My Sharp DV-RW250H has stopped recording and playing back dvd's. It tries to read discs and comes up with error code C104 incorrect disc.I've tried new discs,pre-recorded ones and cleaning the lens without any success. It has no problem reading playing back CD's. Does anyone have any suggestions please? Regards Trevor Naylor
informatica
  • 1114 Answers
SOURCE: Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Posted on Aug 01, 2007
TEKUSER
  • 56 Answers
SOURCE: my panasonic DMR-ES 15 cannot read anymore!
There maybe a problem with the optic lens (dirt) try to clean it very gently with cotton, also the motor plate that holds the cd/dvd is not holding it very well so it not rotates at proper speed try to clean the both sides where the hole of the cd/dvd is when it´s inserted, if you think that you migth not have skills for that don´t do it.
Hope it help
Posted on Jun 25, 2009
  • 111 Answers
SOURCE: Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Posted on Apr 01, 2010
  • 5370 Answers
SOURCE: Yamaha MusicCast won't record cds
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem.If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen.The lens is very thin glass material.You can say the lens is the "eye" of the unit.If the eye is dirty then it will not see the object.The unit needs to be opened carefully and this lens has to be checked.If any dust is collected clean it.Using the cd lens cleaner helps,but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help.If the lens is got cracked then the lens assembly has to be replaced. You can use dry tissue to clean the lens.once the unit is opened.------------This will help.Thanks.Helpmech.
Posted on Dec 14, 2010
gopakumarg43
  • 74136 Answers
SOURCE: how do i replace the read write head on my panasonic dvd recorder
It is not an easy work as you thinks. You must have thorough knowledge in electronics, and experience to diassemble and reassamble the deck mechanism. Seek tech support. This is a very skilled work. Never make the set irrepairable.
Posted on Jun 04, 2012
Testimonial: "Thanks for your help."
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Aug 01, 2007 | NAD C541 CD Player
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
My DVD-HR753 will not read discs. A message comes up saying 'this disc cannot be played or recorded'
Original dvd disc,not copy or not another countries datas disc?Same country as the DVD player was bought and formatted Disc?Most likely the disc u trying to play it is in a difference formatted of recording or finalizing data codes inbeted by some patent coded program.Tries play many more other DVD discs,should work find,than the original disc,u trying to play have protected datas or difference format and not same as of ur DVD player main programming firmware.
May 27, 2011 | Samsung DVD-HR735 DVD Recorder/HDD...
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Sansui dvd player wont play and dvd's... shows up as incorrect disc c104 error
Try cleaning the optics with one of those DVD cleaners.
When that probably doesn't work, you can hand clean the optics if you can figure out how to get at them. (easy on some, hard on others) If that doesn't work, it is prbably not worth going any farther
Dec 21, 2007 | Optical Coating Model 108 VHS VCR
DVD recording or playing.
Where can you find the 1-2X DVD, I have only been able to find 1-4X and none of these work.
Feb 07, 2007 | Sansui VRDVD4005 DVD Player/VCR
 Grubhead
Grubhead
