Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
We have a twyford toilet with a saniplus system behind. This suite was added when the previous owners had a room and ensuite built over the garage. There is always a disgusting smell coming from the toilet. I do not know how to clean it. can you help
    Scholar:
  • Saniflo Expert
  • 115 Answers
Check the top lid of the pump casing. There is a 1/2" hole on top which must be kept plugged or seal capped. If left open odor tends to emmitt from there. Also check for any loose connections or waste leak at the bottom of the pump casing or the bowl.
Posted on Jul 13, 2011
Recently purchased a Caravan which does not have manual for the Twyfords Toilet System. If I were to furnish you with model nos etc., could you possibly supply me with same, please.
the toilet system manual will be on the manufacturers web site
or you can go to any caravan service center as the toilet will be fitted to many different brands of caravans
Nov 22, 2017 | Home
I've had a saniplus toilet system (with toilet and sink) for about 10 years. Suddenly stopped working as well. The macerator pump runs in shorter bursts and the water level in the toilet goes down
You should check the 1 1/2" vent pipe if there is one attached to the top of the pump casing. The vent pipe must be vented to the open air, outside of the house so the unit can breath air in and out at all times. A lack of airflow usually creates this type of problems. Leave the vent connection open to the room and flush the toilet, you will see the difference when pumping.
Mar 11, 2013 | Home
What is an Ensuite?
Ensuites are designed to provide you with a private room or as a toilet or shower cloak. Ensuites are available in either single or double size and come with a unit supported with poles. There are some ensuites with features like removable roof for use with a solar shower, removable floor, storage for toiletries, hook for a light and mesh windows.
Sep 04, 2012 | Bass Pro Shops Camping, Backpacking &...
When I flush my mascerating toilet, the tank behind the toilet floods over. How do I fix this?
I assume you are referring to the holding tank and not the pump case.
The bowl float system on the couple SaniPlus toilets I have seen are similar to standard toilets. This will be a plastic float that slides up and down the water inlet tube. It will be attached to a shut off lever at the top of the tube by a metal rod. The float and rod are attached to each other by a "V" shaped clip. To adjust the shut off level you need to slide this clip up/down the rod.
If you remove the top of the tank and flush you should be able to see this working when flushing. Try shutting off the water flow by moving the shut off lever by hand. Use the water shut off at the inlet line leading into the tank to start and stop the water before it over flows if the lever does not work.
If the lever does not stop the flow then you have a problem with the water inlet mechanism and it may need to be replaced.
If your inlet mechanism is different from what I described please respond back with the model number of your SaniPlus.
Hope this helps.
Jun 22, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniplus draining in pulses
When you flush the toilet, the Saniplus will turn on and off once or twice, this is normal. If it turns on 3 times or more then could be a problem with venting or the discharge pipe installation may not be properly installed. But when you run the sink or shower it will turn on and off constantly, this is normal. The Saniplus pumps out the water as it comes in.
Jun 20, 2010 | Saniflo & Saniplus& Macerator Pump
What space is required to install this unit
Only the normal space behind the wc pan. If you go to the Saniflo website they will give the exact dimensions.The unit is approx. 350mm x 300mm x 100mm wide
Feb 27, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Size of inlet for shower for a saniplus toilet system?
The inlet pipeworks for a shower to Saniflo would normally be 2" / 52mm polypipe as per the diagram (different saniflo unit type, but they are all the same)
If this helps please leave feedback, if not - let me know and I'll try and help some more!
Jan 25, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
A saniflo ensuite shower room that is
If you mean that it self activates then the non-return valve is at fault by the sound of what you say
Nov 24, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
405 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
