Question about Sharp DV-NC80 DVD Player/VCR
My Sharp DV-RW250H has stopped recording and playing back DVD's.Ok with CD's.Have cleaned lens without success. Does anyone have any ideas? Regards Trevor Naylor
3 Suggested Answers
  • 360 Answers
SOURCE: Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Posted on Feb 08, 2009
SOURCE: copying vidoe to dvd
Hi, if you still have the problem of unable to copy from video to dvd,then just follow these instructions, on the Remote, (when you have both the video tape that you wish to copy in the machine and the blank disc also in the machine ) Press the DUBBING Button(This is 2 buttons along from the Record button),almost immediately a message will pop up asking if you wish to copy VCR to DVD.
Hopefully this is of help to you. Regards. Gary
Posted on Feb 10, 2009
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
ERR-0101
meens fan problem ok thx nick use lens cleaning cd also ok
Feb 11, 2008 | Sharp CD-C2900 Shelf System
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
I have an DR275 LG DVD recorder. For some reason it stopped playing DVD discs. But it will play anything else you put in it I have cleaned the heads switch it of by the power as well. What could...
The laser mechanism has a number of optical components, not just the lens. There also additional fixed lenses and mirrors inside the laser unit which are very difficult to access. If sufficient dirt builds up on these components then the dvd laser may not work properly. Unfortunately it is very difficult (or even impossible) to clean these parts.
Another possible fault is that the CD laser is usually separate to the DVD laser and the DVD laser is no longer working properly, while the CD laser is still OK. In this case, the unit is definately not repairable without replacing the whole laser unit (not a readily available item and not likely to be cheap).
If the unit is out of warranty, your cheapest option is to buy a new DVD recorder.
Jun 16, 2011 | LG DR275 Recorder
I OWN AN ONKYO DVD- DV SP 502. I AM HAVING PROBLEM WITH THE PICK UP, AND THE SERVICE CENTRE TELLS ME TO REPLACE THE PICK UP ASSY,( 03 SD Pickup Assy-S part no.OXX8005). I HAVR TRIED CLEANING THE LENS BY...
The someone that told you to try cleaning the lens with a cotton swab (q-tip) was right.
if that doesn't work, check all the cables that go to or are in the pickup assembly.
If all that seems OK, then you very well may need to replace the assembly.
Mar 27, 2011 | Onkyo DV-SP502 DVD Player
Pionner DVR-540H-S no longer plays DVD's
little,
good day, true it's not advisable to use disc cleaner for it may also damage or scracth the optic lens inside.Possibly the optic lens of your player is either dirty caust by dust or faulty. but let's do hope it's only dust related and the only thing you can do now is to open and unscrew the upper cover of your player. Get a soft cotton buds, after dismantling the upper cover locate the optic drive lens and clean the lens by wipping it gently in circular direction. then try to play some DVD.
cheers,
mark
Feb 01, 2009 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Copying vidoe to dvd
Dec 02, 2008 | Sharp DVRW250 DVD Players
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
ONKYO DV-SP301
the play head of your device known as the ''lens'' is either dirty or bad thats why its selecting disc,try clean it with lens cleaner,if it still does the same thing call your technician,and tell him to change the lens for you.if he does the right thing ,it will work perfectly well.
Dec 13, 2007 | Onkyo DV-SP501 DVD Player
Sharp DV-NC80 DVD Player/VCR Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
