Question about MA Audio HK4000D Car Audio Amplifier
Amp is powering on at all
Well i have a brand new amp ma hk401sx series and after i installed it i noticed that it has no power at all being feed to it that i kow of no leds or noise at all i hooked up the remote to it and i have no problems gettin a led o the remote only can you help me
  • bereagolfer0 Aug 30, 2008
    im gettin power and has a good remote
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Posted on Aug 16, 2008
6ya staff
SOURCE:
Kenwood KDC-BT558u drains 640 constantly from the Battery even when the unit is off!
check the wire harness connections, sounds like you have KOER power hooked to KOEO. Or in other words, you have power to the radio with the key off that should connected to key on power
Jan 06, 2015 | Kenwood Car Audio & Video
When the rca cords are plugged into the amp it makes a constant low note. Once the rca's are disconnected the low note stops. What would cause this?
You have a bad ground in most cases.
Because of this the amp tries to pull ground from the RCAs which are connected to your grounded headunit chasis.
To make a solid amp ground. Find a piece of metal (not the back deck), scrape off the paint and then use 2-3 self tapping screws with washers to keep the ground from moving.
And of course plz don't forget to rate me ;)
Sep 02, 2010 | MA Audio HK401SX Car Audio Amplifier
Amp is in protect mode
If you have'nt fixed your amp by now I thought I'd tell ya a couple of things why it's going into protect. The basics. Blown subs, bad power suply or mosfets, and blown output transistors/mosfets. Still need help let me know. I repair amps for a living and i'm the cheapest you'll find and honest. I also give the longest warranty. I'm tired of other people rippin people off on repairs. Let me know.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/mark_b53a7494531bf96d
Apr 24, 2010 | MA Audio HK401SX Car Audio Amplifier
I have 2 dvc 4 ohm alpine type r 15's and 2 svc american bass
Hi mate very nice amp you got there here is the specs for it
Model: MA Audio HK401SX
Hard Kore Series 1800 Watt 1 Channel High Performance Class X Car Amplifier
1 x 1800W RMS @ 0.5 Ohm Mono
1 x 1200W RMS @ 1 Ohm Mono
1 x 650W RMS @ 2 Ohm Mono
1 x 500W RMS @ 4 Ohm Mono
Fully Unregulated MOSFET Power Supply
2 Ohm Stable @ Mono
1 Ohm Stable @ Mono
0.5 Ohm Stable @ Mono
if you have 2 12s just bridge them and you will have 650wrms at 2ohm running to them or one sub at 4 ohm 500w rms ps they should pump iam running 2 12s with just 360rms at 2ohm and they do the job good luck
Oct 19, 2009 | MA Audio HK401SX Car Audio Amplifier
2 alpine type r 15's 4 ohm dvc and 2 american bass svc 4 ohm and hk401sx how do i get the most beat?
Option 1 (parallel) = 0.5 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 1/2 ohm mono This set up will blow your mind as your amp will put out 1800rms at 0.5 ohm
How do i drop it down to 0.5 ohm
there are no settings on the amp, if it is made to be stable at .5 ohm you will need 8 voice coils to make .5 ohm, if your subs ar 2 ohm, you will need 4 coils to make .5 ohm when hooked in parallel
Sep 23, 2009 | MA Audio HK401SX Car Audio Amplifier
My ma audio hk 4000 amp is powered on no sound coming thru subs amps brand new
If there is no protection light on, be sure the input is on. Some head units need to be turned on manually (factory set to OFF).
Verify the subwoofers are wired properly.
A list of your components would help to solve your problem.
If it is new, it should still be under warranty - worst case scenario output transistor(s) blown, or power supply bad.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Protect light
Does the amplifier do this when you don't have the sub hooked to it? If so, you have a pinch/short in your ground or power wire. If not, the subwoofer has a short in its voice coil or the amplifier needs to be repaired as it cannot handle a typical load.
Dec 29, 2008 | MA Audio HK401SX Car Audio Amplifier
My brand new system isnt working right...
All righty then, This is most often gaused by bad grounds. Make certain the ground of the amp is a solid clean connection. The best place is under one of the rear seatbelt bolts, next check the condition of the ground at the battery this has to be clean with a good connection to the chasis, third make sure the Head Unit also ahs a clean positive ground. If these do not yeild results then get hold of any littel portable radio, cassette player, mp3 player as long as it has a earphone jack. Get one of those cables that have a earphone plug on one end and RCA plugs on the other. Disconnect the RCA's from the HU and hook up the player. Power up the system and play back from your portable player, mess with the gain on the amp and see if you still have the same problem when playing back from the portable device. If the problem goes away then you probably have blown grounds on the RCA's on the head unit and only a repair shop can fix that or a new HU. If you still have the problem with the portable player then adjust your lowpass filters and cut off to a higher frequency until the problem goes away. The gain on these amps should never be used to make up for low output from the Head Unit. (another cause for this condition) Get a HU that has 4 to 6 volt sub outputs and crank the gain down on the amp. That gain control is to control distortion (over driving the amp) not to make it louder. If you want louder then go for the HU with the higher sub output voltage or go with a SUB with a lower ohm rating. Your amp is stable down to 1 ohm. Oh and double check if you have your subs wired correctly improper wiring at the subs can m ake this problem worse.
Apr 28, 2007 | MA Audio HK401SX Car Audio Amplifier
Amp ???
Ever find a solution? i am having the exact same problem... didnt happen until i plugged in the bass remote they send with it...
Dec 28, 2006 | MA Audio HK4000D Car Audio Amplifier
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
80 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
Fahr Quad
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
