Hello, i have a coby RC-011 tv and one day one of my channels stopped working. i bought a new cable wire and that did do anything. the MTS says mono, and all the other channels say stereo. any way i can change mono to stereo?
tvtek
  • 1284 Answers
SOURCE: SAP - I can't get my new TV out of Mono and into stereo.
Are you using a cable box sush as a Comcast cable box? If so then the volume control within the cable box is most likely not high enough for the TV to detect a stereo pilot signal. The Comcast remote (if thats what you have) still is programmed to operate the volume within thier box, the volume display will be at the top of the picture and it will be in white. Turn it up until the word "stereo" appears. then leave it at that setting and use your TV's volume control only.
Posted on Feb 13, 2007
snakehead
  • 1074 Answers
SOURCE: mts:mono mode and just keeps scrolling through channels
take that tv to a tech you bought that set deffected .or take it back to where you buy it from.but my advice is that you take it back to where you buy it from.as you will pay double.repairs and what you have already paid for the set.good luck
Posted on May 03, 2007
BDEATH
  • 58 Answers
SOURCE: Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Posted on Sep 04, 2007
djnick989
  • 1067 Answers
SOURCE: Audio Problem - Can't turn the 'stereo' feature on the MTS
what cable boxdo uuse can use s video out for video to tv and rca cable for sound left and right is it a hd tv then u wantto use coumpiunt cable or hdmi
Posted on Jan 11, 2008
MikeMaierTV
  • 206 Answers
SOURCE: Audio Problems
First for the Toshiba could the SAP (Second Audio Progam) be turned on this will somtimes cause the audio to drop. And are you using the onboard tuner or does this set conect to a cable box?
Then for the Panasonic the most common problem for your fault would be the convergance curcuits are shorted and need replacment, or some other componet may be loading down the set and forcing it in to shut down, Tv's will do this to prevent further damage
Posted on Feb 13, 2008
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
Jan 11, 2008 | Toshiba 57H83 57" Rear Projection HDTV
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
Why doesn't the remote control work?
The batteries may have to be replaced. If new batteries do not solve the problem, it may be necessary to replace the remote.
Jul 16, 2015 | Coby Televison & Video
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
I just received a Coby TFTV992 9" portable TV. I'm trying to tune the TV channels without success.
1st click the "mode" button on the TV or remote then use the vol. up and down buttons to scroll around until you get to DTV mode then press "enter" on the remote you should get a message "please run channel auto scan" . click "Menu" on the remote the "Picture" screen will come up, keep clicking the vol. up button to scroll past "Audio" then "Setup" then to "Channel" then use the CH up or down buttons to scroll to "Air" click OK , then use the CH down button to scroll to "Scan all channels" then click the vol. up button. it then should start scanning, FYI you have to be fast!
Jan 07, 2013 | Coby Usa Coby Electronics TFTV992 9 Inch...
Why does my Coby 40 TFTV4028 LCD TV keeps flickering
Try changing the input device to something you are sure works.
Look for any loose contacts in RC jacks/sockets/Cable. Check your power outlet for any loose contacts.
Jul 30, 2012 | Coby 40 TFTV4028 LCD TV
Asus mobile problem
IF you are planing to buy Asus Mobile phone You Have to Contact Asus Sales team:-
Adil Azim Siddiqui
Channel Manager
9999992557
adil_siddiqui@asus.com Delhi
or
Akanksha 011-46508998
Service centre Address:-
ASUS Technology Pvt. Ltd
RC
Manish Kumar
011-46508998/96/97
404 - 405 , 4th Floor ,Padma Palace ,Building no. 86 ,Nehru Place,New Delhi 110019
Mar 21, 2010 | ASUS Eee PC 1000H Laptop
Why do i only get 4 channels that show?
sir you need to auto search your t.v set or auto program it to get all channel you desired.
Aug 06, 2009 | Coby TF-TV2617 26 in. LCD TV
Mts:mono mode and just keeps scrolling through channels
May 02, 2007 | Apex Digital GT3215 32" TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
