Question about Home
Need installation instructions for Fluidmaster Pro 45 fill valve. Cannot get the tube to lengthen.
    Brigadier General:
  • 3,301 Answers
Turn the water off, at the bottom of the tube is a sleeve ( connection ) usually a lighter color of gray, grab it and pull it up,, once you do you can adjust the tube to the desired length and then just click it back down into the locked position
Posted on May 25, 2011
2 Suggested Answers
  • 4340 Answers
SOURCE: fluidmaster stool flushing system: the float cup
REplace the assembly
Posted on Sep 22, 2010
How to adjust fluidmaster
There should be a small black rubber tubing piece that connects to the fill valve and the other end goes in the overflow tube to refill the bowl after each flush. Make sure this tubing is installed correctly and that should solve the problem. Hope this helps.
Bob
Jul 03, 2014 | Home
Need to adjust the tank water level on a Fluidmaster Pro 45 fill valve.
look on the internet site for the product and look it up no excuse for not knowing wher to look but this is a good place to start
Aug 03, 2013 | Home
300. Why does it occasionally get stuck in the up position or fails to refill tank completely?
It has been my experience that they are reliable. Fluidmaster instructions say to flush the valve (not the toilet) after installation to purge debris. It may be necessary to do this again. Also check for interference with the refill tubing. The float and linkage should be able to move freely.
Oct 10, 2012 | Fluidmaster Fill Valve and Flapper Repair...
I installed the Fluidmaster 401LG Fill valve but when I turn the water back on, water leaks from the water supply tube.
Did you change the supply tube also...many times the old one will not seal to a new fill valve.
heatman101
Jun 05, 2011 | Home
I have a fill valve that says Fluidmaster 747. when tank goes to fill it sprays water out at the top
There should be a small flexible tube/hose that came with this and goes over where the water is spraying out, it should look like a little nipple, the hose goes on there and then to the white tube appoximately an inch or so in diameter that goes to the bottom of the tank where the flapper ball is connected. The small flexible tube is supposed to connect to the top of the larger tube via a clip so-as to fill the toilet bowl back with water. If everything is connected like it's supposed to be then you might have a cracked fluidmaster.
Mar 11, 2011 | Fluidmaster Plumbing
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
I installed a new complete Fluidmaster and filled it up with water but when flushing water comes out under the tank not under the toilet though.
probably needs a "doughnut" tank washer under tank..or try tightening the tank bolt..fluid master comes with a little rubber hose that goes to overflow tube
Nov 25, 2010 | Fluidmaster Plumbing
After tank fills up, water continues to flow a little. How do you fix it?
Replace the top cap of your fill valve, or just the fluidmaster seal disc. Here is a link to the Fluidmaster fill-valve Instructions.
Sep 06, 2010 | Fluidmaster & Fits-All Faucet Connector
Not getting enough water in the tank to flush properly.
adjust the float level,it's a rod attached to lever next to float . i believe it will take a screw driver, look closely there is a+/- indicator
Apr 15, 2010 | Fluidmaster & Fits-All Faucet Connector
Sorry to be so dumb.... how do I open the red cap on top of the Fluidmaster pro 45? The water siphons on/off every minute or two for a duration of 5 seconds. I will check the flapper to make sure it seals...
Also see if your. fill tube is cracked this can cause it to cycle also, As for your fluid master, as long as the water is shuting off and it fills your tank in a timely manner its ok. I dont beleave the top on the pro series comes off.
Dec 01, 2009 | Home
Home Logo
474 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
