Question about Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep
I installed a used Ingersoll-Rand SSR-EP30 yesterday. When it reaches set pressure (110) and unloads, the air pressure continues to gradually creep up until it shuts down on high pressure...approx. 145 psi. I do not have the operator's manual. Any suggestions? Thanks
I've a ingersoll compressor ssr ep 20 which is shutting down on high airent temperature.
Posted on Jul 11, 2012
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
SOURCE: I have an ingersoll rand ssr-ep60 with intellisys
There have a hidden button to turn on to do setting
Posted on Mar 31, 2010
dee73ten
  • 40 Answers
SOURCE: i need an exploded view of a ingersoll rand ssr
air end exploded view?
Posted on Aug 09, 2010
  • 214 Answers
SOURCE: I HAVE AN INGERSOLL RAND
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Posted on Mar 28, 2011
Ingersoll rand ssr ep60 60hp,how to reset low unload sump
Press the reset button on the controller. If the same alarm keeps coming back when you run the machine, then the machine is probably operating with low unloaded sump pressure and you will need to find out why. It's likely a false reading, a problem with the inlet valve or the wrong rotation.
Nov 15, 2015 | Ingersoll Rand Air Tools & Compressors
I have an Ingersoll Rand EP30 air compressor which has emptied its coolant out of the air inlet onto the floor. What are the probably causes and their remedy?
The unit was not turned off correctly or it shut itself down due to high temp or other problem what happens is that when the compressor is loaded (producing air) the inlet valve is open which if shutdown the pressure withing the compressor will escape through this open inlet valve which will contain oil also
Apr 29, 2012 | Ingersoll Rand Air Tools & Compressors
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
Unloader valve keeps opening and closing during pump operation. does not give a continuous discharge, as when the ball valve is stuck open. seems that when the pump reaches max output pressure that the...
Sounds like the cutoff valve is failing to cut power off to the compressor drive motor, while it activates the unloader.--- I'd consider looking closely at the contacts, or replacing the cutoff.
Nov 13, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Ingersoll Rand SSR compressor shuts down loaded or unloaded with no alarm, and then shows ready to start . Will not run more than a few minutes either loaded or unloaded. installed meter on incoming power...
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Aug 25, 2009 | Air Tools & Compressors
Ingersoll Rand Stationary Air Cooled Rotary Screw Compressor 10 Hp, 35 Cfm At 125 Psi, Model# Ep Logo
1,587 people viewed this question
Top Ingersoll Rand Tools & Hardware - Others Experts
elunsford
Phil Walker
Phil Walker
Are you an Ingersoll Rand Tool and Hardware - Other Expert? Answer questions, earn points and help others
