Question about Kenmore Dryers
Where is the thermal fuse on a Kenmore model 76902690?
    Brigadier General:
  • 3,301 Answers
Remove the back panel,, you'll see it
Posted on May 25, 2011
Do all kenmore ovens have a thermal fuse?
As far as I am aware, no ovens have a thermal fuse. However, you live and learn, some do, but mine doesn't.
Oven Thermal Fuse (part #WP3196548 and others)- How To Replace ...
Video for Kenmore oven thermal fuse? 3:02
https://www.youtube.com/watch?v=BF-cmB9xBSk
Aug 23, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Thermal Fuse http://www.appliancepartspros.com/App... Follow these simple step-by-step ...
Kenmore Electric Range Replace Thermal Cut-Out Fuse ... - YouTube
Video for Kenmore oven thermal fuse? 5:51
https://www.youtube.com/watch?v=Ihqo1QyYwaQ
Nov 14, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the thermal cut-out fuse on Kenmore and ...
Oven Thermal Fuse - 9759242 for Whirlpool, Sears, Kenmore
https://www.amazon.com/Oven-Thermal-Fuse-9759242-Whirlpool/dp/B019S0D482
Rating: 5 - ‎1 reviewNew non resettable oven thermal fuse replaces Whirlpool, Sears, Kenmore, Estate, Roper, KitchenAid, 9759242. Replaces part numbers: AP3879224, 4452223, 1061375, AH974726, EA974726, PS974726. ... 4452223 NEW OVEN THERMAL CUT OUT SAFETY FUSE for Whirlpool and KitchenAid….
How to Replace an Oven Thermal Fuse | Repair Guide Help - Sears ...
https://www.searspartsdirect.com/...oven/how-to-replace-an-oven-thermal-fuse.html
This wall oven repair guide explains how to replace a thermal fuse. The fuse trips to protect the wall oven from excessive heating. If the fuse blows, the oven won't heat. You can reset some fuses with the press of a button; this guide explains how to replace one that can't be reset. Replace the thermal fuse using a ...
How to Replace Thermal Fuses in Kenmore Ovens | Hunker
https://www.hunker.com › ... › Home Appliances › Other Home Appliances
Nov 15, 2011 - Kenmore ovens are manufactured by Whirlpool and distributed by Sears, Kenmore's parent company. Whirlpool and Kenmore ovens have a thermal fuse that is located in the control panel of the appliance, which protects the oven control board from overheating. On Whirlpool and Kenmore ovens, it is not...
ovens have thermal fuse Google Search
Apr 04, 2018 | Kenmore Kitchen Ranges
I am trying to figure out why this Kenmore model 6 5821 dryer is short cycling flame will come on for about 3 minutes or less and continue to turn on and off
Sounds like a thermal fuse is blown. Remove back plate of dryer and locate the thermal fuse (small white plastic strip with two wires coming out). $12 thermal fuse can cause this problem. Have a manual? If not buy one!
http://www.searspartsdirect.com/partsdirect/brands/Kenmore-Parts
Jul 02, 2016 | Kenmore Dryers
How do l change thermal fuse on Kenmore dryer model 110.88752793
Hello Shelton;
My name is Peter. I am a retired field service appliance technician.
25439664-j5jtgwve0qxm0uckbdimcx40-1-0.jpg Thermal fuse 3399849 trips if the exhaust air leaving the dryer becomes too hot.
Unplug the dryer before installing the thermal fuse. Wear work gloves to protect your hands during this repair.
This Dryer Thermal Fuse part #3399849
This is located in the back of your dryer on your hot air exhaust manifold.
Feb 17, 2015 | Kenmore Dryers
Kenmore elite 110.7703 no heat
Hi there
From the model number it seems this machine was made by Whirlpool for Kenmore. The thermal fuse is on front bottom near the blower wheel.
a) Pop open the front panel.
b) Then remove front door panel by removing the two secrews
c) Remember to disengage the door switch wiring
d) you will see the thermal fuse near the blower compartment.
e) If thermal fuse is burned out then it should not have continuity on OHMS scale on a multimeter.
Dec 07, 2013 | Kenmore Dryers
Amana dryer model YNED7200TW will not start. there is power, but start button does nothing. Resetting breaker did not work. Any ideas?
Thermal Fuse
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
  • Admiral Dryer Thermal Fuse
  • Amana Dryer Thermal Fuse
  • Crosley Dryer Thermal Fuse
  • Estate Dryer Thermal Fuse
  • Kenmore Dryer Thermal Fuse
  • Kenmore Refrigerator Thermal Fuse
  • Kenmore Washer/Dryer Combo Thermal Fuse
  • KitchenAid Dryer Thermal Fuse
  • KitchenAid Washer/Dryer Combo Thermal Fuse
  • Magic Chef Dryer Thermal Fuse
  • Maytag Dryer Thermal Fuse
  • Roper Dryer Thermal Fuse
  • Roper Washer/Dryer Combo Thermal Fuse
  • Whirlpool Dryer Thermal Fuse
  • Whirlpool Washer/Dryer Combo Thermal Fuse
In Stock
Quantity: http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
Jun 08, 2011 | Amana Dryers
No heat
The thermal fuse is located on the blower housing while the thermal cut-off is located on the heater housing. If the dryer is electric, runs but doesn't heat, the thermal fuse is not the problem; otherwise the dryer will not run because the thermal fuse is wired in series with the motor and cuts power to the motor when it fails. The problem could the heating element, high-limit thermostat, thermal cut-off, or cycling thermostat. These components can be found in the blower housing and the heater housing depending on the model of the dryer. Specify the model number of the dryer for a more specific advice.
Apr 12, 2010 | Kenmore 63942 Dryer
Kenmore elite oasis dryer model #110.6708
about $10.00 for the thermal fuse and 1 Hr Labor (my rate is $30.00 per hour) and a service call,rate depending on where you live
Mar 19, 2010 | Kenmore Elite Oasis 6809 Electric Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
Not heating
start by checking the fuse box or breaker box to make sure you have power. An Electric dryer will run however it will not heat if a fuse is open.
Oct 02, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
