Question about BenQ FP71G 17" LCD Monitor
Benq Q7T3 Monitor fails on startup
My Benq monitor will not start at all. I appears there maybe some voltage failure during the startup proceedure,
    Champion:
  • 293 Answers
Hi...there,
So, this Q7T3 LCD Monitor have a power brick (AC Adapter)??? If yes, check to see if it still lite green. If no, then your backlight inverter need to replaced or repaired. Have a nice day!
Posted on Sep 14, 2008
Displaying only 2 secs
Monitor STFC (Self Test Feature Check)
* Turn off the monitor
* Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
* Unplug the monitor video cable from the back of the computer
* Turn on the monitor
* The floating dialog box should appear on screen against a black background. If the issue appears during the STFC, the monitor is defective. Get it replaced.
Oct 31, 2013 | BenQ Computers & Internet
Brand new BenQ EW2730V not turning on after 30-40 minutes of use with the XBOX 360/PS3. Is it a feature or something because the power button is blinking orange?
Oct 22, 2013 | BenQ EW2730V 27 WIDE
When I switch on my FP767 monitor the light appears as blue, but nothing on the screen.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL (BenQ makes Dell MONITORS) monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 21, 2010 | BenQ FP767 17" LCD Monitor
My monitor keeps turning off and on
You may haev failing power supply or the backlight inverter circuits are going bad. BenQ makes monitors for DELL and HP.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 25, 2010 | BenQ G2110W 21" Monitor
Do you know how to open a benq fp91g+ monitor?
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=BENQ&megnev2=FP91&kategoria=&kat2=all
Most of the time you will use flat blade screw driver, starting at the bottom edge to pry open the case then work your way around, also look at YOUTUBE, just search for HOW TO OPEN LCD MONITOR.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 15, 2010 | BenQ FP91G+ Monitor
How do I remove the back of a Benq Q7T3 monitor after removing the 7 screws ???
usually the back of some monitos come togerther by preassures clips , you can use an screwdriver (flat) or there is a plastic tools that looks like the tool that you used for remove old paint from the walls , so them stick the tools between the plastics cover and with caution force to open a litter bit at the time , possible you will brocke some of this clips but that happen all the time , best regards italocub
Jun 11, 2009 | BenQ Computers & Internet
Benq-q7t3 no picture
see http://www.badcaps.net/forum/showthread.php?t=4304
Jun 21, 2008 | Samtron 96BDF 19" CRT Monitor
Benq 19" monitor not working every time when computer started
Check your connections and make sure they are tight, and there are no bent pins. If everything seems ok, you might want to try plugging this monitor into a different computer or plug a different
monitor into yours to determine whether it's the monitor, the video card, or maybe the driver (doubtful on this as you state it seems to be bad somethimes on boot).
May 26, 2008 | BenQ Computers & Internet
BenQ LCD 17 inch Monitor
I wonder if this has a backlight in it. Most/or all LCD flatpanel displays use a backlight in them, namely a small florescent tube (a tiny version of the office florescent lights). If this is burn't out, or the little power supply which runs it dead, you will have a black display. The image is actually there, you just can't see it, except perhaps faintly when external light hits it just right. The display must be disassembled to check this light. If you have tech savvy, and some equipment, voltmeter, maybe an oscilloscope, you could check it out. Where to get a replacement lamp? Google it... perhaps the manufacturer.
Sep 17, 2007 | Gateway FPD2275W LCD Monitor
BenQ FP71G 17" LCD Monitor Logo
1,164 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
