Heating & Cooling Logo
Posted on May 25, 2011
Duo Therm Mod# 90120.001 runs but won't light
Steve
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2015
Steve
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
481
Points
There are only three things that stop a burner from lighting (or engine from running): 1. No fuel 2. bad air/fuel mixture 3. no source of ignition.
Guess what? It's one of these three.
For starters, I actually have this furnace. First things first, make sure you have sufficient voltage to the unit. It runs on the 12 volt system, so make sure the battery is fully charged and/or you are plugged in to "shore" power and your inverter is working. If the voltage is low, the fan will run, the relays will click, but the gas valve may not open and the igniter may not have the juice to run.
At startup, you should hear relays clicking. Three times, on/off, 10 seconds apart, before the board gives up trying. If you don't hear this, probably bad board or bad hearing, but possibly bad sail switch (switch tripped by main blower air flow), relays, or gas valve actuators.
The blower will run even with the control board disconnected.
Next, check for obstructions in the inlet/exhaust, like wasp nests. Wasps LOVE hydrocarbons for some reason. Truthfully though, this shouldn't be a problem unless the nest completely obstructs the tube. This furnace has a choke which restricts the airflow to an area about the diameter of a large middle finger or a small thumb anyway. That's what the "burner air adjustment" adjusts.
If everything is clicking but it still doesn't light, you should be able to smell gas at the exhaust. If not, guess what? Probably no gas. Points to bad board, sail switch, low voltage at valve, or bad valve (unlikely).
Assuming you have gas smell, check the connection to the igniter. Heat/cool-down cycles will tend to loosen the nut. It's a .25 inch socket by the way. To get at it you need to remove the furnace from the RV.
After removal, to get the furnace out of its shroud, you only need to remove the hex screw at the center-front by the gas valve and the wiring pull-thru on the right side. Then the unit will slide out.
While you're at it, check the gas orifice for obstructions. I did this by removing the air inlet shroud, but there may be an easier way. I think you can remove the whole gas assembly instead, but removing the shroud lets you clean everything up a bit. I had mud wasps obstructing the inlet tube. The tube has a choke inside like a flattened golf ball. If you remove the tube it will fall out. It's a little tricky to get back in, but not impossible. Just line it up with a nail.
The gas jet is quite large as gas jets go. Remove the jet and clean it with brake cleaner and/or compressed air.
Check all connections, tighten as necessary. Clean and tighten ground connections, blow or vacuum away dust. Vacuum through the exhaust while you are at it.
Reassemble and spark her up on the bench.
You can McGyver a battery connection to the unit to test operation. Red to red, negative to yellow. The blue wires are for thermostat. Short them together to test operation.
This won't help much without gas, but you can at least see that the sail switch operates properly.
The sail switch controls gas flow.
You can't really test the igniter easily. It's high voltage and a pig to remove and replace. If you don't have a spare gasket, don't.
You can check voltage to gas valve. If none, it is either sail switch or board. Jump sail switch to test which.
Now the iffy bit. If the voltage is lower than 9.5 volts, the valve probably won't open. The question becomes "why." Bad ground? Bad connection somewhere? Bad input voltage? Bad board?
Check, clean and tighten connections. Clean edge connector on board - gently with cloth or pencil eraser. Try again.
This is the situation I have; there is a voltage drop at the valve (between connector and ground) of 3 volts. The furnace runs on shore power, but not on a fully-charged battery. I've ordered a new board.
If you don't understand me, or it still doesn't work, you need a licensed tech with access to parts. He should be able to bench-test unit, so just slide it out and take it to him.
PS: New board from http://www.dinosaurelectronics.com/ did the trick.
5 Related Answers
Anonymous
  • 1124 Answers
  • Posted on Jul 09, 2009
SOURCE: i have a duo therm brisk air model 57915-001 leak
Could be the drain path is clogged.. Take the cover off & see if you can get it cleaned..
Anonymous
  • Posted on Jul 19, 2008
SOURCE: duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Jan 03, 2008
SOURCE: Duo Therm Air Conditioner Mod. 59136.331/ Control box E 6360360
Something wrong with your thermostat, but if you are using a electronic thermostat and have the indication of supply like light in your control then you can replace the miniature relay that triggers the cool mode of the unit. But no indication of supply try to check the fuse, then if not works you to replace new thermostat.
ifixalot4her
  • 46 Answers
  • Posted on Aug 01, 2009
SOURCE: Duo-therm fan only runs on low
useually a sticking fan relay in the controll board this is the closeest unit to a home based cenral air system and i would leave this one to the experts if you want to trouble shoot there is a detailed wiring diagram on the back side of the pc board cover on the fan and compessor unit it self there is a seperate relay for each speed on your unit make sure getting power to selected relay if not trace wiring and do continutity tests back to themostat
Anonymous
  • 51 Answers
  • Posted on Aug 14, 2009
SOURCE: duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Duo therm heat pump blowing hot air only
relay module or communication cable from t-stat issue.
2answers
Duo therm mod. 57915 air conditioner seems to work good , runs for 4-5 minutes then kicks breaker , was kicking 30 amp breaker at camp ground , i've been working on connections to make sure its...
Unit may pull as much as 17-18amps when compressor starts up, but level out to 12-15 amps when up and running. Keeping in mind that is all relative to proper 120v incoming voltage, heavy enough wire to run the application etc. If your AC unit needs cleaning , it may draw an extra amp or 2 . With that said, when your at the park, first thing I'd question is their incoming voltage to RV, and try running fridge etc and anything else on propane if possible. The AC alone should not cause 30amp at source breaker to trip, before 15 0r 20 amp breaker in RV that is connected to AC trips. If it doesn't trip your breaker at home, and all is connected same at park, then I certainly would suspect bad breaker or voltage/wiring at park is the cause. P.S. I noticed you said you have 12 gauge wire (rated at 20 amps) connected to a 20amp breaker at panel, but RV is plugged in to a 15amp receptacle, I will assume with a 15 amp adapter from 30 amp plug. Do you see any hazard regarding 15 amp rating on receptacle? ( just a little advice.)
2helpful
Duo-therm mod # 57915 not cooling fan?????
3helpful
5answers
Duo-Therm by Dometic Thermostat
red and white are positive and neg 12v
green is low fan
grey is high fan
yellow is cooling
blue is neg 12v(marked B-)
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
