Question about Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator
We have about fourty HT1000 radios that are all exibiting the identical problems. there is no TX and the RX is at around 80db.
  • Motorola Master
  • 1,654 Answers
Since you have such a large quantity with the same problem, it is possible if these radios have been reprogrammed, retuned, or even possibly had a power surge while attached to their chargers. These would be the items we would investigate first. Sometimes a well-meaning programmer can clone a problem into multiple radios.
Send or take several (a good sample) of your radios to a Motorola dealer for more analysis.
Best regards.
Posted on May 25, 2011
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
Stuck on rx mode
Rx is an abbreviation for receive. (Tx is transmit) There are a variety of reasons a radio will be "stuck" in Rx:
1) Another radio in the group is stuck in transmit and you cannot reply if your radio is receiving the other radios transmission.
2) Your radio is programmed for Rx only.
3) Your radio has a Tx problem such as a bad mic, or something covering the mic opening.
4) Your battery is low or bad. It takes more energy to Tx than to Rx.
Best regards.
Feb 07, 2014 | Cobra LI3900-2DXVP (14 Channels) 2-Way...
148 gtl cobra cb radio and the rx/tx light stay on
This sounds like a problem with the MB3756 Regulator IC. It controls voltage regulation and TX/RX Switching. It is a common failure in these radios. Check voltages with schematic that can be found at
CB Tricks Home Page
Sep 02, 2013 | Cobra 148 GTL 120-Channels Base CB Radio
Mirage 88.. RX okay TX distorted
try the original mic . If its still distorted then it,s a radio problem.
Mar 14, 2012 | Galaxy Radios DX- 88HL Base CB Radio
New radio, TX/RX freq. off 7khz and clarifier non functionable
under warranty that would be cover no charge.! send it in.. The clarifier on a factory radio will only adjust the RX.. not the TX.. unless there's a "course and fine." the course would do both. the fine would be rx only
Feb 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Red RX/TX and red ANT light on my CB
Well,first hand ,some cobra radio,s have red some have green RX/TX lights, but are you modulating? Some green lights turn red. What is your standing Wave on the antenna,s? You need to check it and the output of the radio. To do this you need a watt or field strenth meter. Can get one at Radio Shack. Your standing Wave is ok as long as it is below a 2. That has to be done on the antenna. ..hope this helps...
Mar 11, 2010 | Cobra 29 LTD CB Radio
I have a deisel 4-7 echo mic ineedcolor to pin to wire it to a Cobra 29 ltd classic thank you so much
cobra:black--ground
yellow--mic
red--tx
blue--rx
the wiring for the echo mic is identical
Sep 16, 2009 | Radio Communications
Ht1000 receivers
Just offhand it sounds like an intermittant solder joint on the circuit board. Just my thought,,, Mechanic
Nov 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
HT 1000, MT1000, Radius P110 Tx problems
Sorry about taking so long to respond. These radios have worked properly in the past. They have increasingly become worse to the point they will not Tx. I have tried to com-cate with a good radio but unsucc. I'm thinking the Tx freq has been altered? Can one freq (Tx) be altered and not the other (Rx) or will both become altered?
Oct 04, 2008 | Motorola HT1000, MTS2000, MTX8000/9000...
Problem Recieving
First try programming the Receiver for Carrier only Squelch,,ie no PL /TPL, then check if it will receive the repeater OK.
If the audio still cuts in and out then (assuming no fault exist) either you mis-programmed the Frequency slightly, or the TPL choice was incorrect.
There is also a possibility of a Bandwidth mis-programming.
Repeaters may have 12.5 KHz or 25KHz channel bandwidth. Basically if you set your radio to 12.5 KHZ and it receives a transmission from a 25Khz Repeater because of the higher repeater TX Deviation the audio on your radios RX will cut in and out and may sound distorted and very loud as well. Your radios TX would sound OK though, but would have lower audio level when heard on the repeater RX. Does your TX work OK through the TPL repeater?
Dec 17, 2007 | Motorola For MT2000 HT1000 HT6000 GP900...
Motorola HT1000, MTS2000, MTX8000/9000 Compatible 2 Way Radio Battery Eliminator Logo
43 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
