Question about Canon VIXIA HF M300 High Definition AVC Camcorder
Camera rattles internally when it is moved around except when it is on in record mode? is this normal or is there something loose that shouldnt rattle?
    Genius:
  • 1,812 Answers
Yes. There is a free floatin element in the lens controled by an electromagnet. This is only active when the camera is in record mode.
Posted on May 26, 2011
Top refrigerator rattling inside the refrigerator when first starts to run then stops rattling
There is something loose, when first starting the compressor because of its initial load vibrates shakes etc then settles down as the system stabilizes. Move things around inside and see if this helps. If not remove everything and try again, if the rattle is still there it is part of the cabinet, if not it was something inside.
Jan 31, 2016 | Kenmore Refrigerators
I just purchased a new Exilim EX-ZR100. The lens rattles when you gently shake the camera. It doesn't matter if the camera is on or off. It works, but the lens rattles like it is loose or broken. ...
I have the same problem on mine too.. but if you search around, you'll find that almost everyone has this problem. As long as the camera is working fine and doing its job, and unless Casio comes up with a comment, we can assume it to be normal...
Jun 07, 2011 | Casio EXILIM EX-ZR100 Digital Camera
The canra says DCF full error agter taking 7 pictuturs
Hi. The PL80 has an 86MB internal memory so it does not sound as if there is anything wrong. However you can buy an SD or SDHC memory card and use that as well, so you can take a lot more pictures.
The number of pictures which can be stored depends on the size of the internal memory, or the extra memory card, and whether you set the camera to record the images in 'Normal', 'fine', or 'super fine' mode. This determines how compressed the images will be, and how much memory each one will use up.
A 1GB card would give around 160 pictures in super fine mode. Have fun with your camera!
Dec 27, 2010 | Samsung PL80 Digital Camera
I have rattle problem with my BMW R1200 Montauk motorcycle. It sounds fine on starting from cold but once engine gets hot a rattle develops. Williams BMW Manchester have suggested it could be exhaust...
I have seen a few of the R1200C bikes with this rattle.... There is a cat. converter in the exhaust system and it sits between the pipes approx. under the transmission. This is the usual cause of the rattle.
Warm the bike up by riding it around for a while, then stop the engine and use a plastic face or rubber hammer to tap on the exhaust system in the area near the transmission to see if you can hear a rattle or something loose in the exhaust. This should give you some idea where the source of the rattle is.
There is no easy fix for this problem except replacement of the offending parts.
Sep 22, 2010 | 2004 BMW R 1200 CL
My FujiFilm Finepix JV100 isn't recording the amount of time it's suppose to. It's on HD mode and it stops around 40 seconds of recording. I tried the other options and they work just fine. Thank you for...
You only use the internal memory (24MB). Internal memory only records 41sec. Please check the settings. If HD records are recorded to internal memory.
Apr 15, 2010 | FUJIFILM FinePix JV100 Digital Camera
Cybershot dsc-w50 records movies instead of pictures
I had the same problem with my camera.  I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures.  Go to Menu and scroll over to Mode, then select Normal.
Jul 10, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Fuji S304 Power Switch
not if you have never done this before. It sounds like something that a local repair shop could fix. Just note that even if it's a minor fix, and the shop suggests to send it to fuji, you'll be looking at a very high rate. 100$ and up. look for someone that says s/he can do it in-shop. good luck
Jun 09, 2006 | Fuji FinePix S304 Digital Camera
Canon VIXIA HF M300 High Definition AVC Camcorder Logo
159 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
