Question about Gigabyte GA-G31M-ES2L Motherboard
Front panel audio not working - Gigabyte GA-G31M-ES2L Motherboard
  • Gigabyte Master
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 25, 2011
ASUS P5KPL AM/PS front audio not working
Is the front panel audio connected to the motherboard? With any problem involving Wigglies(electirics) you should check your connections first, then fuses. In your case just the connections.
Mar 08, 2012 | ASUS P5KPL-AM/PS Motherboard
I HAVE HYTECH PCI SOUND CARD. BUT MY FRONT PANEL AUDIO IS NOT WORKING. HOW TO SOLVE
Hello there,
1. You must trace the front panel audio headers if it is attached to the right device.
2. Remove audio headers from the mother board if you are using a PCI sound card.
3. Check if your sound card has the proper audio headers.
4. Next configure your audio software if same jacks are tied up.
The image below is a Typhoon sound card, the rectangle box signifies audio headers. I don't have a clear image of your audio headers. It would be a big help for us to help you. the images provided below will help you to configure your front panel audio. pcsyke_80.jpg
This is the default header assignment for front panel audio.
Most casing this days have this dependent or intact headers unlike before.
This is an example of independent front panel audio in different configurations.
Hopefully this information Helps.
Thank you for using FixYa.
Jul 20, 2011 | Typhoon Anubis Typhoon Silver Crest 3D...
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Not work audio front panel.What`s the problems. How to connect cables in motherboard. please help
The front audio panel will only work if connected to motherboard. Try
connecting to the audio panel in the back of the computer (directly
to the motherboard). If the rear panel audio plug (green) doesn't work
then the audio drivers that came with the motherboard might need to
be installed. Check your audio driver status with operating system.
Jul 08, 2009 | Abit GD8 Pro Motherboard
Front panel audio failure-DG33FB Intel mainboard
Your Intel DG33FB board by default was already setup for use. Your board has been configured for independent multi-streaming 5.1 audio (using the back panel audio connectors).
Your board should have come with a shielded front panel audio cable to connect front panel audio as shown on page 45, item B. The pin out for the front panel audio header is shown on page 46, table 5.
If you did not receive this cable you may need to contact Intel.
Check the Intel link included, which shows the cable needed for either AC'97 or HD cabling;
Audio standards: AC'97 and HD audio
Most motherboards will not play audio through the rear jacks when the board is connected to the front audio pins.
Intel like other manufactures do not mention this in their manuals.
Thanks for using Fixya!
Jun 03, 2009 | Intel D865GBF Motherboard
ASUS p5kc front panel connector
all motherboard front side audio connector is equal so if you compair with onther motherboard
connector
Feb 02, 2009 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Plug mic and earphone to the front panel
hi!gud am...hope this will help...
have you check if your audio controller is working?have you installed the driver?if not check this out...start>control panel>system>hardware>device manager>sound,video and audio controllers...
is your mic and earphone new?if not try to replace it with a new one maybe its broken that's why its not working...
check if the front panel audio is connected on your mobo...some casing with front panel audio has no connection...let me know what you see and tried ok?
goodluck...
Feb 28, 2008 | EPoX EP-4PLAI Motherboard
Front Panel Audio
I don't believe that this motherboard supports simultaneous front and rear audio. That's the purpose of the jumpers; to route audio to the back panel when on and to the front panel when the front panel connectors are connected,
Jan 13, 2008 | ASUS P4GE-V Motherboard
Gigabyte GA-G31M-ES2L Motherboard Logo
117 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
