Question about KitchenAid Architect ® Series II KBFC42FTS Stainless Steel
MY Model: KBFC42FTS IS LEAKING WATER ON THE FLOOR. DON'T KNOW WHY
How to fix kitchenaid kbfc42fts bottom freezer builds up ice and leaks on floor
The drain line is clogged go around the back of machine take off back cover and you will see a drain line coming through the floor and at the end of it is a rubber grommet.The rubber grommet is clogged up just take it off and throw it out and then turn off machine for 24 hrs with doors open to melt out all the ice
Aug 08, 2014 | KitchenAid KBFC42FTS 42" Bottom Mount...
Car leaking
are the doors wet or just the floors?
most likely its the door seals, cracked or broken or just plain old and stiff
could also be window seals
check the seals around the windows and open the door and check the door seals
Mar 30, 2013 | Cars & Trucks
I have a Whirlpool washer that's leaking water onto the floor. Jason Harris told me to look under the heater i don't know where the heater is.
There is no heater on that machine.
Does the water leak as soon as you start the fill cycle or does it start to leak when the water level gets up to the agitator?
Oct 20, 2012 | Washing Machines
My Whirlpool Gold French Door Refrigerator GX2FHDXVD is leaking underneath. The pan is cracked. How do I remove the pan?
i don't think there is a pan in your machine,it's built into the bottom frame near the compressor where the water evaporates from the heat.most likely you have a blocked drain in the freezer or one of the water lines has a crack or the water valve is cracked and leaking.open the freezer door,look at the floor of the freezer to see if there's any ice there on the freezer floor,if so you have a blocked drain,where is the water leaking from,in the front of the machine or the rear,also do you have a water line hooked up to the machine?
Oct 02, 2012 | Refrigerators
Water leaking into the back seat floors
I don't know if you have a wiper on the back window.... if yes! there could be a leak in the water pipe ending there...
Sep 01, 2012 | 1996 Buick Park Avenue
I have a kenmore portable air conditioner. It was given to me so I don't have much info on it. When we use it we have water on the floor after we shut it off. We have ruined the rug . We replaced the...
It from all you said, it sounds like it's condensation dripping from the cooling coils. They are probably dirty and therefore the condensation is not evaporating like it should. Also, the air intake filter may be dirty or clogged.
Since you don't have an owner's manual, locate the model number of your unit and then go online to Sears Parts Central. Armed with the model number you will be able to locate the Owner's Manual and download and print it for future reference. It alone, will prove invaluable.
Hope this helped you and thanks for choosing FixYa.
Aug 03, 2011 | Heating & Cooling
Hi! My AC is leaking. I bought it from QVC april 2009. it's been fine. all of a sudden it's leaking out the bottom. the plug is pluged in and when i try to drain it a little water comes out...
If it's leaking water and it's an electrical appliance. Water & electricity don't mix, do they? So, first turn the unit OFF and unplug it from the wall. But, not if you're standing in water.
Here's the problem: The plastic tubing that's supposed to drain the water into the bucket is clogged and it's draining it onto the floor.
Remove the water bucket and look up into the bucket cavity. You should see a small hole or tubing. That's the drain to the bucket. Using an 18" long plastic Zip Tie, appropriately sized to fit that hole or tube. Carefully insert the Zip Tie into it and continue to insert it, until you reach a bend in the tubing. You must gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then, slowly pull it back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared for some water to follow. If you don't have a Zip Tie & don't want to go out and buy one, you may use something similar. But, NO wire coat hangers.
Hope this helped you solve the problem.
Jul 06, 2011 | Haier HEATER CPN10XH9 Air Conditioner
Frigidare r5303b under worktop fridge with little freezer box inside what number should it be on because thermastat does not seem to go off much
Good day,
Don't know the numbering sequence on your model, but all manufacturers design the control so that half way from warmest to coldest is normal.
Mar 31, 2010 | Frigidaire Refrigerators
KitchenAid Architect ® Series II KBFC42FTS Stainless Steel Logo
55 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
