw+199254713704764+1#) if code that does not unlock your phone STOP! .
SOURCE: 6085 security code forgot.please unlock security
Google for mastercode generator, you can restore lost security code with that code..
Example this: http://nfader.z-host.ru/
Compability list: http://nfader.z-host.ru/forum/viewtopic.php?t=12
TEST AT UR OWN RISK!! I m not 100% sure that works !
