Question about Brother MFC9320CW All-In-One Printer
We have a Brother mfc-9320cw printer that is printing with a thick and ugly crust of ink on the right edge of every 8.5x11" sheet we print. What is causing this? We've replaced the belt. It happens regardless of toner level (new and old drums give same problem). HELP!!!
This happened to mine, only my thick edge was blue. My problem was that the little green slider that cleans the wire on the toner holder was pushed to the wrong side. (Sorry, can't remember technical term for the green thing or the wire! It has an arrow on it and it's pretty easy to spot.) Push it all the way back to the left until it clicks and it should fix the problem.
Posted on Jun 14, 2011
  • Susan Fleischer Jun 12, 2013
    Exactly what I needed. Simple solution. Thank you.
  • 24 Answers
First you can try fixing your problem by cleaning toner cartridge corona wire also called green tab. Sometimes leftout toner can couse the problem you describe.
Socond, try cleaning the corona wite on Brother MFC-9320CW the same way as cleaning the toner cartridge. When printing out many pages the user must clean from time to time the drum unit surface.
Third thing you have to check is the waste toner container. It may be full and this may also be causing the problem.
I hope this information can be helpfull.
Posted on May 06, 2012
    Sergeant:
    Habit-Forming:
  • 106 Answers
Problem usually goes away if you clean the head/cartridge. What does the user manual say under the "troubleshooting" paragraph? Brother mfc 9320cw manual Download Free Manuals
Posted on Jan 19, 2016
Brother MFC-9320cw printer has stopped printing because it is at 50,000 sheets fed & says it needs to 'Replace PF (print feed) kit'. It was feeding just fine. Brother says I have to go to an aut
(1) Open the printer and wait for the carriage to slide over. If for some reason it does not follow these instructions:
(a) Unplug the printer
(b) Manually slide the carriage over until you can get the ink cartridges out.
(2) Remove the ink cartridges from the print head.
(3) Use cotton swabs dipped in hot water or a mix of hot water and isopropyl alcohol to thoroughly clean the print head.
(4) Repeat this until there is no ink residue coming off on the cotton swab.
(5) Once finished, allow to dry and replace the cartridges
(6) Try to print something now
If that does not work then you have one of two possibilities:
(1) One of the ink cartridges is defective and causing the error
(2) If it's definitely not that, then the print head will need to be replaced.
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Apr 18, 2014 | Brother MFC9320CW All-In-One Printer
Tip
How to make duplex copies with a Brother MFC-240C printer
The Brother MFC-240C is a well-performing multifunction color printer. There is a lot that it can do, but one limitation it has is the inability to make double-sided copies. If you need to make a duplex copy of something, you can do it manually by re-feeding the paper once you've copied the first side.
After the first side of the page has been printed, let the paper sit for a minute or so to make sure the ink has dried. Then, put it back into the paper tray on the top of the stack. Make sure the back side of the page (the side that has not been printed on yet) is facing down, and the lead edge of the page (the edge that was fed out of the printer first) is facing toward the inside of the printer, rather than toward you.
Once the paper is set, push the tray back in and print the document or image that you want to appear on the back of the page. If you are printing multiple pages, position the paper so that the page you want printed on first is on the top of the stack.
The MFC-240C was not designed for duplex printing, so you may run into some issues with it, especially when you are using very thick or very thin paper. With very thin paper, the ink may bleed through to the other side of the page. With very thick paper, you may have to let the paper sit for a longer time after the first side is printed, because the ink could take longer to set and dry.
on Jul 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-9320CW is printing blurred images
Click menu once and OK 3 times and reply the status of the test print
Oct 15, 2013 | Lexmark X7170 All-In-One InkJet Printer
Maintenance ink pr
Can you please explain what is happening, are there any error messages or what happens when you try to print etc.. the more details the better. Thanks
May 31, 2013 | Brother MFC-9320CW Color Laser Printer -...
Brother MFC 4420C prints plain sheets of paper.
To start ensure that is not a software problem.
Go to Control Panel >> Installed Printers. Remove the printer. Install the printer again using the software disk or downloading the driver software from Brother website.
If that does not fix the problem, and the printer prints blank sheets, then it is usually a clogged printhead.
The printheads can be cleaned removing the ink carriage and soaking it in isopropyl alcohol overnight. If that does not work, then the printhead must be replaced.
Regards
Jun 17, 2009 | Brother MFC 4420C All-In-One InkJet...
Ink on edges and sides of glossy prints
What I ended up doing is wrapping a piece of old sheet aroung my finger and put it into the far left side of the part, that is mentioned in the cleaning directions in my book,. under "cleaning the machine printer platen." After turning the machine off first, I got gobs of the waste ink (several times) doing it that way. Then I took the ink damaged glossy photo paper, and ran that through the printer with just a small image for printing. It seemed to not pick up any more ink on the edges. I hope this helps someone else.
Nov 12, 2008 | Brother MFC-5460CN All-In-One InkJet...
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC9320CW All-In-One Printer Logo
1,283 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
