Showing cannot format complete - Computers & Internet
  • 27,725 Answers
You have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Posted on May 26, 2011
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 22, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
Is it possible to format a HCS725032VLA380 in NTFS ?
Absolutely...just make sure you have any data you want to keep backed up. If there's no data, then it's pretty straight forward.
  1. To format right click on My Computer (or just Computer in Windows 7) and select Manage.
  2. Go down to Storage and select Disk Management
  3. You'll see a list of drives connected to your system. If the drive you need to format doesn't have a partition, it will show as either Unallocated or Not Initialized.
  4. If it's not initialized right click on the drive and select to initialize it.
  5. Once complete, the box will show "Unallocated".
  6. Right-click on the box to the right of the drive listing (Disk X) and select New Partition.
  7. Accept all of the default parameters, or change the volume name it's up to you. You might want to select quick format to save some time.
  8. The formatting will start and will be busy until complete.
  9. Once the formatting is complete your drive will be accessible.
Jan 24, 2013 | Computers & Internet
4gb scan disk showing space as 0bytes if i click open then it show format now if i continue it shows format is not completed insert new disk plz help how to rectifie this problem
This problem is most probably due to virus infection. This USB drive can no longer be formatted in your system. However, you can try to format it by disabling your anti-virus protection for a while. If this one does not work, then try to format it on another system (eg. your friend's computer).
Dec 12, 2010 | Computers & Internet
Pendrive software
if window is unable to format try to format it using some utility software like hp disc format utility
download link
http://files.extremeoverclocking.com/file.php?f=197
Apr 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
It is unable to format and it shows "device was unable to complete the format"
Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders them selfs then format a couple of times hope this works
May 24, 2009 | SanDisk Sansa e260 MP3 Player
Windows was unable to complete the format
windows was unable to complete the format 4gb moser beer
Feb 26, 2009 | Electronics - Others
My recorder says "full" when i try to record, but i have deleted everything!!??!!
Solution for this problem is to Format the recorder. Step 1 is to turn on unit. Step 2 Press Erase " Delete will flash on the display. Step 3 Press and hold Rec for 3 seconds "Format" will flash on the display. Step 4 Press and hold Erase, the completed percentage will show on the display (formatting is now in progress). Step 5 After formatting is completed the remaining time will show on the display. You should now be able to record. Make sure that you hold the ERASE button in step 4 until Formatting shows 100% complete.
Feb 23, 2008 | RCA RP5030 Digital Voice Recorder
Memoryproblem
Try creating a new or extended partition in the unused space using a later version of Partition Magic (www.download.com)This problem usually occurs due to a previous format not completing correctly IE the MP3 player was removed from the USB source before completing a previous format. Check to see that there is not a pinhole reset button on your MP3 player (requiring a paperclip or pen to be inserted into the pinhole and pressed until a factory reset of the device completes) Much like resetting a digital watch)once reset to factory you can attempt to format the device fully again.
May 17, 2007 | Sony NW-E405 MP3 Player
Computers & Internet Logo
David Payne
David Payne
