Question about HP LaserJet 4700 Printer
My Hp 4700n printer is making really light pinkish copies. I have changed all the ink cartridges...what else could be wrong
SOURCE: hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
Posted on Jun 01, 2008
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
  • 96 Answers
SOURCE: printer does not make black
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Posted on Aug 26, 2008
gisvc
  • 40 Answers
SOURCE: hp 3180 print cartridge light blinking
hi,
is the ink cartridge you replaced hp brand or did you refill it this is an incompatibility code from the software. some brands and cartridges are not fully compatible and creates an e code error code. if it is hp brand it is likely a defective sensor chip in the ink cartridge. i would for best assurance return the cartridge for a different one and then recheck. if niot you may need to restore your software or reinstall it most of the time this will fix the problem.
hope this helps..happy computing!
Posted on Mar 30, 2009
  • 253 Answers
SOURCE: How to change ink cartridges in HP 1610 all-in-one printer
Generally on the older AIO machines there is a front panel That is usually on the right hand side, or lift the entire scnner panel and see if you see the cart. cariage. If you see the cartridges the old ones usally lift up and towards you, If there is a clip holding the cart. lift the clip and the cart will lift out
P.S. go to HP.com and click support, choose the second option and enter your model, there you can download the manual for free
Thanks for the good rating if this helps
Posted on Apr 12, 2009
I just changed four ink cartridges on a HP Deskjet 3522. It will print but I can not copy.
What error are you getting? Are you trying to copy directly on the printer or are you using the HP software to do it?
Dec 05, 2014 | HP DeskJet Office Equipment & Supplies
After changing theblack ink cartridge in the DX4400 the printer will not print, i have `run` through several copies only to get `faint horizontal lines` on the copy paper, would you have any idea what i...
Do you get the lines when copying only or when printing as well? If you only have the issue when copying, then the scanner part of the printer could be the problem. If the issue happens when both copying or printing, then the issue more than likely resides with the printing mechanism of the printer.
I'm not familiar with this printer model, but here's a few things to check:
  • Remove the ink cartridge and re-seat it into its cradle. While it's out, make sure there's no left over tape covering the nozzle of the cartridge (like HP cartridges have).
  • Epson ink cartridges include a microchip inside them that monitor the ink levels of the cartridge. Once the ink gets below a certain level the cartridge will no longer work. If this is an older cartridge, the issue could be resolved by getting a new one. If this is a brand new cartridge, it could be that the cartridge is faulty or that there is an issue with the printer itself.
Good luck! -Ingo
May 05, 2011 | Epson Stylus Multifunction Inkjet Printer/...
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
I changed the black ink cartridge but the ink light keeps blinking as there was no ink and it also makes weird noises as is the cartridge try to move but can't
you may have probably gotten a fake ink for your printer, because Hp printer will never work or print not until u put in a genuine ink from Hp. Try to purchase another genuine ink and see if the problem will occur again.
Thanks
Jun 23, 2010 | HP DeskJet 810c InkJet Printer
My HP Photosmart 8250 Inkjet printer is not printing black ink. If I let it sit for a while and only print 1 copy it will print a pretty good copy. Additional copies are almost blank but will have color...
try to reinstall the printer driver software. you can download the latest printer driver software from yout printer manufacturer's web site then restart the computer and printer.
Jun 11, 2010 | HP Photosmart 8250 InkJet Printer
Pinkish tint in photo color copies ....... Is there a way to adjust the color ?
The "secondary" colours are produced by mixing the "primary" colours. One of the "primary" colours inside your inkjet cartridge is out of ink, and the resulting "actual" mix is not the "theoretical" mix.
Refill or replace the ink-cartridge.
Apr 05, 2010 | HP PSC 1315 All-In-One InkJet Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Wrong "low level" alarm
well bad for you!!! if that happens i think it's gonna make you pay much!!!! hmmm...!!! let me suggest!!! why not bust that printer and buy a canon pixma ip1880!!! it's a lot better!!!
if i dont help i dont care!!! well at least i tried hehehehehehehehehehehehehehe.... smell ya lateh
Jul 17, 2008 | HP Photosmart 3210 Printer
My HP Printer does not show color. When I print black and white, I get a pinkish cast and often pinkish printing.
It is possible you're black cartridge is too low on ink & needs replaced. If you're black ink cartridge is new, there could be small ammounts of sticky tape left over the contacts of the ink cartridge. Please clean the ink cartridge's copper contacts (side only, not the bottom of the ink cartridge), with a cotton swab & a little alcohol. Since the ink cartridge is removed clean copper contacts inside the carriage holder as well. Allow time for the alcohol to dry. All most every printer installs software that monitors ink level's. To check you're printer for this. Click the start button, slide up to & click Printers and faxs. The printer and fax window will open. You're default printer will have a little check mark next to it. Right click once on that printer name, another little pop-up window will open, slide to & left click on properties.
You're printer (It's name) will open. Near the bottom click on Printing Preferences. Another window will open. Click the Services tab. Than click Service this device. You should be able to see the ink levels.
Have more questions? Please feel free to ask.
Hope this has helped.
Luck!
Mike
May 12, 2008 | Office Equipment & Supplies
HP LaserJet 4700 Printer Logo
32 people viewed this question
Seeker5211
Seeker5211
