Question about Numark Industries Numark CDN 22 Mk4 Double DJ CD Player
My numark cdn22 mk4 doesn't work at one side. the right to be specific. he can't read the disc and says al the time read. when i want to eject the cd the cd player opens and the cd is stil spinning in the plastic frame. when the cdplayer is trying to read the cd he makes a ticking sound and it doesn't stop. the point is that i do not have any guarantee any more.
5 Suggested Answers
djromann
  • 158 Answers
SOURCE: my numark cd mix2
Hallo! This is caused by the laser fault. First unplug the cord, high voltage!!! Disassemble the device, look under the cd place you will see a little lense. Clean it VERY DELICATE with a piece of cottonwool with alcohol, can clean it twice with alcohol and then with a dry one. If doesn't help, then need to replace the laser reader system with a new one, it's that where the lense is placed, it must have on it an badge with the serial number, you can search it by that number/code.
Posted on May 18, 2011
  • 5603 Answers
SOURCE: use the cdn22 on weekends
Check for contamination on the disks that won't load. Also if you have things like cigarette smoke or "fog" machine that can cause the problem. The precision of the head of the CD players is amazing as the tracks are millionths of an inch apart and it doesn''t take much to cause a problem. If trying to load again the disk finally works, then it may not be registering on the hub quite right. Care in centering MAY help.
Posted on Mar 14, 2011
jdvillanueva
  • 2098 Answers
SOURCE: Hi, I purchased the Numark Twin
Hi kshanley,
If you have necessary tools and test instruments, know safety precaution in basic troubleshooting try the steps below to solve your problem.
Assuming that the disc is good.
1.Clean the lens. - Sometimes because of dust and any fine foreign objects the lens can't read any disc. If you have a CD Lens cleaner, play it to the affected area. If this is not available you may manually clean the optical lens. Open the cover and gently clean the eye of the lens by smooth,clean,soft cotton buds. Be careful while doing this, just a gentle stroke only.
2.Check the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser. If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Check the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.Good motor - reading should be fairly high and it will spin. Bad motor- reading will drop to low resistance and will not spin.
Click this link for more info.
LINK1
LINK2
Hint : Most of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If the above steps didn't cure the problem, high chance that your optical lens was faulty.
If you can't do the job yourself, I would advice you to look for a professional to troubleshoot the symptom.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the cover(it will void the warranty).
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 03, 2011
djredskyy
  • 670 Answers
SOURCE: Numark CD DJ IN A
Was it working at first, and it just stopped? Try unhooking everything and just isolate the one cdj and plug it in see if it will eject. If its Brand New and this just started happening my sugguestion is to take it back to the store. you get what you pay for and numarks whole dj in a box line is the bottom line stuff.
Posted on Jun 15, 2011
Kmx02 disk spins fast, does not read
Educated guess is the deck cannot read the disc for some reason and is trying to find the index to start reading it. Try another disc and see if you have the same problem. Some discs will not play on some machines especially if you copied them yourself due to data duplicating copy guards installed in some machines.
Mar 04, 2014 | Numark Industries Numark KMX02 Dual Deck...
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Not receiving STEREO output when toggle switch for mixer is in the STEREO position
Here are a couple of steps you can do first before opening up the mixer & I'll word this so that it covers every potential item, (Turntables, CDJ's, Rack Mount CD Players, External Player, PC, Laptop, etc.) Obviously there are a multitude of items that could be the cause of you only receiving your RIGHT MASTER OUT since you didnt specify what item this occurs with if not all. So here's a quick legend for you to follow my references regarding the NUMARK 5000FX Mixer so here we go:
MIC/Line Phono/CD Phono/CD Phono/CD LA/LB Zone/Booth/Rec/MSTR
LO LO LO LO LO LO LO LO LO LO LOLOLO LO
RO RO RO RO RO RO RO RO RO RO RORORORO
1. Turntables - A) If being used make sure the little black switch on the back is set to Phono instead of CD. Plug just one table in, play the record & see if there's only one side of your MASTER output jumping and make note of it. Then repeat the exact same steps for all Phono inputs (total 3) & again make note of your MASTER output signal Left or Right or Both sides jumping. This will help you identify if its just a specific channell that only works on R or L.
B) Now do the exact steps above for the other turntable & this will confirm whether or not the Phono cables went bad on the turntable or if a specific channell is has gone bad while in Phono mode.
2. CDJ's/Rack Mount CD Player - A) Now just use your CDJ's/Rack Mount CD PLayer for the next test & be sure to now change the little black switch on the back from Phono to CD. Just as the steps with the turntable perform the same for this item in all possible RCA's (total 6) & note your MASTER channell output signals L & R.
B) Now do the same for the other CDJ/Rack Mount CD Player & this will confirm whether or not the RCA cables went bad on the CDJ's/Rack Mount Player or if a specific channell has gone bad while in CD mode.
3. Audio Cables OUT - A) There are a host of ways to have your audio come OUT & multiple configurations depending on how you record &/or bounce your audio OUT. Now since you say your MASTER OUT digital meter is only jumping on the R side depending on if you're going with RCA MASTER OUT or XLR BALANCED MASTER OUT either or is what'll show the digital reader bouncing with audio so check both. It could very well have been a cable going bad on you simple as that & you can check that by pluging your cable that works on the R side into the L side. If it starts showing a reading on the digital meter than you've solved the problem being a bad cable. Also don't forget to check your ZONE, BOOTH & RECORD OUTS as well however these will not show on your digital meter so open up your audio recording software to confirm that L & R sides are working for these.
B) Last but not least double check that your BALANCE knob is set directly at 12 o'clock, this could sometimes be the culpret.
Well I hope this helps & good luck.
WesTCo@sT
Sep 21, 2012 | Numark Industries Numark 5000FX 5 Channel...
Need to find how to open a NXD200 from numark... cause i got a problem with 1 button
It's just the screws in the bottom that hold the top and bottom shells together Possibly some on the sides.
Sep 21, 2011 | Numark Industries Numark NDX200 Tabletop...
Does nat read disk
typically with these if you get a no read disk on disks you have once before known to work in the unit then you probolly need a new drive. You may try to use different types of cd's ( expecially if burnt ) owners manual might have a preferred brand in it.
Aug 16, 2011 | Numark Industries Numark NDX200 Tabletop...
My NDX400's display screen doesn't show anything. When I turn it on, all the "characters" flash white, so I know it works. But then, it just goes blank. No matter what I do, nothing shows...
If you was to turn the deck upside down you will see 4 main screws in the corners holding the silver top to the black chassis of the deck. undo these screws and carefully turn the deck over and lift the top off slowly. I say slowly because before putting it down (you might need someone to hold it for you) you need to un-clip the white plug and there will be a data ribbon stopping you from pulling the lid away. this is the strip you need to check both ends that the connections are clean and pushed in properly (the blue strip on the connector should be facing the middle of the circuit board) be careful not to snap the connector and make sure you push it into its socket straight and not at all at an angle or it could snap. put the white connector back in and pop the lid back on and turn it on to see if worked.
Jul 05, 2011 | Numark Industries Numark NDX400 Tabletop...
My numark cd mix2 won't play a disc on the left hand side, it just says no disc
May 18, 2011 | Numark CD Mix2
Use the cdn22 on weekends for 6 hours a night. at least twice a nightone of the cd players said no disc when i put one in. its not always the same side that does it. the only way to correct it is to power...
Mar 14, 2011 | Numark Industries Numark CDN 22 Mk4 Double...
Numark Industries Numark CDN 22 Mk4 Double DJ CD Player Logo
270 people viewed this question
Top Numark Music Experts
Matthew Spark
Matthew Spark
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Numark Music Expert? Answer questions, earn points and help others
