We understand that your problem is: Hi I have the envision series AOC monitor, It turns on and i also have all the functions like AV, HDMI, PC, but when I turn it on it says no signal. I have checked all of the cords and my Oc is working fine with a different monitor but I cant figure out whats going on. It was working fine yesterday can you please help .
  • cedar_grove_ May 26, 2011
    I am not computer savy and I dont understand your response. Can you please help, if you were refering to the cords as leads then they all work just fine even after we switched them out.
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Posted on May 25, 2011
  • Brian Sullivan
    Brian Sullivan May 26, 2011
    even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
    a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty graphics card clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
Inputs will not change on a envision aoc tv
Try a factory reset. This might re-enable the other functions.
Try this:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Jan 13, 2014 | AOC Televison & Video
AOC 19 inch LED Monitor e950Swn - Will HDMI adapter to VGA connector to PC get hi def?
HDMI will only go as far as HDTV. Use DVI, component video (RGB etc) or VGA instead.
Jan 10, 2013 | AOC 19" LED Monitor e950Swn Black
My Envision Series AOC TV has blue lines across the screen when its on. Common problem?
This might be a screen driver problem that cannot be easily repaired without replacing the whole screen assembly. It may be cheaper to replace your TV. Ask a repair shop for a repair quote.
May 15, 2012 | AOC Envision L32W461 32 in. LCD HDTV
Does the AOC 931Swl 19 have a hdmi port to connect my ps3 to?
Hi there.
Unfortunately the AOC 931Swl does not have a HDMI port.
Slasher_X
Sep 22, 2011 | AOC 931SWL 19 inch Monitor
I have sapphire ati radeon 5570 graphics card. i have aoc 912sw+ 19 inch lcd monitor. how to connect hdmi port of graphics card with monitor?
the HDMI port is for connecting video and sound to a home theatre / surround sound system. I understand that this monitor only has a VGA connector.
The sapphire ati radeon 5570 graphics card has the following ports on the back to connect to a display: DVI (white), VGA (blue) and DisplayPort (the thin slot in the middle). You can use an ordinary VGA cable to connect the card to your monitor.
Unfortunately you cannot connect this card directly to your monitor using the DisplayPort.
Hope this helps
Tom
Jul 21, 2011 | AOC 912SW-4 Monitor
I have an Envision AOC 32 tv monitor and want to hook my WII up to it, It has yellow white and red wires. The back of the monitor has HMDI, PC Cable, and coax connectors. It also has speaker out puts and...
Yellow Is VIDEO, Red & White is your AUDIO. (Stereo). They should go color to color on the TV's AV input. This is AV, and you use 3 wires to connect this way.
The Red, Green, & Blue, is called COMPONENT, & is ONLY VIDEO, the AUDIO, still must use Red & White. So to connect with Component you use 5 wires, altogether, 3 for Video, 2 for Audio.
Plug them in color to color & choose the right INPUT on the TV, and turn on your input device.
Feb 26, 2010 | Envision L32W761 32 in. LCD TV
Envision Series / AOC 22 hdtv monitor
Probably blown capacitors, the 19" widescreen uses 6 16V 1000uF
Do you have a soldering gun? Its not that hard to fix, get the capacitors on ebay for $6-$8 with shipping.
Oct 31, 2008 | Envision 19" Widescreen Flat Panel LCD...
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
