Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
The coupling from the toilet to the Maceration Unit is leaking at the Macerator side whenever the unit is flushed. How can this be stopped, or repaired? I am in Jacksonville, Florida. Is there a qualified repair service here? My cell# 904 744 9809 Terry Addy
  • 1,555 Answers
I won't suggest you to try to fix this problem yourself as you may do more damage to it. Kindly contact (904) 724-7211 or visit 8850 Corporate Square Court Jacksonville, FL 32216 for hiring an expert plumber.
Posted on May 26, 2011
Leaking macerator unit
Shut off water supply and check where the leak is. Loosen the joint , reconnect it securely and reclamp. Before reclamping spray Stop Leak around the joint. Slowly open water supply. Goodluck.
May 30, 2013 | Home
I've had a saniplus toilet system (with toilet and sink) for about 10 years. Suddenly stopped working as well. The macerator pump runs in shorter bursts and the water level in the toilet goes down
You should check the 1 1/2" vent pipe if there is one attached to the top of the pump casing. The vent pipe must be vented to the open air, outside of the house so the unit can breath air in and out at all times. A lack of airflow usually creates this type of problems. Leave the vent connection open to the room and flush the toilet, you will see the difference when pumping.
Mar 11, 2013 | Home
3yr old saniflo + started making loud vibrating noise and smells also small black particles come out - husband opened top and looks like a mesh thing has disintegrated. Toilet is at end of sink, bath /...
Unfortunately the systems are desiged to pump out. The disintegrated screen thing is part of the maceration end of the system. Your going to have to clean the thing out and replace the macerator.
Jun 20, 2011 | Saniflo 002/003/005 Saniplus Toilet with...
After I flush the toilet, the motor continues to run and not stop. The only way to stop the motor is to kill the power to the unit. Please advise. Thanks
The float or float switch is sticking. You will need to get into the pump and clean the area.
"It's a dirty job, but someone has to do it"
Good luck
Feb 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo keeps going off when not flushed
Water pressure makes the unit turn on and off. If it turning on by itself then could be water draining back into the pump. Water could be leaking from the check valve on the discharge elbow into the pump or from the toilet tank into the bowl. Inspect the flapper on the check valve and the flapper on the flush valve.
Aug 09, 2010 | Saniflo & Saniplus& Macerator Pump
Macerator keeps going off even when not flushed.
Water pressure makes the unit turn on and off. It will only activate on it's own when enough water pressure is present. Most likely it can be water leaking from the toilet tank into the bowl, and from the bowl into the pump. Or could also be that waste water is slowly draining back into the pump through the check valve on the discharge elbow, creating enough water pressure that it will make the unit kick on and off.
Aug 06, 2010 | Saniflo & Saniplus& Macerator Pump
Leak bubbles out from top vent thru sponge barrier - just wondered why?
I had the same issue before and called Saniflo. They told me that when the pumps are assembled at factory, they use soapy water to test the unit and see if it leaks. By flushing the toilet with plain water only a few times will eventually get rid of the soap residues inside the pump.
Jun 09, 2010 | Saniflo & Saniplus& Macerator Pump
What is the best product/chemical to keep Saniflow free of calcium build up ?
I would suggest not using standard drain cleaner as it could cause damage to the seals inside the unit. Saniflo suggest the following
http://www.sanifloproducts.co.uk/products/Saniflo-Products-Saniflo-Descaler.html
Hope this helps
Jan 21, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
114 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
